廉洁吃亏一阵子,自律安全一辈子;贪婪侥幸一阵子,坐牢后悔一辈子。(马振宗南京公司)
两袖清风一生轻松,一日为贪终日难安。(朱兴明南京公司)
淡泊人生蓄以明志,清廉处世方能致远。(马永贵南京公司)
心无私欲,自然会刚;人无邪念,自然会正。(韩 成 南京公司)
主营产品:Schneider ,Foxboro,Ovatin,
Allen-Bradley,Siemens等各类工控产品,
欢迎来电咨询!
优势产品,最低价供应
Asco/ Tri Point Pressure Switch *New* SB10DF
Stahl 9001/51-280-110-14 Safety Barrier Intrinspak new
Sunx Photoelectric Safety Sensor Controller SF1-AC2
NSD Varilimit Limit Switch Controller VS-10EXT ABSO
Autotech Resolver E7R-RL101-NE4FS 3/8 in new
Emerson Motion Program Controller PCM-11 960158-02 new
Taihei Boeki Pressure Switch PZ30PS-100X3 new
Euchner Enabling Switch ZSA085114C1968 085114 New
Camco Encoder CT-6004-10-ADO 115 vac
TR Electronics LA-66-K Linear Position Sensor 312-01454
SMC CEU2 3 Point Preset Counter Controller
Custom Servo Motors Module Controller 469882-01
Sick FGSE 600-111 Receiver 600 mm 6 m 1013884
Ingersoll Rand Air Nutrunners D Series DAM25NE4S8
Siemens Simatic Input Module PLC 505-4332 new in box
Siemens Simatic Output Module 505-4508 8 pts new in box
Omron Power Supply S8PS-15024C 24 vdc nib
Siemens 505-4908 5054908 Relay Output Module new in box
Bei Encoder H20EB-37-F12-SS-360-ABZC-7272-SM18-24V-S
Balluff Absolute Encoder BRGD2-WCD0B-EP-P-R-K 783628
GE Druck Industrial Pressure Transmitter PTX-1210
Symbol Laser Scanner Barcode Phaser P300STD-I001
Heidenhain Indramat Encoder ROD 420.0010 238 485-23 new
Banner EZ-Light PVA226P6RQ PVA Receiver Emitter new
Banner Light Curtain MGR1816A Receiver new
Banner Light Curtain MGE1816A Emitter new
Square D Electromechanical Level Control 9038AW1 9038 A...
Uticor PMD 150 Programmable Message Display PMD 150 150...
Toyoda Toyopuc TUF-5731 DLNK-SP 16/00 Communication Ter...
STI Light Curtain Receiver MS4312BR 42672-0120 MiniSafe...
Hydac Pressure Transmitter HDA 4745-B-100-000 new
Dynamics Research Corporation Encoder SST-10-E2-97C
Sierra Instruments Flow Meter *New* 730-N1-PV1-V1-EO
Veeder Root Mechanical Counter EG-123925-686 new
Acu-Rite Linear Encoder 38-52-52-5308 new
Indramat Module Card AS151/204-000 new
Indramat Rexroth AS151/204-000 Module Card
TOHO Multiplex Tranmitter I/O Card AII-32-8S8R-2 new
Vorne Industries 2015 Panel Message Display 2015S-ILP/4...
Montronix/ Kistler RetroBolt *New* M16-ICA
Toyoda Photoelectric Branch 2 TXK-5201 new
Metrotec Power Supply MGD15-06 *New*
Allen Bradley Incremental Encoder 845H-SJHZ26FWY2C new
Electro Cam Programmable Limit Switch 5000 Series PS-51...
SMC Compact Guide Cylinder MGPS50-100
Aikoh High Compression Load Cell DCD-500 5KN new
Goodman Digital Counter S660-S13026 new
Asco 2-Way Solenoid Valve 8210B056 new
Maxon Motor Control 4-Q-DC 145391 ADS Servo Amplifier
Vickers Valve DG4V-3S-6C-M-FW-B5-60 dg5s4-043c-e-t-m-fw
GF Signet pH/ORP Transmitter 3-87101 new
Taiheiyo Kikai Kogyo H20-T Hot-Ace Super Heate Heater H...
Honeywell UV Flame Detector Purple Peeper C7012E 1104
Emerson Positioning Servo Drive PCM-11 960158-02
Nordson 276954B SA03H 00358 new
Sola Power Supply SDN-24-20-100 new in box
Keba Ketop CB211 Connection Box
Lambda Industrial Power Supply JWS300-15
NSD Teach Pendant Hand-Held VS-T01-0.3 new
NSD Teach Hand-Held Pendant VS-T01-0.3 new
Allen Bradley Incremental Encoder 845H-SJDZ25CMY2 new
Lambda JWS300-15 Industrial Power Supply new
Symbol Scanner Barcode LS3070-I100US new
Oilgear Cartridge Valve HS2SV0-604-0W
FCI Fluid Components International FLT93C-0A1B*0*C1B000...
MTA Inc. Master On Device with Diagnostic Function ESU-...
Wago Ethernet TCP/ IP Programmable Filedbus Controller ...
Indramat Rexroth Module Card DEA5.2
Eagle Signal Microprocessor Timer Counter CX312A6 new
Eurotherm Temperature Controller 2216/CC/VH new
Balluff Photoelectric Sensor BOS 26K-PA-1LHC-S4-C new
Indramat Module Card AS161/012-000 new
FEM FEM-03 Flow Monitor new
Load Controls Control Load Compensator XCR-1830V R1, R2
Indramat Rexroth DEA5.1 Input/Output Module
Indramat Rexroth Input Output Module DEA4.2
Allen Bradley PCB Assy Feedback SP-122972 new
Veeder Root Mechanical Counter EG-123925-1
SICK OPTIC Contrast Scanner NT8-01 13010455
Tokyo Sensor Co. Bumper Switch N12
Abbott Technologies Z5B20 Power Supply
Vorne Industries Event Counter 77/256M-0AC-004
Hokuyo Electronic Counter DC-MC6-E DC-M new
Valenite Gauging Probe 715M358-B01 VGage new
Sick PS53-1000 Power Supply 7024494 new in box
Valenite Gauging Probe 760M406-B03 VGage new
Valenite Gauging Probe 715M308-B01 VGage new
KB Electronics Load Cell PID Controller Board 55002406
Veeder Root Totalizer 195326-045 new
Warner Electric Photoscanner MCS-500-01 7150-448-004 ne...
Cognex I/O Expansion Module 800-5758-1 Revision J
Five Star Seal 85 Fluid Surry Seal 2 1/2
LKB Butterfly Valve 9611414550 304 ss new in box
Five Star Seal 84 Fluid Seal 1 5/8
Five Star Seal 85 Fluid Surry Seal 1 1/8
Five Star Seal 85 Fluid Surry Seal 2 1/4
Allen Bradley Guard Master Minotaur MSR6R/T 23018
Banner Mini Screen Controller MSDINT-1T2 new
Banner Light Curtain MGE3016A Emitter
Sensor Systems Rectilinear Potentiometer 111 new
Key Transducers 1106-04 Load Cell new
Totalcomp Single Point Load Cell TPMK4D-100 100 lbs
Omron Temperature Controller E5CJ-R2-F
Action instruments Action Pak Signal Conditioner 4390-0...
Indramat Programming Module MOD15 MOD 15/1X0014-002 new
Indramat Programming Module MOD15 MOD 15/1X0007-001 new
Euchner Safety Switch TZ TZ2LE024SR11 070958 new
Heidenhain Rotary Encoder ROD 529 406038-13 new
AC Autotech Limit Switch Mini Cam M1350 SAC-M1350
Sony CCD Camera Module XC-77 w/ Lens
Allen Bradley 500L-AOA94 Lighting Contactor new
Holjeron BusBlock I/O Module BBK-DIG128 new
Indramat Rexroth Input/Output Module DEA28.1
Allen Bradley Snubber Resistor Assembly 81001-408-63-R
Microscan Bluetooth Modem & Power Supply 98-000076-01
Sick Power Supply PS53-0000 7024495 new in box
Dynapar Encoder HA62525006341 HA625 3/8" new
Dynapar Encoder HR62510000306 3/8 shaft new
Montronix Sensor *New* AE100-400WB
GE General Electric Solid State Reduced Voltage Starter...
Sunx Photoelectric Sensor Super Analog RS-820H-1-SAS
Computerwise Transterm TT6-00 Data Terminal new
Yamatake LDV-5304S Limit Switch Multi Plunger new
UE United Electric Electronic Pressure Switch One D1A1C...
Spectrum Illumination RL4 Standard Series Ring Light RL...
Deltron Power Supply W115D 24v new
Delavan Sonac Sensor 11L new
Pfeiffer Vacuum DVI 005 M Valve Electromagnetic PFH1323
RexRoth Gear Pump 9510 290 021 9510290021
