Inputs (17" to 26") 5 inputs with palm rejection
Inputs (27" and 32") 10 inputs with palm rejection
Input Method Finger, finger tips, thin gloves, 3M Smart Pen
Accuracy >99% of true position
Resolution 4K x 4K
Linearization Inherently Linear (only video alignment needed)
Tail Connection Solder-less design
Light Transmission 88% (+/- 2%)
Electronics (3M Multi-Touch Controller PX)
Communication USB HID Digitizer, Serial RS-232
Dimensions (17” to 23”) 3.75" x 4.18” (95.25 mm x 106.17 mm) REF
Dimensions (24” to 26”) 3.75" x 4.18” (95.25 mm x 106.17 mm) REF
Dimensions (27” to 32”) 4.62" x 4.85” (117.35 mm x 123.19 mm) REF
Operating (17” to 23”) 260 mA (typical)
Operating (24” to 26”) 320 mA (typical)
Operating (27” to 32”) 360 mA (typical)
Sleep Current < 500 uA
Power Connection Self-powered 5 V @ 2 A max
Connectors ZIF (touchscreen side)
Molex (USB/Serial COM side)
Touch Refresh Rate Greater than 100 Hz (<10 ms)
Reliability
Surface Obstruction Withstands most surface contaminants
Chemical Resistance ASTM-D-1308 and ASTM-F-1598-95
Operating Temperture 0ºC to +50ºC (up to 90% RH from 0ºC to +35ºC
(above +35ºC see specification))
Storage Temperture -10ºC to +70ºC (up to 90% RH from 0ºC to +35ºC
Humidity Up to 90% RH from 0ºC to +35ºC, non-condensing
Mechanical
Total Thickness 17” to 27” sensors: 2.1 mm
32” sensors: 2.4 mm
Cover Glass 17” to 27” sensors: 1.6 mm
32” sensors: 1.9 mm
Graphics Black border (standard design)
Display Size Supported 17” to 32” (standard sizes available)
Durability Non-active cover glass, no wear mechanism
Sealing NEMA 4X/IP66, complete water-resistant
seal compatible
Cleaning Water, isopropyl alcohol, or similar non-abrasive cleaners
Regulatory FCC-B, CE, TUV
(Agency Approvals)
RoHS Compliant Yes
System Warranty
One year on touch system
Unlimited touch warranty
Operating Systems Supported
Windows 7, Vista, XP (32- and 64-bit)
Windows CE 4.0, 5.0, 6.0
Linux Kernel 2.6, Kernel 2.4 (serial only
