Product model/产品型号 |
TK-2401-PF-C-2.4 |
Dimensions/尺寸规格 |
10.1" |
Structural/结构 |
GG |
Drive form/驱动方式 |
COB |
Rati/比例 |
16:9 |
Lens OD/面板外形 |
421mm*346mm*1.1mm |
Lens VA/面板视窗 |
377.32mm*302.06mm |
Sensor OD/功能片外形 |
402.32mm*330.06mm*1.1mm |
Thickness/产品厚度 |
2.4mm |
Surface hardness/表面硬度 |
6H |
Transparency/透光度 |
>90% |
Operating temperature/工作温度 |
-30 ℃ ~ +75 ℃ |
Storage temperature/保存温度 |
-40 ℃ ~ +85 ℃ |
Relative Humidity/s湿度 |
90% at 60℃ |
Linearity/线性度 |
1PT:+/-1mm,10PT:+/-2.5mm |
Touch life/触摸寿命 |
> 300,000,000 times |
Max. Resolution/最大分辨率 |
4096×4096 (Automatic matching ) |
Max. Support Points/最大支持点数 |
Max,10 points |
Control Type/控制器类型 |
PCBA control board |
Connector Type 连接方式 |
USB |
Interface to Host/Master(主机接口) |
USB, 4 wire, 2.0 Full speed |
Supply Voltage/工作电压 |
USB 5VDC |
Power Consumption/功率消耗 |
Active Mode:<30mA,Idle Mode:5mA |
Oscillator Frequency/振荡频率 |
12MHz |
Response Time/反应时间 |
<10ms<> |
Min. Report Rate/读取速度 |
10PT: 80Hz |
Max. operating frequency/最大工作频率 |
100 MHz |
ESD.Air discharge/抗静电.空气放电 |
8KV |
ESD.Contact discharge/抗静电.接触放电 |
4KV |
Operating system/运行系统 |
Windows7、Windows8、Windows XP…… |
Adapter ripple /适配器纹波 |
Vpp<50mv<> |
