品名/型号 |
基材 |
胶系 |
总厚度(mm) |
粘着力(g/in) |
适用温度(℃) |
50# PET保护膜 |
50#PET |
硅胶 |
0.065±0.005 |
5g↓ |
-10~80 |
50# PET保护膜 |
50#PET |
硅胶 |
0.065±0.005 |
10~15g |
-10~80 |
75# PET保护膜 |
75#PET |
硅胶 |
0.090±0.005 |
3g↓ |
-10~80 |
75# PET保护膜 |
75#PET |
硅胶 |
0.090±0.005 |
5g↓ |
-10~80 |
75# PET保护膜 |
75#PET |
硅胶 |
0.085±0.005 |
6~10g |
-10~80 |
100# PET保护膜 |
100#PET |
硅胶 |
0.120±0.005 |
3g↓ |
-10~80 |
100# PET保护膜 |
100#PET |
硅胶 |
0.110±0.005 |
6~10g |
-10~80 |
100# PET保护膜 |
100#PET |
硅胶 |
0.110±0.005 |
40~50g |
-10~80 |
25# PET保护膜 |
25#PET |
亚克力胶 |
0.040±0.005 |
10~15g |
-10~80 |
38# PET保护膜 |
38#PET |
亚克力胶 |
0.053±0.005 |
6~10g |
-10~80 |
50# PET保护膜 |
50#PET |
亚克力胶 |
0.065±0.005 |
3g↓ |
-10~80 |
50# PET保护膜 |
50#PET |
亚克力胶 |
0.060±0.005 |
6~10g |
-10~80 |
50# PET保护膜 |
50#PET |
亚克力胶 |
0.060±0.005 |
300~400g |
-10~80 |
▲ 产品特性:普通PET基材涂布胶水,贴合聚酯薄膜而成,有多种厚度和粘性供选择。具备良好的自吸附性和
消泡性,洁净度高且使用后不残胶。
▲ 产品用途:广泛应用于个段制程及运输过程避免刮伤,达到保护效果;并可作为光电材料如OCA光学胶、
反射片、扩散片之冲型载体;适用于金属、塑料和玻璃等多种材质。 HPS-2083(SY356-A)改
为HPS-2082;
▲ Product Features: PET substrate coated glue laminating a polyester film made of a variety of
thickness and viscosity for selection. With good self-absorption and
Defoaming, high cleanness and use no adhesive residue.
▲ Uses: widely used in a BEOL and during transport to avoid scratching, to achieve the
protective effect; and as optoelectronic materials such as OCA optical glue,Reflective films, the proliferation of the red vector of the piece; applicable to a variety of materials such as metal, plastic and glass. HPS-2083 (SY356-A) to change
Of HPS-2082;
