品名/型号 Product Name/ Model |
基材 Substrate |
胶系 Adhesive |
总厚度(mm) Thickness |
粘着力(g/in) Adhesion |
适用温度(℃) Application Temperature |
38#防静电保护膜) |
38#PET |
亚克力胶 |
0.050±0.005 |
6~10 |
-10~80(建议制程用) |
50#防静电保护膜 |
50#PET |
亚克力胶 |
0.065±0.005 |
6~10 |
-10~80(建议制程用) |
50#防静电保护膜 |
50#PET |
亚克力胶 |
0.065±0.005 |
6~10 |
-10~80(建议制程用) |
▲产品特性:具有防静电效果之PET保护膜,吸附性及消泡性佳,洁净度好且撕除后不残胶。
▲产品用途:适用于保护显示器之面板(LCD、OLED)、CRT、触控式荧屏、手机、数码相机及PDA面板,贴合于反光板,运输、裁切过程中避免刮伤,达到保护效果;并可用于光电材料如反射片、扩散片之冲型载体。
▲储存环境:温度23℃±5℃、相对湿度65%±5%。
▲储存时间:12个月。
▲ Product Features: anti-static effect of PET film, adsorption and good² defoaming, cleanliness and tear, glue residue.
▲ Product Use: apply to protect the display panel (LCD, OLEDs), CRT, touch screens, mobile phones, digital cameras and PDA panel and fit the reflective board, transportation, cutting to avoid scratching to achieve the protective effect ; can be used for optoelectronic materials such as reflective film, and the proliferation of film, the red vector.
▲ Storage Environment: Temperature 23 ° C ± 5 ° C, relative humidity 65% ± 5%.
▲ storage time: 12 months.
