1.PPS BIR-026903 6PCS
2.CAL/SIG BGR-026746 4PCS
3.DR PE板BIR-026805 16PCS
4.I/O PE板BIR-026804 16PCS
UPS电源 (5种型号)
WUN-2R5V5VW
WUN-9V11VW
WUN-5V7VW
WUN-5V18VW
WUN-2R5V5VW
Amber CRT Advantest R3261 R3261A R3261C R3361A R3361C
ADVANTEST ACUARTOR, ROTARY FESTO DSR-25-180-P
Advantest Q8344A Optical Spectrum Analyzer 350nm-1750nm
Michelson Interferometer, Maximum resolution of 0.05nm
Advantest R6161 DC Voltage / Current Generator
Advantest 5365 Advantest 5571 and other tester parts
Advantest R6452E Digital Multimeter
Advantest R6452A Digital Multimeter
ADVANTEST Q7750 /10 1525nm-1635nm Optscope (Network Analyzer)
Advantest Q8163 Optical Polarization Scrammbler
New AMBER CRT for R4131D Advantest Spectrum Analyzer
Advantest Model D3286 Error Detector 12Gb/s. Tektronix D3286
ADVANTEST Q7606B 1510-1590nm 100Hz-50GHz Optical Chirp Test set
ADVANTEST R3162 SPECTRUM ANALYZER 9KHz-8GHz
CRT Advantest R3271 R3271A R3265 R3265A R3365A R9211
Advantest R3267 Spectrum Analyzer 100Hz - 8GHz
ADVANTEST Q8163 1290-1580nm Polalization Scrambler
Advantest R3964A 3 Port Adapter for R3765C
Advantest Optical Power Meter TQ8215 + Q82021A
New CRT for TR4131 TR4131E Advantest Spectrum Analyzer
Advantest R3131 Spectrum Analyzer Operation Manual
Advantest Extender Board BGS-026818
Advantest T5771ES-Flash Memory Tester
Advantest D3186 & D3286 Pulse Pattern Generator / Error Detector
UNIT TESTED & FULLY FUNCTIONAL. OPTION 70 INSTALLED!
Advantest D3371 Pulse Pattern Generator and Bit Error Detector 3.6GHz
Advantest D3286 Error Detector Opt 10 / 70 12.5 Gb
Advantest-H7-0?761X01 Tester Head
ADVANTEST TR-8601 High Megohm Meter
Advantest D3186 Pulse Pattern Generator Opt 10 / 70
Advantest R6740B Power Source
ADVANTEST R6441A DIGITAL MULTIMETER
ADVANTEST U3661 MAINTENANCE MANUAL
ADVANTEST R4136 INSTRUCTION MANUAL
Advantest R4131B 10kHz - 3.5GHz Spectrum Analyzer
ADVANTEST R3541C Modulation Accuracy Measurement Unit
ADVANTEST 5361 / SHINDENGEN BX05450 5VDC 450A NEW boxd
Advantest OTDR TQ8450 Analyzer
上海泰思电子专业生产、研发、销售触摸屏,led显示屏,触摸查询一体机,触摸显示器。开发触摸查询软件,还提供电阻、电容、红外线、声波等各种触摸屏。触摸屏,触摸显示器,触摸屏一体机,大屏幕液晶触摸屏,等离子触摸屏, 原装液晶触摸屏显示器,触摸屏点菜点歌终端,排队机,开发各行业多媒体触摸查询软件及定制机柜. 4线,5线,6线,7线,8触摸屏
