本公优惠供应TOUCH SCREEN MODULE中的各种材料,包括触控IC,SENSING IC,ITO SENSOR,COAXIAL CONNECTOR,WINDOW SCREEN,DIODE-TVS,MOS FET,Transistor,IC-ANALOG SWITCH,CMOS HALL IC,IC-DC/DC CONVERTER,BEAD-SMD,CHIP BEAD等各种材料。
| ITEM | PART NUMBER | MAKER | Stock |
| RECEIVER | KR-1207H-01 | kilin telecom | 3,600 |
| COAXIAL CONNECTOR | W.FL-R-SMT-1 | Hirose | 5,000 |
| CONNECTOR-SOCKET | 30P,2R,0.4MM,SMD-S,A | Panasonic | 170 |
| JOG SWITCH | EVQWKP005 | Panasonic | 7,330 |
| ITO Sensor | KBGTI5801KTL | Nissha | 16,847 |
| WINDOW SCREEN | KBGTI5801KTL | BIE | 17,276 |
| WINDOW SCREEN | KBSHWA220KTLKT | BIEL | 18,000 |
| WINDOW SCREEN | KBSHWA220KTLBEKT | BIEL | 11,107 |
| DIODE-ZENER | KDZ2.0EV | KEC | 1,605 |
| DIODE | GMF05LC-HS3 | VISHAY | 1,152 |
| TVS DIODE | RSB6.8CS | ROHM | 8,000 |
| DIODE-TVS | uClamp0501P,ESD DIOD | SEMTECH | 30,000 |
| ESD Protector | PESD0603-240(1608,) | RAYCHEM | 2,881 |
| MOS FET | Si1016X | RICHWOOD | 9,000 |
| TR-SMALL SIGNAL | KRC402V | KEC | 3,758 |
| Transistor | SST3906,ROHM社 | ROHM | 2,097 |
| LED | SSC-TWH104HE | SEOUL SEMICONDUCTOR | 2,515 |
| IC-ANALOG SWITCH | FXL4T245BQX | Fairchild Semiconductor | 9,000 |
| CMOS HALL IC | US4881ESO | MELEXIS | 27,280 |
| SENSING IC | SO281000-24QFN-01 | SYNAPTICS | 30,000 |
| SENSING IC | SO381000-24QFN | SYNAPTICS | 8,000 |
| SENSING IC | SO340010-16QFN-01 | SYNAPTICS | 5,924 |
| IC-HALL EFFECT S/W | EM-1681-FT,SOT,4P,2. | ADCHIPS | 2,229 |
| IC-DC/DC CONVERTER | LM2733XMFX,SOT-23,5P | ARROW | 6,000 |
| INDUCTOR-SMD | 10uH,10%,3225 | MURATA | 1,000 |
| RESONATOR | CSTCR6M00G53 | MURATA | 2,122 |
| MICRO SPEAKER | BMS-151101SL08,SCHV7 | BLUECOM | 14 |
| AUDIO-RECEIVER | SBR110627P-CW01,SCHY | BLUECOM | 4 |
| BEAD-SMD | CIM05J152NC | SAMSUNG | 5,084 |
| CHIP BEAD | BLM15AG121SN1D(MMZ1005Y121CT000) | MURATA | 20,000 |
| BEAD-SMD | BLM15HG102SN1D,1005,1000ohm | MURATA | 50,000 |
| CHIP BEAD(BLM03AG241SN1D) | (BLM03AG241SN1D) | MURATA | 15,000 |
| BEAD-SMD | 120OHM,1.0X0.5X0.5MM,MMZ1005Y121CT000 | TDK | 10,000 |
| BEAD-SMD | BLM15HD102SN1 | MURATA | 70,000 |
| SWITCH | SKRWAFE030 | ALPS | 8,509 |
| SWITCH | SWITCH,EVPAHBC6A | Panasonic | 200 |
| SWITCH | SKQGABE010 | ALPS | 5,531 |
| ITO SENSOR | KBGTS3650KTL | Nissha | 23 |
| WINDOW SCREEN | KBGTI5801KTL | BIEL | 39,464 |
| WINDOW SCREEN | KBGTI5800KWKTL | BIEL | 7,041 |
