| Product ID | JAD-15727 |
| Manufacturer | Advantest |
| Vintage | 2005 |
| Model | T2000 |
| Condition | Good |
| Configuration | |
| De |
T2000 Test System |
| Comments | |
| Detailed Specifications |
Advantest T5377,T5593, T5588 维修
** T3347A MEC12 SYSTEM DIAGNOSTICS REV.5.06B2 **
** START AT 2012/12/20 13:27:03 **
** STN1 TEST PIN= 1 - 256 **
** STN2 TEST PIN= 1 - 256 **
TH2 INIT DR GAIN FAIL**
110057. 57PIN IN1 (H) BINARY SEARCH DATA=#5700
210057. 57PIN IN1 (L) BINARY SEARCH DATA=#5700
TEST 56100 TH2 ( 9) CLAMP CHECK FAIL**
10057 PIN= 57 LIMIT= 9.500V , 8.500V MDATA= 0.000V FAIL
20057 PIN= 57 LIMIT=-3.000V ,-4.000V MDATA= 0.000V FAIL
HV2 57PIN BGQ-020732 (AAA) IS DOUBTFUL
TEST 53000 TH2 ( 2) DR OFFSET VOLTAGE (NORMAL MODE) CHECK FAIL**
120057. 57PIN IN2 (H) LIMIT= 29.00MV ,-29.00MV MDATA=-1.018V FAIL
220057. 57PIN IN2 (L) LIMIT= 29.00MV ,-29.00MV MDATA= 1.012V FAIL
TG SLOT 2 BGR-020842 (BKE) IS DOUBTFUL
HV2 SLOT 5 BGQ-020841 (AAA) IS DOUBTFUL
HV2 SLOT 10 BGQ-020840 (AAA) IS DOUBTFUL
TEST 53100 TH2 ( 2) DR IN1-16 SELECT CHECK FAIL**
110057. 57PIN IN 1 (H) LIMIT= 542.1MV , 481.9MV MDATA=-752.0MV FAIL
TEST 53410 TH2 ( 2) TH-MDC CABLE CONNECTION CHECK ***PASS
TH2 INIT PL OFFSET FAIL**
10057. 57PIN IL1 (H) SEQUENTIAL SEARCH DATA=#445
20057. 57PIN IL1 (L) SEQUENTIAL SEARCH DATA=#445
维修时间 标准时间10个工作日,加急3个工作日,对修复部位保修三个月。 本公司回收各种损坏的变频器、触摸屏、电源、伺服驱动等。贵单位如有上述各方面的维修需求,请带坏电路板来我公司考察、维修,以便建立长期的业务关系。我们将以高度的热情、精湛的技术为贵单位排除一切因电路板故障造成的诸多不便,竭尽全力保障生产顺利进行。
通过中国触摸屏网金牌会员认证
