全新Macbook PRO A1398 MC975上半部分
全新原包A规 Retina Macbook MC975 Assembly 上
半部分LP154WT1
产品型号(MODEL) :上半部分 Retina Macbook MC975
屏尺寸(Size) :15.4英寸
制造商(Productor): MACBOOK
分辨率(Resolution) :2880*1800
显示比例(Display scale) 16:10
响应时间(Response) 25(Tr+Td) ms
亮度(Luminance) 350 nits
对比度(Contrast Ratio) 1500 :1
颜色(Color) 262K(6bit)
B101EW05-V0工程参数
面板类型(Technology) a-Si
接口类型(Interface) LVDS(1ch,6bit)
驱屏电压(Drive-screen voltage) 3.3V
点距(Pixel Pitch) 0.0565x0.1695 mm
显示区域(Active Area) 216.96x135.60 mm
外形尺寸(Outline) 229.46x149.2x5.2 mm
面板重量(Weight) 1200g
可视角度(Viewing Angle) 180/180/180/180 (上/下/左/右)
背光类型(Backlight) 白光LED
灯管数量(Lamp Number) --
背光寿命(Life Time of Lamp) 15K Hours
工作温度(Operation Temperature) 0oC ~ 50oC
工作湿度(Operation Humidity) --
存储温度(Storage Temperature) -20oC ~ 60oC
存储湿度(Storage Humidity) --
主要用途(Applications) 平板电脑,笔记本
产品图片:
热门产品:
| HSD100IFW2 | |
| HSD100IFW1 | |
| HSD121PHW1 | |
| M101NWT2 10.1 LED | |
| HSD101PFW2 10.1 LED | |
| B101EW02 V.0 | |
| B101EW05 V.0 | |
| N101ICG-L21 | |
| LP101WH1-TLA2 | |
| N116BGE-L32 | |
| N116HSE-EA1 | |
| LTN116AT01/B116XW02 V.0 Grade A | |
| LP121WX3 TLC1 just 45pcs | |
| LP121WX3 TLA1 | |
| LT131EE11000/B131HW01 | |
| LT131EE12000/B131RW02 | |
| B133XW01 V.0 | |
| B133XW03 V.0 | |
| LP133WH1 TLB1/A2 | |
| LP133WH1 TPD1 30pins for DELL | |
| B133WX03 V.3 /B133XTF01 | |
| LP133WP1 TJAA For Macbook A1369 A1466 A1465 | |
| LTN133AT23 | |
| LTN133AT25 801 | |
| N133HSE EA1 | |
| M133NWN1 For ACER S5 | |
| B140XW03 V.0 or compatible one | |
| B140XW03 matte | |
| LTN140AT21 | |
| LP140WH1 TPD1 | |
| LP140WH2-TLE2 | |
| LP140WH4-TLA1 | |
| N140BGE-L21/23 | |
| HW14WX101 | |
| B140RW02 V.0 | |
| B141PW04 V1 | |
| LTN141BT08 For T400S T400 | |
| N144NGE-E41 For U840W U845W U800W | |
| LP154WX7 15.4 LED Grade B | |
| N154I2-L02 20PCS | |
| N154I3-L02 7PCS | |
| B154EW08 V.1 2PCS | |
| B154EW02 V.7 20PCS | |
| CLAA154WB03AN 6PCS | |
| LP156WFC-TLB1 | |
| LTN156AT24 15.6 LED HD Matte | |
| LP156WH4 TPA1 Compatible to N156BGE-E21 | |
| B156XW04 v.6 Slim Matte or compatible one | |
| B156XW03 V.0 compatible one LTN156AT20/24 | |
| LP156WF4 SPB1 | |
| LP156WF4 SLB1 | |
| LTN156AT19 | |
| N164HGE L11 | |
| LP164WD2 TLA1 | |
| B170PW06 /LP171WP4 | |
| LP171WU5 TLB1 | |
| B170UW02 2ccfl 1920*1200 or Compatible one | |
| N173HGE-L11/L21 17.3 Full HD Matte | |
| N173HGE-L11/L21 17.3 Full HD Glossy | |
LP173WD1 1.LTN154MT07 slim LED 1680*1050 for macbook pro 200pcs
2.LTN154AT14 15.4 LED,special one with cable 50pcs
3.A1398 assembly (upper half of laptops,with case)
4.LTN121AT06 12.1 LED 40pins
5.LTN141AT12 14.1 LED with cable
6.LTN141AT13 14.1 1CCFL LCD PANEL
7.LP133WQ1 13.3 Slim LED for macbook A1425
8.LP133WP1 TJAA,13.3 LED ,from Macbbok A1369
9.In the future will come 3K 15.6 LED,B156XW02 V.0/1
10.Assembly for NP900X3B 900X3C 900X4C 900X3E/A(panel part number is11.HN133WU3-100,compatible to LSN133AT01),new,just left 20pcs now.
12.LP133WH5 TSA1 13.3 LED For HP XT Series
13.12.1 LCD B121EW03
14.LTN133AT01 13.3 1CCFL 30Pins
我们提供各种液晶屏,
尺寸从 3'' 到 64'',
1).尺寸:3'',3.5'',7'',8'',8.9'',10'',10.1'',10.2'',11.1'', 15.6'',16'',16.4'',17'',17.1'',18.4''......64''......
2).分辨率:WSVGA, WXGA, WXGA HD, XGA, WXGA+, WXGA++, UXGA, WUXGA......
3)背光: LED, 1 CCFL, 2 CCFL
2.Keyboards,IC,Convery,Adapter and other laptop accessories
