品名/型号 Product Name/ Model |
基材 Substrate |
胶系 Adhesive |
总厚度(mm) Thickness |
粘着力(g/in) Adhesion |
适用温度(℃) Application Temperature |
50#双抗PU胶保护膜 |
50#双抗PET |
PU胶 |
0.062±0.005 |
3↓ |
-10~80(建议制程用) |
50#无抗PU胶保护膜 |
50#超透PET |
PU胶 |
0.062±0.005 |
3↓ |
-10~80(建议制程用) |
产品特性:针对普通玻璃、硬化玻璃特性所开发的PU胶系保护膜,不含硅胶成份,无硅转移。贴合性能好,排气性能优于亚克力
胶保护膜粘性稳定且容易撕取。具备高洁净度和高透光性,使用后不残胶、无鬼影。
产品用途:用于各种面板、零部件制程及出货的保护,适用于普通玻璃、硬化玻璃、PMMA和PC等多种材质。
Product features: in view of the common glass, hardened glass properties developed by PU adhesive protective film, Do not contain silica gel ingredients, no silicon transfer. Joint performance is good, the exhaust performance is better than that of acrylic plastic protective film, viscosity stabilityeasy to tear. Have high cleanlinesshigh light penetration, no glueshadow residue after use.
Product use: used for various panels, parts of the processshipment protection, suitable for ordinary glass, hardened glass, PMMAPC,other materials.
