促销6ES71531AA030XB0
品牌: 西门子
型号: 6ES71531AA030XB0
所在地: 全国
最后更新: 2014-06-18 08:30
 6DD1600-0BA2
SIMATIC TDC, CPU551
64-BIT CPU MODULE
WITH DIGITAL INPUTS
6DD1600-0AK0
SIMADYN D
PM6, RAPID 64-BIT CPU MODULE
WITH BINARY INPUTS,
L AND C BUS
6DD1600-0AJ0
SIMADYN D
PM5, 32-BIT CPU MODULE WITH
BINARY, ABSOLUTE AND INCREMENT.
INPUTS, L AND C BUS
6DD1600-0AF0
SIMADYN D
PROCESS MODULE PM16
GENERAL APPLICATION 16BIT16MHZ
L- AND C-BUS , 16BI AL, 16BO
6DD1601-0AE0
SIMADYN D,
PROCESSOR MODULE PG16
LINE-COMMUTATED CONVERTERS
6DD1601-0AH0
SIMADYN D
EXPANSION MODULE ITDC
FOR PM4. PM5. PM6
CONTROL F. LINE-COMMUTATED
CONVERTERS VIA SITOR IF
6DD1606-0AD1
SIMADYN D
TECHNOLOGY BOARD T400
FOR 6SE70/71 AND SRT400
32-BIT/32MHZ, 8BI, 2BO, 4BI/BO
5AI, 2AO;2 PULSE ENCODER INPUTS
2 SER. INTERF.+ 1 SSI ENCOD. OR
1 SER. INTERF.+ 2 SSI ENCODERS
CONFIGURING WITH D7-SYS
1MB FLASH, 2MB RAM, 32KB EEPROM
6DD1606-3AC0
SIMADYN D
I/O SUBMODULE IT41
FOR PM4/PM5/PM6
16 BI, 16 BO, 4 AI, 4 AO,
4 ENCODER INPUTS
6DD1606-4AB0
SIMADYN D
I/O SUBMODULE IT42
FOR PM4/PM5/PM6
16 BI, 16 BO, 4 AI (A/D),
4 AI (V/F), 4 AO
6DD1607-0AA2
SIMATIC S7-400,
FM458-1 DP  APPLICATION MODULE
FOR SIMATIC S7-400
6DD1607-0CA1
SIMATIC S7-400,
EXM 438-1 I/O EXPANSION MODULE
FOR FM 458
4 X ANALOG OUTPUTS 16 BIT
EXM 438-1 NOT SPAREPART
COMPATIBLE TO EXM438
6DD1607-0EA0
SIMATIC S7-400,
COMMUNICATION EXPANSION MODULE
EXM 448
FOR FM 458
6DD1607-0EA1
SIMATIC S7-400,
COMUNICATION EXPANSION MODULE
EXM 448-1
WITH PROFIBUS-DP
AND SLB F. SIMOLINK INTEGRATED
6DD1607-0EA2
SIMATIC S7-400,
EXM 448-2 WITH 2 SIMOLINK
INTERFACES
6DD1607-0CA0
SIMATIC S7-400,
EXM 438 I/O EXPANSION MODULE
FOR FM 458
6DD1610-0AK0
SIMADYN D
FLASH MEMORY MODULE MS51
PCMCIA CARD FOR PM4. PM5. PM6
4 MB FLASH-EPROM, 8KB EEPROM
6DD1610-0AH0
SIMADYN D
MEMORY SUBMODULE MS5
32BIT, 2MB FLASH-EPROM
8KB EEPROM
6DD1610-0AH3
SIMATIC TDC
MEMORY CARD MC521
2 MB FLASH-EPROM, 8 KB EEPROM
6DD1610-0AH4
SIMATIC TDC
MEMORYCARD MC500
4MB FLASH-EPROM, 8 KB EEPROM  *****
6DD1610-0AH6
SIMATIC TDC
MEMORYCARD MC510
8 MB FLASH-EPROM, 8 KB EEPROM
EEPROM
6DD1610-0AG1
SIMADYN D
MEMORY SUBMODULE MS41
16 BIT, 512KB EPROM,2KB EEPROM
6DD1611-0AG0
SIMADYN D
MAILBOX MM4 , 32BIT
L- AND C-BUS , EACH 2MB RAM
SYSTEM ERROR SIGNAL OUTPUT
6DD1611-0AF0
SIMADYN D
MAILBOX MM3
L- AND C-BUS , EACH 64KB RAM
RADIO CLOCK
6DD1640-0AH0
SIMATIC TDC
SIGNALMODULE SM500
WITH 8 AO/8 AI/16 DO/16 DI/
4 INCREMENTAL ENCODER INPUTS/
4 ABSOLUTE ENCODER INPUTS/
6 LED
6DD1641-0AC0
SIMADYN D
BINARY INPUT/OUTPUT MODULE EB11
32BI,32BO
6DD1642-0BC0
SIMADYN D
ANALOG OUTPUT MODULE EA12
8AO
6DD1660-0BA0
SIMADYN D
COMMUNICATION MODULE CS12
FRAME COUPLING VIA LWL
1 RECIEVER/TRANSMITTER
6DD1660-0BB0
SIMADYN D
COMMUNICATION MODULE CS13
FRAME COUPLING VIA FIBRE OPTIC
CABLE , 4 TRANSMITTER/RECEIVERS
6DD1660-0BC0
SIMADYN D
COMMUNICATION MODULE CS14
CABLE, 8 TRANSMITTERS/RECEIVERS
6DD1660-0BD0
SIMADYN D
COMMUNICATION MODULE CS22
FRAME COUPLING
VIA OPTIC FIBRE CABLE
6DD1660-0BH0
SIMATIC TDC
COMMUNICATION MODULE CP52AO
ACCESS MODULE FOR
GLOBAL DATA MEMORY (GDM)
6DD1660-0BG0
SIMATIC TDC
COMMUNICATION MODULE CP52IO
INTERFACE MODULE FOR
WITH 4 INTERFACES
6DD1660-0BF0
SIMATIC TDC
COMMUNICATION MODULE CP52M0
MEMORY MODULE FR
WITH 2 MBYTE SRAM MEMORY
6DD1661-0AD0
SIMATIC TDC
COMMUNICATION MODULE CP50M0
WITH 8 MBYTE BUFFER MEMORY,
UP TO 2 MPI INTERFACES,
UP TO 2 PROFIBUS DP INTERFACES
6DD1661-0AD1
SIMATIC TDC
COMMUNICATION MODULE CP50M1
UP TO 1 MPI INTERFACE,
6DD1661-0AB1
SIMADYN D
COMMUNICATION MODULE CSH11
SLAVE INTERFACE FOR BUS SYSTEM
SINEC H1
6DD1661-0AE1
SIMATIC TDC
COMMUNICATION MODULE CP51M1
FOR INDUSTRIAL ETHERNET
WITH TCP/IP AND/OR UDP
6DD1662-0AB0
SIMADYN D
COMMUNICATION MODULE CS7
CARRIER MODULE FOR A MAXIMUM
OF 3 COMMUNICATION SUBMODULES
6DD1662-0AC0
SIMADYN D
COMMUNICATION SUPPORT MODULE
CS8 FOR UP TO PLUG-IN
COMMUNICATION MODULES
6DD1672-0AD0
SIMADYN D
PARALLEL PROGRAMMING UNIT PP1X
EXTERNAL PROGRAMMING UNIT
WITH POWER SUPPLY 110/230V
6DD1681-0EB3
SIMADYN D
BINARY INPUT MODULE SB61
GALVANIC ISOLATION24/48V , 8BI
24 or 48 V DC, LED-DISPLAY
6DD1681-0AG2
SIMADYN D
BINARY OUTPUT MODULE SB70
8 BO, MAX. 120V AC/DC,
LED-DISPLAY, GALVANIC ISOLATION
6DD1681-0GK0
SIMADYN D
CONVERTER SU13
50 TERMINALS (1:1 CONNECTION)
6DD1681-0BD1
SIMADYN D
ANALOG IN/OUTPUT MODULE SE13.1
PASSIVE SWITCHING
6DD1681-0DH1
SIMADYN D
BINARY OUTPUT MODULE SB71
8 BI, 24 or 48 V DC
6DD1681-0AJ1
SIMADYN D
CONVERTER SU12 10-POLE
10 SCREW-PLUGIN-TERMINALS
10-POLE PLUG
6DD1681-0EA1
SIMADYN D
CONVERTER SU11 20-POLE
20 SCREW-PLUGIN-TERMINALS
20-POLEPLUG
6DD1681-0AE1
SIMADYN D
INTERFACE MODULE SE4.1
8BI/BO,24V,LED
6DD1681-0AE2
SIMADYN D
BINARY INPUT or OUTPUT SB10
8 BI or 8 BO , 24V DC
LED DISPLAY
6DD1681-0CA2
SIMADYN D DIGITAL CONTR. SYSTEM
SITOR INTERFACE SE20.2
DIRECT COUPLING
FOR PG16 , PG26, PT20G
6DD1681-0CB2
INTERFACE MODULE SE21.2
SIMOVERT INTERFACE FOR PS16
6DD1681-0FG0
SIMADYN D
CONVERTER SU10 26-POLE
26 SCREW-PLUGIN-TERMINALS
26-POLE PLUG
6DD1681-0EA1
SIMADYN D
20-POLEPLUG
6DD1682-0CH0
SIMATIC TDC
SUBRACK UR5213
21 SLOTS
95 V - 255 V INPUT VOLTAGE
INTEGRATED FAN
FOR GDM
5-ROW FEMALE CONNECTOR
6DD1682-0CH2
SIMATIC TDC, SUBRACK UR5213
21 SLOTS,
95V - 255V INPUT VOLTAGE,
INTEGRATED FAN,
FOR GDM,
6DD1842-0AA1
SIMADYN D
T400 WITH AXIAL WINDER
INCLUDING SMALL DOCUMENTATION
GERMAN/ENGLISH
WITHOUT T400 AXIAL WINDER
USER MANUAL
6DD1842-0AD1
SIMADYN D
T400 WITH SHEET CUTTER/
CUT TO LENGTH (SPS450) REV.A
WITH BRIEF DESCRITION
AND USERMANUAL ON CD
6DD1682-0DA1
SIMATIC TDC
SLOT COVER SR51
6DD1682-0CE3
SIMADYN D
SUBRACK SR24.3
115/230V AC INTEGRATED FAN
24 SLOTS , L- AND C-BUS
6DD1683-0CH1
SIMATIC TDC
POWER SUPPLY (WITH FAN)
6DD1683-0CH0
SIMATIC TDC
POWER SUPPLY PS5213 WITH FAN
6DD1683-0CC0
SIMADYN D
POWER SUPPLY UNIT SP22
5V/25A, 15V, 24V DC INPUT
WITH FAN
6DD1683-0CD0
SIMADYN D
POWER SUPPLY UNIT SP23
6DD1683-0CC5
SIMADYN D
POWER SUPPLY UNIT SP22.5
5V/25A, 15V, 115/230 V AC INPUT
FAN
6DD1683-0BC0
SIMADYN D
POWER SUPPLY UNIT SP8
5V/52A, 15V, 24V DC INPUT
WITH FAN
6DD1683-0BC5
SIMADYN D,
POWER SUPPLY UNIT SP8.5
5V/52A, 15V, 115/230 V AC INPUT
FAN
6DD1684-0GC0
SIMATIC TDC
PLUGIN CABLE SC62
50-POLE SCREENED
6DD1684-0GH0
SIMATIC TDC
SERVICE CABLE SC67
10-POLE SCREENED
TO CONNECT TO THE
CPU-SERVICE-INTERFACE
6DD1684-0GD0
SIMATIC TDC
PLUGIN CABLE SC63
50-POLE SCREENED
6DD1684-0EK0
SIMADYN D
PLUGIN CABLE SC49
50-POLE2 X 26-POLE, L = 2M
DRILLED AND SCREENED
6DD1684-0FH0
SIMADYN D
SERVICE/INSTALL. CABLE SC57
PC TO PM4/PM5/PM6 or SS4
2 PARTS:
PART 1: L= 10M, 9 -  9 POLE
PART 2: L= 0.5M, 9 - 26 POLE
6DD1684-0FF0
SIMADYN D
RIBBON CABLE SC55
40-POLE 2 X 20-POLE , L = 2M
6DD1684-0GF0
SIMADYN D
SC400 START-UP CABLE
PC<-> T400 LENGTH: 7,5M
9-PIN. SUB-D F. PC-COM1/2
3-PIN. SCREW TERMINAL
CONNECTOR FOR T400
6DD1684-0FA0
SIMADYN D
PLUGIN CABLE SC50
15-POLE- 26-POLE , L=2M
6DD1684-0FB0
SIMADYN D
PLUGIN CABLE SC51
25-POLE - 26-POLE , L = 2M
DRILED AND SCREENED
6DD1684-0FE0
SIMADYN D
PLUGIN CABLE SC54
50-POLE , 5 X 10-POLE , L = 2M
6DD1684-0BH2
SIMADYN D
ROUND CABLE SC17.2
50-POLE, L=2M, SITOR INTERFACE
SHIELDED ,PG16,PG26,PT20G
SE20.2,SITOR
6DD1684-0BC0
SIMADYN D
RIBBON CABLE SC12
20-POLE, TWISTED, LENGTH=2M
6DD1688-1AB0
SIMADYN D
INTERFACE SUBMODULE SS2
SERIAL INBTERFACE V.24(EIA 232)
6DD1688-0AE0
SIMADYN D
COMMUNICATION SUBMODULE SS5
FOR CS7 MASTER INTERFACE FOR
BUS SYSTEM SINEC L2 FMS
6DD1688-0AE2
SIMADYN D
COMMUNICATION SUBMODULE SS52
FOR CS7 , MASTER INTERFACE FOR
BUS SYSTEM SINEC L2 DP
6DD1688-0AD0
SIMADYN D
COMMUNICATION SUBMODULE SS4
FOR CS7 , SIMADYN D PROTOCOLL
DUST 1,2,3,7
6DD1688-1AC1
SIMADYN D
NTERFACE SUBMODULE SS31 EIA 485
6DD1842-0AB1
SIMADYN D
T400 WITH ANGULAR SYNCHRONOUS
CONTROLLER
INCL. SMALL DOCUMENTATION
GERMAN/ENGLISH
WITHOUT T400
ANGULAR SYNCHRONOUS CONTROL
USER MANUAL
6DD1843-0AA0
SIMATIC AXIAL WINDER SPW420
V2.21, UNLOCK COPY LICENSE
R-SW, SW AND DOKU ON CD
CLASS A
2 LANGUAGES (G, E)
RUNS UNDER WIN95/98/ME/
NT/2000 IN CONNECTION WITH
STEP7, CFC, D7-SYS
REFERENCE-HARDWARE: T400
6DD2920-0AN1
EPIS22 PERIPH. DEVICES EP22/IS1
SIGNAL PROCESSOR EP22
WITH PLUGGED IS1
NMA: 460 692 9008 10
6DD2920-0AT1
KEIN TEXT VORHANDEN
6DD2920-0AV3
FIRING PULSE OUTPUT MODULE
促销6ES71384CA010AA0 促销6ES71513BA230AB0 促销6ES71511AA050AB0 特价6ES71384FA040AB0 6ES79720BA520XA0 促销6ES79720BB520XA0 促销6ES79720BB420XA0 促销6ES79720BA520XB0
