询价联系人:陈雨
询价热线: 0713-6542758,13476570100 /15072726572
询价QQ: 2593165857, 2982072083
欢迎您的来电!
传真:0713-6542758价供应 德国力士乐 PPV系列叶片泵
PVV2-1X/040RA15DMB PVV2-1X/045RA15DMB
PVV2-1X/055RA15DMB PVV2-1X/060RA15DMB
PVV2-1X/068RA15DMB PVV4-1X/069RA15DMB
PVV4-1X/082RA15DMB PVV4-1X/098RA15DMB
PVV4-1X/113RA15DMB PVV4-1X/122RA15DMB
PVV5-1X/139RA15DMB PVV5-1X/154RA15DMB
PVV5-1X/162RA15DMB PVV5-1X/183RA15DMB
PVV5-1X/193RA15DMB PVV5-1X/193RA15DMC
PVV21-1X/060-040RA15DDMB PVV21-1X/068-027RA15LUMB
PVV41-1X/098-027RA15UDMC PVV41-1X/122-036RA15DDMC
PVV42-1X/098-045RA15DDMC PVV21-1X/068-027RA15LUMB
PVV51-1X/162-036RB15DDMC PVV51-1X/193-027RA15DDMC
PVV52-1X/193-040RB15URMC PVV52-1X/193-055RB15UUMC
PVV54-1X/183-082RA15DDMC PVV54-1X/139-082RA15UUMC
PVV52-1X/139-068RA15DLMC PVV5-1X/193RA15LMC
PVV54-1X/139-069RA15UUMC PVV2-1X/068RJ15UMB
PVV4-1X/113RJ15UMC PVV1-1X/027LA15LMB
PVV42-1X/082-045RA15DDMC PVV1-1X/027RJ15DVB
PVV54-1X/162-082RB15UUMC PVV41-1X/082-018RA15RRVC
PVV41-1X/082-046RA15UUMC PVV51-1X/139-027RA15DLMC
PVV52-1X/139-068RA15DLMC PVV21-1X/040-018RB15UDMB
PVV5-1X/154RJ15DVC PVV21-1X/055-018RA15UUVB
PVV5-1X/193RA15LMC PVV4-1X/122RA15RMC
PVV54-1X/154-113RJ15UUMC PVV21-1X/045-027RJ15UUMB
PVV21-1X/068-027RA15URMB PVV51-1X/154-027RA15RRVC
PVV54-1X/193-122RA15UUVC PVV54-1X/193-113RA15UUVC
PVV1-1X/046RA15DVB PVV41-1X/082-036RA15LLMC
PVV2-1X/060RA15LMB PVV54-1X/193-082RA15DDMC
PVV52-1X/154-055RA15UUMC PVV42-1X/082-068RA15UUMC
PVV54-1X/183-122RB15DDMC PVV54-1X/139-098RB15DDMC
PVV52-1X/162-055RB15DDMC PVV52-1X/154-068RB15DDMC
叶片泵 PVV2-1X/040RA15DMB
叶片泵 PVV2-1X/045RA15DMB
叶片泵 PVV2-1X/055RA15DMB
叶片泵 PVV2-1X/060RA15DMB
叶片泵 PVV2-1X/068RA15DMB
叶片泵 PVV4-1X/069RA15DMB
叶片泵 PVV4-1X/082RA15DMB
叶片泵 PVV4-1X/098RA15DMB
叶片泵 PVV4-1X/113RA15DMB
叶片泵 PVV4-1X/122RA15DMB
叶片泵 PVV5-1X/139RA15DMB
叶片泵 PVV5-1X/154RA15DMB
叶片泵 PVV5-1X/162RA15DMB
叶片泵 PVV5-1X/183RA15DMB
叶片泵 PVV5-1X/193RA15DMB
DR15G-4-5X/200YM
力士乐阀
DBW10B1-52/100-6EG24N9K4
DBW10B1-52/200-6EG24N9K4
DBW10B1-52/315-6EG24N9K4
DBW20B1-52/100-6EG24N9K4
DBW20B1-52/200-6EG24N9K4
DBW20B1-52/315-6EG24N9K4
DBW20A2-52/200U6EG24N9K4
DBW10B7-52/315S6EG24N9K4
DBW20B1-52/100-6EW230N9K4
DBW20B2-52/350-6EG24N9K4
DBW20B2-52/315S6EG24N9K4
DBW10B2-52/315S6EG24N9K4
DBW10B2-52/315-6EG24N9K4
DBW20B2-52/200-6EW110N9K4
DBW10B2-52/100-6EG24N9K4
DBW30BG2-52/315-6EG24N9K4
DBW30B1-52/315-6EW230N9K4
一种液压压力控制阀。在液压设备
中主要起定压溢流作用,稳压,
系统卸荷和安全保护作用。
定压溢流作用:在定量泵节
流调节系统中,定量泵提供的
是恒定流量。当系统压力增大时,
会使流量需求减小。此时溢流阀开启,
使多余流量溢回油箱,保证溢流阀进口压力,
即泵出口压力恒定(阀口常随压力波动开启)。
稳压作用:溢流阀串联在回油路上,溢流阀产生背压,
运动部件平稳性增加。系统卸荷作用:在溢流阀的
遥控口串接溢小流量的电磁阀,当电磁铁通电时,
溢流阀的遥控口通油箱,此时液压泵卸荷。
溢流阀此时作为卸荷阀使用。安全保护作用:
系统正常工作时,阀门关闭。
只有负载超过规定的极限(系统压力超过调定压力)时开启溢流,
进行过载保护,使系统压力不再增加
(通常使溢流阀的调定压力比系统最高工作压力高10%~20%)。
实际应用中一般有:作卸荷阀用,作远程调压阀,
作高低压多级控制阀,作顺序阀,用于产生背压(串在回油路上)。
溢流阀一般有两种结构:1、直动型溢流阀 。2、先导式溢流阀。
对溢流阀的主要要求:调压范围大,调压偏差小,压力振摆小,
动作灵敏,过载能力大,噪声小。
DBW20B2-52/315-6EG24N9K4
DBW30B2-52/350-6EG24N9K4
DBW10B3-52/315-6EG24N9K4
DBW20B2-52/315-6EW230N9K4
DBW10B2-52/315-6EW230N9K4
DBW10B2-52/200-6EW230N9K4
DBW20B2-52/200-6EG24N9K4
DBW10B2-52/200-6EG24N9K4
DBW10A3-52/315-6EG24N9K4
DBW20A2-52/350-6EG24N9K4
DBW20BG2-52/315-6EG24N9K4
DBW20A2-52/315-6EW230N9K4
DBW20B2-52/315U6EG24N9K4
DBW10B2-52/100U6EG24N9K4
DBW10B2-52/315-6EG24N9K4V
DBEE6-12/100YG24K31M
DBW20A2-52/100-6EG24N9K4
DBW30B2-52/315-6EG24N9K4
DBW10A2-52/350-6EG24N9K4V
DB20-2-52/2002V
DBW20B2-52/100-6EW230N9K4
DBW20A2-52/315-6EG24N9K4
DBEM30-32/200YG24K4M
DBW30A2-52/315-6EG24N9K4
DBW20B2-52/350S6EG24N9K4
DBW20B2-52/100-6EG24N9K4
DBW30B2-52/100-6EG24N9K4
DBW30B2-52/100-6EW230N9K4
DBW30B1-52/200-6EG24N9K4
DBW10B3-52/315S6EG24N9K4
DBEM10-52/200YG24K4M
DBEM20-52/200YG24K4M
DBEM20-52/315YG24K4M
DBW20B1-52/315-6EW110N9K4
DBW20B1-52/315-6EW230N9K4
DBWCB2-52/100-6EG24N9K4
DBW10B2-52/350-6EG24N9K4
DBW10A2-52/315-6EG24N9K4
DBW10A2-52/200-6EG24N9K4
DBW10B2-52/200-6EG110N9K4
DBW20A2-52/315S6EG24N9K4
DBW30BG2-52/100-6EG24N9K4
DBW20B3-52/315-6EG24N9K4
DBW10B2-52/200U6EG24N9K4
DBW20BG2-52/200-6EG24N9K4
DBW10A3-52/200-6EG24N9K4
DBW10B2-52/315U6EG24N9K4
DBW30A3-52/315-6EG24N9K4
DBDS20G12/25-20
DW10B1-52/315-6EW230N9K4
DBW30A2-52/315-6EW230N9K4
DBW10BG2-42/200-6EG48N9K4
DBW20A2-52/200-6EG24N9K4
DBW20A1-52/315-6EG24N9K4
DBW10A1-52/200-6EG24N9K4
DBW20A1-52/200-6EG24N9K
DBW10B2-52/100S6EG24N9K4
DBW30B2-52/100U6EG24N9K4
DBW30A2-52/350-6EG24N9K4V
DBW30A2N52/315-6EG24N9K4
DBW20B2-52/350-6EW230N9K4
DBW20A2-52/315-6EG24N9K4V
DBW30B2-52/100U6EG110N9K4
DBW20A2-52/350S6EG24N9K4
DBW30B2-52/3152U6EG24N9K4
DBW30B2-52/350S6EG24N9K4
DBE10-52/50YG24K4M
DBW20B2-52/100-6EG110N9K4
BW20B2-52/200-6EG110N9K4
DB3U30E2-52/315-6EG24N9K4
DBW30A1-52/200-6EG24N9K4
DBW20B2-52/350YS6EG24N9K4
DBW10A2-52/315-6EG24N9K4V
DBW10A1-52/315-6EG24N9K4
DBW20A2-52/315U6EG24N9K4
DBW10B7-52/315-6EG24N9K4
DBW30A2-52/315U6EG24N9K4
DBW20B2-52/100YU6EG24N9K4
DB30-2N52/350
DBW20B2-52/200U6EG24N9K4
DB30-2N52/315
DBW10B2-52/350U6EG24N9K4
DBW30B2-52/100-6EG110N9K4
DBAW40BF1N12/150S6EG24N9K4
DBW10A1-52/315U6EG24N9K4
DBW20B1-52/200U6EG24N9K4
DBW20B7-52/315U6EG24N9K4
DBW30A2N52/315YS6EG24N9K4
DB3U30H2-52/315YU6EG24N9K4
DBW30A2N52/350S6EG24N9K4
DB30-1N52/200
DB30-2N52/200YU
DBW30A2N52/350-6EG24N9K4
DBW10B2-52/200U6EG110N9K4
DBW20AG7-52/315-6EG24N9K4
DBAW30BH1N12/200-6EG24N9K4
DBAW15BH2-22/200-170-6EG24N9K4
DBW20A2-52/200YS6EG24N9K4
DBW20A2-52/31526EG110N9K4
DBWTA2-52/100-6EG24N9K4
DBW20B7-52/315S6EG24N9K4
DBW20A7-52/315-6EG24N9K4
DBW52AP1-32/100U6EW230N9K4
DBW20A1-52/350U6EG24N9K4
DB30-1N52/2002U
一种液压压力控制阀。
在液压设备中主要起定压溢流作用,
稳压,系统卸荷和安全保护作用。
定压溢流作用:在定量泵节流调节系统中,
定量泵提供的是恒定流量。当系统压力增大时,会使流量需求减小。此时溢流阀开启,
稳压作用:溢流阀串联在回油路上,
溢流阀产生背压,运动部件平稳性增加。
系统卸荷作用:在溢流阀的遥控口串接溢
小流量的电磁阀,当电磁铁通电时,溢流阀的
遥控口通油箱,此时液压泵卸荷。溢流阀此时
作为卸荷阀使用。安全保护作用:系统正常工作时,阀门关闭。只有负载超过规定的极限
(系统压力超过调定压力)时开启溢流,
进行过载保护,使系统压力不再增加
(通常使溢流阀的调定压力比系统
最高工作压力高10%~20%)。实际应用中一般有:
作卸荷阀用,作远程调压阀,
作高低压多级控制阀,作顺序阀,
用于产生背压(串在回油路上)。
对溢流阀的主要要求:调压范围大,调压偏差小,压力振摆小,动作灵敏,过载能力大,噪声小。
DBW30A1-52/350U6EG24N9K4
DBW30A1-52/315S6EG24N9K4
DBW30B2-52/315YU6EG24N9K4
DB20-2-52/502V
DB20-7-52/502V
DB20-7-52/2002V
DBDS6K11/315
DBDS10K10/400
DBDS10G11/200
DBDS20K11/200
DBDS20K11/50
DBDS10K11/315
DBDS10K18/25
DBDS6K11/100
DBDS10P11/400
DBDS6K11/315
DBDS10K11/315
DBDS10P11/200
DBDS6K1211/100
DBDS10P11/200
DBDS10K18/25
DBDS10P11/200
DBDS10K18/25
DBDS20P10
DBDS10P11/200
DBDS10G12/200
DBDS20K11/50
DBDS6K18/315
DBDS6P18/315
DBDS20P11/315
DBDS10P18/315
DBDS6P11/315
DBDH10P11/200
DBDS10G11/200V
DBDS10G11/25
DBDS10K10/200
DBDS10K11/315,
DBDS10K18/315
DBDS20G11/315V
DBDS20K11/200
DBDS20K18/315
DBDS20P10/315
DBDS10P11/315
DBDS10K11/400
DBDS10K11/400
DBDS10G18/200
DBDH10G10/200
DBDS20K11/315
DBDS10K11/315
DBDS10K11/100
DBDS6K10/100
DBDS6K11/100
DBDS10K11/315
DBDS10K11/315
DBDS6K18/100
DBDS6K11/100
DBDS20P11/250
DBDS10K11/315
DBDS10K18/25
DBDS6K11/100
DBDS6K11/100
DBDS6G10/400
DBDS10P11/200
DBDS6K10/100
DBDS10G11/200
DBDS10P11/200
DBDS10K18/25
DN10DBDS10K10/315
DBDS6K11/315
DBDS10P11/200
DBDS6K1211/100
DBDS10P11/200
DBDS10K18/25
DBDS6P11/ 315
DBDS10P11/200
DBDS10K18/25
DBDS10P11/200
DBDS6K1211/100
DBDS10P11/200
DBDS10K18/25
DBDS10P11/200
DBDS10K18/25
DN10DBDS10K10/315
DBDS6K11/315
DBDH10P18/400
DBDH6P11/315
DBDS30G11/315
DBDS10P11/200
DBDS6G11/315,
DBDS10K11/315
DBDS20K11/315
一种液压压力控制阀。在液压设备中主要
起定压溢流作用,稳压,系统卸荷和安全
保护作用。定压溢流作用:在定量泵节流
调节系统中,定量泵提供的是恒定流量。
当系统压力增大时,会使流量需求减小。
此时溢流阀开启,使多余流量溢回油箱,
保证溢流阀进口压力,即泵出口压力恒定
(阀口常随压力波动开启)。稳压作用:
溢流阀串联在回油路上,溢流阀产生背压,
运动部件平稳性增加。系统卸荷作用:
在溢流阀的遥控口串接溢小流量的电磁阀,
当电磁铁通电时,溢流阀的遥控口通油箱,
此时液压泵卸荷。溢流阀此时作为卸荷阀使用。
时开启溢流,进行过载保护,使系统压力不再增加
(通常使溢流阀的调定压力比系统最高工作压力高10%~20%)。实际应用中一般有:作卸荷阀用,作远程调压阀,
DBDS20P18/200
DBDS20P10
DBDS30P18/200V,DBDS30K18/315V
DBDS30K18/315
DBDS30K18/25,DBDS25G18/315
DBDA20P18/25
DBDA20G18/25
DBDA20K18/100
DBDA20K18/25V
DBDH20K18/50
DBDA15G18/25
DBDA10P18/
DBDA10G18/630V
DBDA10G18/25V
DBDA10K18/400
DBDH10P18/50V
DBDH10G18/315V
DBDS10P18/25V
DBDS10K18/315V
DBDA6P18/25
DBDA6G18/315V
DBDS6P18/200V
DBDS6G18/315
DBDH25G18/50
博世Rexroth力士乐3DREP6型三通减压阀简介:
由比例电磁铁直接驱动,将输入的电信号按比例地转
化成压力输出信号.比例电磁铁是带中心螺纹和
可更换线圈的湿式可控直流电磁铁,电磁铁可通过外部
电控器(3DREP型)和集成电控器(3DREPE型)精细控制.
博世Rexroth力士乐电磁换向阀
4WE6D62/EG24N9K4,4WE6Y62/EG24N9K4,4WE6C62/EG24N9K4,4WE6A62/EG24N9K4,4WE6B62/EG24N9K4,4WE6J62/EG24N9K4,4WE6E62/EG24N9K4,4WE6M62/EG24N9K4,4WE6H62/EG24N9K4,4WE6HA62/EG24N9K4,4WE6G62/EG24N9K4,4WE6U62/EG24N9K5,4WE6L62/EG24N9K6,4WE10Y33/CG24N9K4,4WE10D33/CG24N9K4,4WE10C33/CG24N9K4,4WE10L33/CG24N9K4,4WE10U33/CG24N9K4,4WE10J33/CG24N9K4,4WE10E33/CG24N9K4,4WE10G33/CG24N9K4,4WE10H33/CG24N9K4,4WE6D62/EW230N9K4,4WE6Y62/EW230N9K4,4WE6J62/EW230N9K4,4WE6E62/EW230N9K4,4WE6G62/EW230N9K4,4WE6G62/EW110N9K4,4WE10D33/CW230N9K4,4WE10E33/CW230N9K4,4WE10J33/CW230N9K4,4WE10H33/CW230N9K4,4WE10G33/CW230N9K4,Z2S16-1-51,FD12FB21/200B03V,4WE10LB33/CG24N9K4,DR10DP2-43/75Y,DB10-2-52/100,4WE6J62/EG24N9K4,M-3SEW6U36/420WG24,3DREPE6C-20/25EG24K31/AOM,H-4WEH32J63/6EG24N9ETS2K4,
4WE6J6O/SG24N9K4,Z2S10A-3XR900407424,4WE6J53AG2,5-4WE10D33/CG24K4QMBG24,H-4WMM22T-7X/F,M-3SEW10C14/420MG24N9K4,4WE6J62/EG24N9K4,DR15G-4-5X/200YM,LC25A10E-7X,SL20PA1-4X,DB10-3-52-/315,SL10PA1-4X/,Z1S6C-1-3X,4WE6Y6X/EG24N9K4,HED80H1X/200K14 ,LC40DB20E-7X ,A10VSO140DR/31R-PPB12N00,DBW20B1/315-6AW220-50NI4,SV20PA3-4X,4WEH16E7X/6EG24N9ETK4,DR20-5-5X/315YM,4WE10E3X/CG24N9K4,Z2FS10-3X,DB10-1-5X/200,4WE10G3X/CG24N9K4,DBW10B-2-5X/315G24N9K4,
R901089244 3WE6A73/HG24N9K4
R900561272 4WE6C62/EG24N0K4
R901089245 4WE6C72/HG24N0K4
R900908590 4WE6D62/EG24N9K4/B12
R900916984 4WE6D62/EG220N9K4
R900574632 4WE6D62/EG24K4QMBG24
R900567512 4WE6D62/EG24N9K4
R901087088 4WE6D73/HG24N9K4
R900561278 4WE6E62/EG24N9K4
R901108712 4WE6E70/HG24N9K4
R900561282 4WE6G62/EG24N9K4
R900561284 4WE6GA62/EG24N9K4
R900561286 4WE6H62/EG24N9K4
R900549534 4WE6HA62/EG24N9K4
R900561288 4WE6J60/EG24N9K4
R901089241 4WE6J73/HG24N9K4
R901108702 4WE6JA73/HG24N9K4
R900901751 4WE6L62/EG24N9K3
R900577475 4WE6M60/EG24N9K4
R900906825 4WE6M60/EG24N9K3
R900572785 4WE6U60/EG24N9K4
R900578186 4WE6UA62/EG24N9K4
R900922335 4WE6Y62/EG220N9K4
R900561276 4WE6Y62/EG24N9K4
R901089243 4WE6Y73/HG24N9K4
R900593277 4WE10C33/CG24N9K4
R900912737 4WE10D33/CG24K4QMBG24
R900589933 4WE10D33/CG24N9K4
R900588201 4WE10E33/CG24N9K4
R900595532 4WE10EA33/CG24N9K4
R900594277 4WE10G33/CG24N9K4
R900597986 4WE10H33/CG24N9K4
R900589988 4WE10J33/CG24N9K4
R900599646 4WE10L33/CG24N9K4
换向阀是具有两种以上流动形式和两个以上
油口的方向控制阀。是实现液压油流的沟通、
切断和换向,以及压力卸载和顺序动作控制的阀门。
可分为手动换向阀、电磁换向阀、电液换向阀等。
又称克里斯阀,阀门的一种,具有多向可调的通道,可适时改变流体流向。
工作时借着阀外的驱动传动机构转动驱动轴,带动摇拐臂,启动阀板,
使工作流体时而从左入口通向阀的下部出口,时而从右入口变换通向下部出口,
实现了周期变换流向的目的。这种变换阀在石油、化工生产中有着广泛的应用,
在合成氨造气系统中最为常用。此外,换向阀还可作成阀瓣式的结构,
多用于较小流量的场合。工作时只需转动手轮通过阀瓣来变换工作流体的流向。
R900500716 4WE10P33/CG24N9K4
R900595531 4WE10U33/CG24N9K4
R900926575 4WEH10D43/6EG24NETK4
R901108817 4WEH16C73/6HG24NETK4
R901108813 4WEH16D73/6SG24NETK4/B10
R901108754 4WEH16E73/6HG24N9ETK4
R900923971 4WEH16E73/6SG24NETK4/B10
R900728689 4WEH16EA73/6SG24NETK4/B10
R901051498 4WEH16J73/6EG24N9ETK4/B10
R901108808 4WEH16J73/6HG24NETK4/B10
R901108814 4WEH16L73/6HG24NETK4/B10
R901108848 4WEH16L73/6SG24NETK4
R901108753 4WEH16U73/6HG24NETK4/B10
R901108752 4WEH16Y73/6HG24NETK4
R901118416 4WEH22C73/6EG24NK4
R900979181 4WEH22C73/6EG24NK4/11
R901066895 4WEH22C73/6EG24NETK4/B10P4,5
R900968722 4WEH22C73/6EG24NETS2K4/B10P4,5
R900754997 4WEH22C73/6EG24NTK4
R900930928 4WEH22C73/6EG24N9K4
R900978153 4WEH22C73/6EG24N9K4/V
R900956841 4WEH22C73/6EG24N9K4/B08
R901224203 4WEH22C73/6EG24N9K4/P4,5
R901160435 4WEH22C73/6EG24N9K4QMBG24
R901012097 4WEH22C73/6EG24N9SK4
R900944266 4WEH22C73/6EG24N9SK4/V
R900787284 4WEH22C73/6EG24N9SK4/B10
R900926834 4WEH22C73/6EG24N9S2K4
R900787285 4WEH22C73/6EG24N9S2K4/B10
R900616539 4WEH22C73/6EG24N9EK4/B10P4,5
R901250026 4WEH22C73/6EG24N9ESK4/B10P4,5
R900778363 4WEH22C73/6EG24N9ES2K4/B10P4,5D3
R901095289 4WEH22C73/6EG24N9ETK4/B10P4,5
R900918616 4WEH22C73/6EG24N9TK4
R901091351 4WEH22C73/6EG24N9TK4QMBG24
R901084830 4WEH22C73/6EG24N9TSK4
R900731078 4WEH22C73/6EG24N9TS2K4
R900933334 4WEH22C73/6EW230N9K4
R900927603 4WEH22C73/6EW230N9SK4
R900734068 4WEH22C73/6EW230N9S2K4
R901129176 4WEH22C73/6EW230N9ETK4/B10P4,5
R901215488 4WEH22C73/6EW230N9ETS2K4/B10P4,5
R900760285 4WEH22C73/6EW230N9TS2K4
R9000722936 4WEH22C73/6EG24N9K5
R901117511 4WEH22D73/6HG24N9K4
R901108958 4WEH22E73/6HG24N9ETK4
R901108815 4WEH22E73/6HG24N9EK4/B10
R901211094 4WEH22EA73/6EG24N9EK4/B10
R900926787 4WEH22J73/6EG24N9ETK4
R901108960 4WEH22J73/6HG24N9ETK4
R901108957 4WEH22L73/6HG24NETK4/B10
换向阀是具有两种以上流动形式和两个
以上油口的方向控制阀。是实现液压油流的沟通、切断和换向,
以及压力卸载和顺序动作控制的阀门。可分为手动换向阀、电磁换向阀、电液换向阀等。
又称克里斯阀,阀门的一种,具有多向可调的通道,可适时改变流体流向。工作时借着阀外的
驱动传动机构转动驱动轴,带动摇拐臂,启动阀板,使工作流体时而从左入口通向阀的下部出口,
时而从右入口变换通向下部出口,实现了周期变换流向的目的。这种变换阀在石油、
化工生产中有着广泛的应用,在合成氨造气系统中最为常用。此外,换向阀还可作成
阀瓣式的结构,多用于较小流量的场合。工作时只需转动手轮通过阀瓣来变换工作流体的流向。
力士乐单向阀
R900420531 S10A1.0/
R900420537 S15A1.0/
R900420525 S20A1.0/
R900420511 S25A1.0/
R901086051 Z1S6P05-43/V
R900347495 Z2S6-1-62
R900347498 Z2S6A1-62
R900407394 Z2S10-1-60
R900407424 Z2S10A1-33
R900328797 Z2S16-1-52
R900483371 SL10PA1-44
单向阀 Check Valve
单向阀又称止回阀或逆止阀。
用于液压系统中防止油流反向流动,
或者用于气动系统中防止压缩空气逆向流动。
单向阀有直通式和直角式两种。
直通式单向阀用螺纹连接安装在管路上。
直角式单向阀有螺纹连接、板式连接和法兰连接三种形式。
液控单向阀也称闭锁阀或保压阀,它与单向阀相同,用以防止油液反向流动。
但在液压回路中需要油流反向流动时又可利用控制油压,
打开单向阀,使油流在两个方向都可流动。
液控单向阀采用锥形阀芯,因此密封性能好。
在要求封闭油路时,可用此阀作为油路的单向锁紧而起保压作用。
液控单向阀控制油的泄漏方式有内泄式和外泄式二种。在油流反向出口无背压的油路中可用内泄式;否则需用外泄式,以降低控制油压力。
力士乐插装阀
R900910269 LC16A20E70
R900910270 LC25A20E72
R900906337 LC32A20E73
R900938000 LC40A20E73
R900912572 LC16A20D73
R900912580 LC25A20D72
R900912589 LC32A20D70
R900912543 LC32DB20E70
1818509245 LR16DB10E10/
1818509246 LR16DB40E10/
R900554857 LC80A05D60/
R900560360 LC80B00E62/
R900562672 LC100A40D62/
R900563206 LC80B10E62/
R900568486 LC80B00D62/
R900569389 LC80A05E62/
R900570128 LC80A00E62/
R900572880 LC100A10E62/
插装阀的通流量可达到1000L/min,通径可达200~250mm。
阀芯结构简单,动作灵敏,密封性好。它的功能比较单一,
主要实现液路的通或断,与普通液压控制阀组合使用时,才能实现对系统油液方向、压力和流量的控制。
插装阀基本组件组件由阀芯、阀套、弹簧和密封圈组成。
根据用途不同分为方向阀组件、压力阀组件和流量阀组件。
同一通径的三种组件安装尺寸相同,但阀芯的结构形式和阀套座直径不同。三种组件均有两个主油口A 和B、一个控制口x 。
R900912590 LC16B40E73/
R900912592 LC16B00E73/
R900912593 LC16B05E73/
R900912594 LC16B10E73/
R900912595 LC16B20E73/
R900912596 LC16B10D73/
R900912597 LC16B00D73/
R900912598 LC16B05D73/
R900912599 LC16B20D73/
R900912600 LC16B40D73/
R900912601 LC25B40E73/
R900912602 LC25B00E73/
R900937999 LC40A20D73/
R900938000 LC40A20E73/
R900938001 LC40B00D73/
R900938002 LC40B05E73/
R900938003 LC40B10D73/
R900938005 LC40B10E73/
R900938006 LC40B20D73/
R900938007 LC40B20E73/
力士乐HED压力继电器
R901106509 HED8OP20/100K14S
R901106505 HED8OH20/100K14AS
R901106504 HED8OP20/50K14S
R901106498 HED8OH20/100K14KS
R901106453 HED8OP20/350K14
R901106452 HED8OA20/200K14AS
R901110456 HED8OA20/200K14V
R901108236 HED8OH20/350K14AS
R901108003 HED8OP20/200K14AS
R901107922 HED8OA20/350K14SV
R901107790 HED8OP20/100K14AS
R901107128 HED8OH20/100K14A
R901102702 HED8OA20/50K14KS
R901102362 HED8OH20/200K14S
R901102360 HED8OH20/100K14
压力继电器是利用液的压力来启闭电气触点的
液压电气转换元件。当系统压力达到压力继电器的
调定值时,发出电信号,使电气元件(如电磁铁、电机、时间继电器、电磁离合器等)动作,使油路卸压、换向,执行元件实现顺序动作,
或关闭电动机使系统停止工作,起安全保护作用等。
压力继电器有柱塞式、膜片式、弹簧管式和波纹管式四种结构形式。
当从继电器下端进油口3进入的液体压力达到调定压力值时,
推动柱塞2上移,此位移通过杠杆放大后推动微动开关4动作。
改变弹簧1的压缩量,可以调节继电器的动作压力。
应用场合:用于安全保护、控制执行元件的顺序动作、用于泵的启闭、用于泵的卸荷。
注意: 压力继电器必须放在压力有明显变化的地方才能输出电信号。
若将压力继电器放在回油路上,由于回油路直接接回油箱,压力也没有变化,所以压力继电器也不会工作。
R901102356 HED8OH21/50K14KS
R901102349 HED8OH21/50K14
R901101698 HED8OA21/50K14
R901099789 HED8OH-21/200K14V
R901102706 HED8OA-2
迪普马MVPP-D/50 叠加阀
MCD
MVPP-D/50 MVPP-D/50 MCD5-SBT/51N MCD5-SBT/51N
意大利DUPLOMATIC(迪普马)公司授权的一级代理商,所销售DUPLOMATIC液压元件:
DUPLOMATIC齿轮泵,DUPLOMATIC系列叶片泵,DUPLOMATIC柱塞泵,DUPLOMATIC系列电磁阀,
DUPLOMATIC叠加阀,DUPLOMATIC比例阀...DUPLOMATIC电磁溢流阀,DUPLOMATIC压力继电器,
DUPLOMATIC防爆电磁阀,DUPLOMATIC伺服阀等
迪普马方向控制阀这个是一种直动式,板式安装方向控制阀,
安装面按ISO 4401标准(CETOP
RP121H)标准。
1- 阀体是由高强度铸铁件
以提供广泛的内部通道
流动压降减到最小。湿式
互换线圈的电磁铁
MCD4-SP/51N 叠加阀
MCD5-D/51N 压力控制阀
MCD5-DT/51N 压力控制阀
MCD5-SB/51N 压力控制阀
MCD5-SBT/51N 压力控制阀
MCD5-SP/51N 叠加阀
MCD6-D/51N 压力控制阀
MCD6-SBT/51N 压力控制阀
MCD6-SP/51N 叠加阀
MERS-D/50 叠加阀
MERS-RD/50 节流阀
MERS-SA/50 节流阀
MERS-SB/50 节流阀
MRQ4-SP/M1/51 叠加式溢流阀
MVPP-D/50 叠加阀
MVPP-SA/50 叠加阀
MVPP-SB/50 叠加阀
MVR-RS/P/50 单向阀
MVR-SA/51 单向阀
MVR-SB/51 单向阀
MVR-SP/51 叠加阀
MVR-SPT/51 单向阀
MVR-ST/51 单向阀
MZD2/50 减压阀
MZD2/A/50 减压阀
MZD3/50 减压阀
MZD3/A/50 叠加阀
MZD3/B/50 减压阀
MZD4/50 叠加阀
MZD5/50 减压阀
RQAM7-P5/1/A/I/51N-A230K1
RQRM5/P5/1/A/I/51N-A230K1
RQM3-P5/A/60N-A230K1现货
RQM7-P5/A/60N-A230K1现货
DSP7-S1/20N-IE/D/A230K1现货
DSP10-S1/20N-IE/D/A230K1
E4P4-12TC/D-I/50N-A230K1
RQ5-W6/41 现货
RQ3-P5/41现货
MERS-D/50现货
迪普马叠加式溢流阀:
三种安装尺寸,多种控制方式,
MCD型阀,直动式
安装尺寸:CETOP 03
压力等级:25-70-140-210-350bar
最大流量:50 l/min
MCD4-SP/51N
MCD5-D/51N
MCD5-DT/51N
MCD5-SB/51N
MCD5-SBT/51N
MCD5-SP/51N
MCD6-D/51N
MCD6-SBT/51N
MCD6-SP/51N
MRQ型阀
先导式控制
安装尺寸:CETOP 03
压力等级:70-140-210-350bar
最大流量:75 l/min
MRQ4-SP/M1/51
RQ4M型阀
安装尺寸:CETOP 05
压力等级:70-140-210-320bar
最大流量:100 l/min
RQ4M4-SP/51
RQ4M5-D/51
RQ4M5-SP/5
迪普马叠加式节流阀
三种安装尺寸,可单向控制液压回路中A,B路的流速。
MERS型阀
安装尺寸:CETOP 03
压力等级:350bar
最大流量:50 l/min
常用型号:
MERS-D/50
MERS-RD/50
MERS-SA/50
MERS-SB/50
迪普马防爆电磁方向阀
符合ATEX 94/9/CE标准,有直动控制和先导控制
MD1K型阀
安装尺寸:CETOP 03
压力等级:350 bar
最大工作压力:50 l/min
MD1K-S3/20N-D24K5
MD1K-S4/21V-AR230K5
MD1K-S1/21N-D24K5
MD1K-S4/21N-D24K5
MD1K-TA/21N-D24K5
MD1M-TA/10N-24V-CC
迪普马补偿式比例流量阀
当液压回路中的系统压力,油液温度发生变化时,
调速阀具有压力和温度补偿功能,使流量不受影响,保持恒定。
安装尺寸:CETOP 03
工作压力等级:250 bar
最大流量:1.5-4-8026-25 l/min
PSP6/21N-K1/K
PST2/21N-K1/K
PSP4/21N-K1-K
PSP4/21N-K1-K
PSP6/21N-K1-K
PSP4/21N-K1-K
PSP4/21N-K1-K
PSP6/21N-K1-K
意大利迪普马电磁换向阀
现货供应以下产品:
特价销售,DS3,DS5系列有大量现货
DS3-RK/10N-D24K1
RPC1-4/T/41
DXJ3-D0L10/10N/E0K11现货
DXJ3-D0L20/10N/E0K11现货
DXJ3-D0L40/10N/E0K11现货
DXJ5-D0L060/10N/E0K11现货
DXJ5-D0L100/10N/E0K11现货
DUPLOMATIC迪普马 DS3-RK/10N-A110K1
DSC3-SA1/10N
DSC3-SA/11N-A230K1
DS3-RK/11N-A230K1
DS3-RK/11N-D24K1 C.C.
DS3-RK/11N-D110K1 C.C.
DS3-S1/11N-A230K1
DS3-S1/11N-D12K1/CM
DS3-S1/11N-D24K1
DS3-S2/11N-A230K1
DS3-S2/11N-A110K1
DS3-S2/11N-D12K1/CM
DS3-S2/11N-D24K1
DS3-S3/11N-D24K1
DS3-S3/11N-A110K1
DS3-S3/11N-D12K1/CM
DS3-S1/11N-A230K1
DS3-S4/11N-A230K1
DS3-S4/11N-A110K1
DS3-S4/11N-D12K1/CM
DS3-S4/11N-D24K1
DS3-SA1/11N-A230K1
DS3-SA1/11N-D24K1
DS3-S3/11N-D24K1
DS3-SA2/11N-D24K1
DS3-SA2/11N-D12K1/CM
DS3-SB1/11N-A230K1
DS3-SB1/11N-A110K1
DS3-SB7/11N-D110K1
DS3-SB7/11N-A110K1
DS3-TA/11N-A230K1
DS3-TA/11N-A110K1
DS3-TA/11N-D24K1
DS3-TB/11N-A230K1
DS3-TB/11N-A110K1
DS3-TB/11N-D24K1
DS3-S3/11N-D24K1
EDM-M3 以上均无现货,交货期4个月
MD1D-S4/55=DS3-S4/10N 现货
DS3-RK/11N-D220K1含税,现货
IGP3-006-R01/10
DFP1-08-RA1/20 交货期四个月
RPCER1-8/C/52-24 四个月
MD1D-S2/50-24VDC现货
RPC1-4/T/41 现货
MDIK - S3/21N-AR230K5 三个月
MD1D-S3现货
MD1D-RK 现货
DS3-S4/10N 220V现货
GP3-0514R97F/20N五个月
e5p4-s1/ei/40v-d24k7现货
e5p4-s4/ei/40v-d24k7现货
DS5-TA/10N=DS5-TA/12N-A230K1现货
MZD3/50 叠加减压阀现货
DSE5G-C60/10V-E0K11/B四个半月
RLM3A-22/10N-D24K1四个半月
部分列举型号:现货供应
PSP6/21N-K1-K压力继电器 PSP6/21N-K1-K压力继电器 PSP6/21N-K1-K压力继电器
现货供应以下产品:
DSE3-A08/10N-D24K1
DSE3-A16/10N-D24K1
DSE3-A26/10N-D24K1
DSE3-C08/10N-D24K1
DSE3-C16/10N-D24K1
DSE3-C26/10N-D24K1
DSE3G-A26/11N-E0K11/B
DSE3G-C26/11N-E0K11/B
DSE5-A30/10N-D24K1
DSE5-A60/10N-D24K1
DSE5-C30/10N-D24K1
DSE5-C60/10N-D24K1
DSE3-C16/10N-D24K1
DSE3-C16/10N-D24K1
DSE3-A08/10N-D24K1
DSE3-A16/10N-D24K1
DSE3-A26/10N-D24K1
DSE3-C08/10N-D24K1
DSE3-C16/10N-D24K1
DSE3-C26/10N-D24K1
DSE5-A30/10N-D24K1
DSE5-A60/10N-D24K1
DSE5-C30/10N-D24K1
DSE5-C60/10N-D24K1
DSP7-S1/20N-EE/D24K1
DSP7-S3/20N-EE/D24K1
DSP7-TA/20N-IE/D24K1
DSPE7-C150/11N-II/D24K1
现货供应以下产品:
E5P4-S1/E/40N-D24K1电液换向阀
DT03-2E/10/24V DC 电磁锥式方向阀
DXJ3-D0L10/10N-E0K11 伺服阀----有现货
E5P4-S1/E/40N-D24K1 电液换向阀
E5P4-S3/E/40N-A230K1 电液换向阀
E5P4-S3/E/40N-D24K1 电液换向阀
E5P4-TA/E/40N-D24K1 电液换向阀
