6FX1192-4AB00
6FX1192-4AB00
厦门岳航计算机工程有限公司
contact: 胡玲
Tel: +86-5 9 2-5 8 5 6 2 0 9 +86-1 8 0 3 0 2 3 5 3 1 1
Fax: +86-5 9 2-5 1 6 5 5 6 1(传真时请注明胡玲收,谢谢!)
QQ: 1 6 0 0 9 2 6 1 8 5
mail: 1 6 0 0 9 2 6 1 8 5 @qq.com
联系地址:厦门市思明区湖滨东路湖光大厦18楼B单元
MKS heated valve 100932500 HPS division, looks clean
MKS baratron 227AA, 1 TORR, +/- 15 VDC, used as is
MKS baratron 141AA, 10 Torr, used as is
NEW AMAT 0200-09273 RING INNER 100MM 94MM 2FLT 90 SHADO...
36 AMAT 0950-01459 IC Prom 150NS CMOS ERASABLE 57512
Stec PV-2000 PIEZO VALVE PV-2103MC
National instruments 6052E Multifunction 16 channel 16 ...
Industrial Control Equipment / Berkeley Process, MIO-OD...
Robitech 980-4825 8 Solenoid module PCB assy
NEW Keithly CTM-05 counter timer card PC6122, 14014
NEW Novellus A01-201-01 Housing shower head, 8 inch
Asyst 3200-1225-05 spartan 300l controller 70ns pop E84...
2 NEW Omega DP41-TC-AR/CE process controllers
New Vacuum Fitting Reducing Tee NW50, SST, lot's 3
2 AMAT 0040-51876 ARM, Hinge 300mm PC XT
2 new AMAT 0021-04475 BRACKET SENSOR MOUNTING, TICL4 TI...
ASYST Technologies 9701-1057-01 PCB Board, FAB 3000-120...
AMAT 0020-24572 Clamp ring, 6 inch, HLZ-180-010
AMAT 0020-26038 Clamp ring, 8 inch, REFLOW 10 Finger AC...
Novellus 02-125859-01 Assy, Emitter, wafer centering, w...
NEW AMAT 0020-47188 Membrane clamp internal, 300mm, 002...
MKS 1480A-27017 MFC Alta model digital Mass flow contro...
NEW AMAT 0021-00407 Collar Ring, Showerhead, 200mm doub...
AMAT 0620-02907 Cable DC Motor INTEGRA,12-9982?-008 Pitt...
Ametek 14232A127-R3 Pittman 9700-9102-01 Motor
NEW AMAT 1410-00030 HTR JKT Straight 208 VAC Foreline, ...
AMAT 0190-77197 BALL SCREW CROSS SWEEP 300MM.
BROOKS Mass Flow Controller 6256S, H2, 2SLM, used
