6FX1123-7AA02
6FX1123-7AA02
厦门岳航计算机工程有限公司
contact: 胡玲
Tel: +86-5 9 2-5 8 5 6 2 0 9 +86-1 8 0 3 0 2 3 5 3 1 1
Fax: +86-5 9 2-5 1 6 5 5 6 1(传真时请注明胡玲收,谢谢!)
QQ: 1 6 0 0 9 2 6 1 8 5
mail: 1 6 0 0 9 2 6 1 8 5 @qq.com
联系地址:厦门市思明区湖滨东路湖光大厦18楼B单元
Semitool 72056-23 SM312FPH 1000ML Fiber Optic Flowmeter...
Lufran AN3-3-5C Annunciator PCB with 5 possition displa...
25 ELPIDA 1 GB MEMORY, 1Rx8 PC3-8500R-7-10-?AP, 1Rx4 PC-...
NEW AMAT 3870-06006 Ham-Let UCV Series Diaphragm Valve
NEW Parker Veriflo Division valve 45800978-2, SMSQ2MICR...
NEW Berkeley Process controls M10, Servo motor cables 2...
Shindengen GY24010GN Switching power supplies Novellus ...
IPEC Speedfam 2805-739261 E, Pneumatic Assembly with Ma...
AMAT 0020-26588 PCII SHIELD
NEW AMAT 3870-01914 Fujikin Valve assembely FUDDFL-71-6...
Edwards high vacuum 600AB, 10 TORR
AMAT 0150-76560 Cable Assy, Devicenet Trunk, System AC,...
Berkeley Process controls MIO-A-4-602 ANALOG CURRENT, 4...
Millipore CDL-21S06 Capacitance manometer 100 torr
AMAT 3700-01426 ORING VITON 75DURO BROWN
AMAT 3700-02352 ORING CHEMRAZ SS513 80DURO WHITE
MKS Spectra, LM75 Resistorr, RGA controller module
2 NEW AMAT 0150-02338 cable assy. mainframe pneumatics
Square D, class 8910, type DPA93 DEFINITE CONTRACTOR
AMAT 0020-82809 PRE-MRS SLIT
LAM 715-011913-501 PL BAF LWR 8.3" Meltron
AMAT 0190-04984 Upper Chamber Hose
Aptech AP1002S 3PW FV4 MV4L Single Stage Regulator
2 AMAT 1410-00031 HTR JKT BEL 208VAC FORELINE 0050-4642...
new AMAT 0021-01646 producer latch, safety, MW clean li...
AMAT 0010-34912, 300MM, CMP, Sensor, Gauge
Asyst technologies 9700-6682-01 Pittman Motor, POD, Adv...
AMAT 3850-01422 Rough Valve, 0966-36743
NEW AMAT 0630-01396 Capacitor, 800PF, 14KVP
AMAT 0150-02890 C/A EMC COMP HEAT EXCHANGER 100FT CSI
Lot of 2 Honeywell LD2P4LVV100M Flow Display and contro...
AMAT P5000 CVD chamber LID cover plate
StarrettNo 812-1 Deflection probe with Feinpruf 1318 pr...
Unit UFC-1100A MFC, 5SLM NH3
Unit UFC-1100A MFC, 5SLM N2
Accufiber M310-4915 Endpoint detector
Unit UFC-1100A MFC, 1SLM N2
ThermX 202AJF08 12 channel temperature display switch b...
Bourns 3862C282503A 1 box of 50 potentiometers, 50kohm,...
AMAT 1350-00492 Setra 2231025PABW2CD1?M Pressure Transdu...
AMAT 0020-75092 CLAMP VIEWPORT WC CHAMBER
Oriental Motor 4TK10CGN-A, Lintec 11007-003 Torque Moto...
NEW AMAT 3800-00463 Pressure Regulator, 4 VCR Female IN...
NEW Veriflo 42600719 Pnumatic diphram valve, 944AOPLPNC...
Engeldhard-CLAL 700230 Type R, Dual TC Probe with Ceram...
NEW Veriflo division valve 45901222, 930AOPLPNCS6785
AMAT 0030-76062 Bezel Monitor 15 in. TTW UL94V-0
GE TED134050WL Industrial circuit beaker, 480V 50A
2 Unit MFC, UFM-9150 He, 6 SLM and 3 SLM
NEW Varian 08290001 Filament preamp PCB assy, 08290-001
MKS 151-0025K KF25 angle mnual vacuum isolation valve
NEW Parker Veriflo Division valve 45800491, 945AOPLPNCS...
