Psychro-Transmitter
Order-No. |
1.1130.20.000 |
工作电压 |
12 V AC / 6 VA |
1.1130.22.000 |
工作电压 |
12 V DC |
测量范围 |
0 ... + 60 °C |
测量元件 |
2 x Pt 100, acc to. IEC 751 |
测量精度 |
1/2 class B (± 0,1K) |
Time constant(时间常量) |
17 s (90 %) |
气流速度 |
4 ... 6 m/s |
Water container(水容器) |
250 ml |
Electr. connection(电子链接) |
4-lead circuit |
链接 |
each with 4 pole plug connector |
尺寸 |
Ø160 x 465 mm |
重量 |
3,7 kg |
Hygro-Transmitter
Order-No. Electr. output Connecting |
1.1000.50.015 |
200 Ohm linear |
Lemo-plug |
1.1000.50.515 |
200 Ohm linear |
3m cabel |
Ambient temp. (环境温度) |
10 ... 100 % rel. F. |
Accuracy(精度) |
± 2 % rel. F. |
Scale graduation(刻度) |
1% rel. F. non-linear |
Measuring element 测量元件 |
H |
Measuring range (测量范围) |
- 35 .... + 70 °C |
Scale length(标长) |
94 mm (90°) |
Stem diameter(茎粗) |
22 mm |
Stem length(茎长) |
250 mm |
Protection (case)(保护等级) |
IP 65 |
Total length (总长度) |
Case 350 mm |
Weight(重量) |
0,45 kg |
Weather&Thermal Radiation Shield
Order-No. |
1.1025.51.000 |
Installation pin (安装针) |
Ø 22 x 27 mm |
Material(材料) |
Al, anodized and varnished |
Dimension(尺寸) |
Ø 170 x 450 mm |
Weight(重量) |
2,5 kg |
Wind Protection
Order-No. |
1.0509.85.006 |
Diameter (直径) |
24 mm |
Length(长度) |
200 mm |
Mesh aperture (网孔) |
0,32 mm |
Material(材料) |
Niro, Brass |
Weight(重量) |
0,022 kg |
Hygro-thermo transmitter compact
Order-No..1.1025.55.xxx.
Order-No. |
1.1005.54.xxx |
Humidity (湿度) |
Temperature(温度) |
.000 |
0 ... 1 V |
Pt 100( ± 0,15 K) |
.241 |
4 ... 20 mA |
4 ... 20 mA |
.161 |
0 ... 10 V |
0 ... 10 V |
0 ... 100% rel. h |
- 30 ... + 70 °C |
Accuracy humidity |
± 2 % rel. h |
Temp. Meas. elem. |
PT 100 acc. to IEC 751 |
Accuracy(精度等级) |
1/3 class B |
Operating voltage (工作电压) |
9 - 30 V DC (.000) 12 - 30 V DC (.241) 24 V DC (.161) |
Protection(保护等级) |
IP 30 for sensor |
Cable(线长) |
5 m long |
Dimension(尺寸) |
20 x 115 mm |
Weight(重量) |
0,45 kg |
Weather and Thermal Radiation Shield,compact
Order-No. |
1.1025.55.000 |
without ventilator (没有换气扇) |
.100 |
with ventilator(带换气扇) |
12 V DC; 2,5 W |
Material(材料) |
synthetic lamellas white |
Mounting(安装) |
stainless steel holder |
Cable(线长) |
5 m, for model .100 |
Dimension(尺寸) |
Ø 120 x 270/290 mm |
Weight |
0,75 kg |
Hygrograph
Order-No. |
Recording time |
Clock work |
1.0610.xx.xxx |
1/ 7 days |
Spring wound drive |
1.0614.xx.xxx |
14/31 days |
1.0615.xx.xxx |
1 /7/ 31 days |
Quartz |
.10.xxx |
Measuring element H (hair), accuracy ±2%, measuring range 10…100 % rel. hum. |
.12.xxx |
Measuring element K (synthetic fibre), accuracy±3%, measuring range: |
.000 |
Not lockable |
.900 |
lockable |
Hygro-Thermograph
Order No. Recording time Thrust |
1.0660.xx.xxx |
1 day / 7 days |
40 mm/day, 11,45 mm/h |
1.0664.xx.xxx |
14 days / 31 days |
20 mm/day, 9 mm/day |
1.0665.xx.xxx |
1, 7, 31 days |
Quartz clock work |
Hum. meas. elem. |
Measuring range |
.00.xxx |
H (-35 ... +70 °C) |
.02.xxx |
K (0 ... +80 °C) |
0... 100 % rel. F. |
.0xx |
lockable |
No |
.9xx |
Yes |
.x00 |
Temperature measuring range |
-35 ... +45°C (only H) |
.x05 |
-20 ... +60°C (only H) |
.x11 |
-10 ... +50°C (only H) |
.x12 |
-10 ... +40°C (only H) |
.x14 |
0 ... +40°C |
.x15 |
0 ... +50°C |
.x16 |
0 ... +60°C |
.x17 |
0 ... +80°C |
Scale range |
0 ... 100% rel. h. |
Accuracy Hum. |
± 2% rel. h. (H), ± 3% rel. h. (K) |
Accuracy Temp. |
± 1 % of mr. |
Recording width |
2 x 82 mm |
Graduation |
5% rel. F. / 1 resp. 0,5°C |
Dimension |
280 x 138 x 285 mm |
Weight |
2,7 kg |
Aspirations-Psychrometer Model Assmann
Order-No. |
1.0400.00.010 |
Measuring range测量范围 |
-10 ... +60 °C |
Graduation (刻度) |
0,2°C |
Accuracy(精度) |
± 0,2 K, for thermometer |
Aspirator |
spring-wound drive |
Measuring time |
approx. 8 min. (=4 ... 2 m/s) |
Dimension |
Ø 90 x 420 mm |
Weight |
3,5 kg |
Order-No. |
1.0450.00.010 |
Measuring range |
- 10 ... + 60 °C |
Graduation |
± 0,1°C |
Accuracy |
0,2 K |
Dimension |
305 x 60 x 22 mm |
Weight |
0,42 kg |
