SYMBOL LS6804I400A
SYMBOL LS6804I400A
厦门岳航计算机工程有限公司
contact: 胡玲
Tel: +86-5 9 2-5 8 5 6 2 0 9 +86-1 8 0 3 0 2 3 5 3 1 1
Fax: +86-5 9 2-5 1 6 5 5 6 1(传真时请注明胡玲收,谢谢!)
QQ: 1 6 0 0 9 2 6 1 8 5
mail: 1 6 0 0 9 2 6 1 8 5 @qq.com
联系地址:厦门市思明区湖滨东路湖光大厦18楼B单元
EFI Electronics MBP120/208Y Linemaster MBP, multiphase ...
NEW AMAT 1350-00490, Setra 2231100PAEB2CD1?M Pressure Tr...
NEW AMAT 3870-04028 HAM-LET UCV, HM20-4VKLC-GF4 diaphra...
5 AMAT 1270-00389 SW Upper Limit
NEW Veriflo division valve 35700182, 930AOPLPNCSC111
NEW AMAT 0010-02532 water return hose W/SST flare FTGS ...
2 new AMAT 0140-77480 cable, robot, DC, K17 TO
Ceramic Ring 4002-7033-01
IPEC Speedfam 372M-46087-1 Shuttle Force Sensor Pneumat...
CTI OnBoard P300 control module 190-27354
Clippard Dual 3-Way R355 CMS-855
Water cooled feed through with insulated connector and ...
8 new AMAT 0021-10773 ground strap, chiller plate
AMAT 0270-70043 Alignment fixture
USED HUNTINGTION ISOLATION VALVE PV-150-SF
STEC SEC 7350 20SLM N2 MODEL SEF-7350M, used
7 SMC SZ3A60-5NL0Z-C4 Valve Bank
Copley Controls Corp. 800-1570 Amplifier Data Sheet
AMAT 0190-08418 Harness, Port Plate Sensor
3 SMC VQD1151W-6L0 Solenoid Valve
4 SMC SV1A00-5FU Solenoid Valve EX150 DeviceNet
AMAT 0090-01534 Sensor Assy, Mask Present, Photomask
14 SMC SV1200-5FU-X7 Solenoid Valve
24 SMC NVJ114Y Valve Solenoid
NEW Fujikin AMAT 3870-01881 Pneumatic bellows valve N?C...
8 SMC VQ1200NY-5-X35 Supply Voltages EX160-SDN1A Soleno...
Pittman servo motors , Ametek 9700-7165-01, 24 VDC, 923...
AMAT 0100-09736 PWBA, WB, Slotted Opto
