51101318-900-RP PWA, TVD191
51101318-901-RP I/O PWA TVD193
51101318-902-RP MICRO TVD194/204
51101580-113-RP CBL/45K TBO SMI
51102008-109-RP PWA, MICRO PROC
51102516-201-RP ConTROL PWB (W/P)
51102866-104-RP DATA CABLE
51103224-100-RP FILTER BOARD POD
51103230-200-RP Cable Clamp
51104630-200-RP
51104782-101-RP PWA, PORTED CTLR
51106227-100-RP DATA HIWAY ADAPTER
51107109-280-RP FAN,VENTURI
51107111-175-RP POWER PAC300LPM
51107127-266-RP CABLE & HEAD KIT
51107146-116-RP IBM KEYBOARD
51107147-155-RP RIBBON, COLOR
51107403-100-RP I/O Card, LCN
51107593-100-RP Pwr Supply, Kybd
51107595-100-RP Pwr Supply, WDC
51107754-100-RP I/O Card, MCPU
51107756-100-RP VIDEO DG - I/0
51107954-100-RP I/O Card, MCPU
51108020-100-RP PERIF INTFC CTL
51108088-200-RP DHI I/O ADAPTOR
51108312-100-RP CRT,
51108389-002-RP Locknut, M3.5 Hex
51108392-004-RP Lockwasher, M3.5
51108393-005-RP Lock Washer, Ext Tooth, M4
51108436-320-RP SCREW
51108590-110-RP ConTROL PANEL AS
51108676-100-RP PWB, I/O WREN II
51108678-100-RP PWB, I/O WREN I
51108679-200-RP MTG SHOCK SNUBB
51108880-410-RP MACH SCR 3.5X
51108883-002-RP W FLAT WASHER M3.5
51108884-005-RP LOCK WASHER M4
51108888-512-RP HEX HD SCREW M4/12
51108892-100-RP Card File, Spare 5 Slot Enh, EC
51108899-100-RP PWA, Fiber Optic
51109040-100-RP CLI Test Cable
51109181-003-RP Cable Set, LCN Coax,
51109181-010-RP Cable Set, LCN Coax,
51109181-015-RP Cable Set, LCN Coax,
51109182-002-RP COAX CBL SET RG59
51109323-100-RP
51109336-100-RP I/O 5-1/4 FDD
51109394-100-RP PWA, PDG I/O
51109485-100-RP 8-dro TAP ASSY
51109516-100-RP Cable, Fan,
51109516-600-RP Cable, Fan,
51109684-100-RP Pwr Supply, PM
51109693-100-RP BRACKET GND 2&4 TAP
51109806-002-RP Cable Set, LCN Coax,
51109818-100-RP PWR SUPPLY, FD
51109882-100-RP PRINTED CARD
51109897-100-RP PWA, HIMX I/O
51109909-100-RP SURGE SUPPR. (A/A)
51109919-100-RP PWA, PCSR
51190102-300-RP 250 Ohm Dummy Resistor
51190413-213-RP MODULAR POWER SU
51190523-125-RP RELAY
51190584-150-RP Fuse, .5 Amp Slo-Blow
51190795-200-RP (MU-NKTT01) RG11 COAX CRIMP TOOL
51190876-100-RP Fan, Rotron
51190879-010-RP Tie Wrap, Small
51190880-175-RP WIRE, #14 600V,GREEN
51190896-100-RP Cable Set, Mini-Coax
51190916-102-RP Tap Assy, 2-dro
51191227-100-RP 4500 BUS TERMTR
51191305-100-RP P.S SWITCH RELAY
51191556-100-RP URCD Repl Kit for Reserve Ctrl Directors
51191783-100-RP Cable, MAU (UxS)
51191784-100-RP Cable, CRT Signal
51192054-104-RP CABLE, SCSI
51192060-100-RP
51192126-400-RP Cable, CRT w/Ferrite
51192139-114-RP (MU-KLX076) CABLE,EC,4-COND,250'
51195058-100-RP I/O Card, PDG TTL
51195066-100-RP Pwr Supply, 5 Slot
51195096-100-RP I/O Card, PLCI
51195119-020-RP TW/PR RED/BLK 20'CBL
51195140-228-RP Hard Drive, 1GB
51195153-001-RP CBLE SET,
51195153-003-RP dro Cable Set,
51195153-010-RP (MU-NKD010)
51195162-100-RP ConNECTOR KIT
51195199-002-RP (MU-NKT002)
51195271-100-RP RSD DISK PACK
51195295-200-RP Mouse-Trackball
51195398-102-RP PWA, 16MB Memory
51195399-120-RP CM505 REPLACEMENT HDWRE
51195440-002-RP
51195476-500-RP CABLE SET,
51195479-100-RP Cable Set, I/O
51195549-307-RP
51195563-200-RP POWER CORD
51195577-100-RP COLOR PRINTER
51195578-200-RP CARTRIDGE CTLR FOR PC DATA MANAGER
51195578-300-RP CARTRIDGE TAPE (SGL) PC DATA MANAGER
51195581-405-RP MODEM CABLE,
51195651-200-RP Modbus Module
51195904-006-RP VIDEO COPIER I/F CABLE,
51195947-200-RP CBL,DB78(8)DB25
51196005-500-RP MCS350 SCSI CARD/MCA
51196006-015-RP CABLE, RS232/
51196019-100-RP PWA, 4 PORT CLM I/O
51196086-200-RP PROC PWB, X-TERM
51196086-207-RP HP TRACKBALL
51196216-102-RP AUI CABLE,
51196246-102-RP LENS CLEANER
51196248-100-RP PWB, I/F
51196345-400-RP
51196425-050-RP CABLE,
51196483-100-RP
51196653-100-RP P/S 5 SLOT (EC)
51196655-100-RP P/S DUAL NODE EC
51196658-018-RP CABLE, VIDEO COPIER MUX SIGNAL
51196659-100-RP 5-1/4 FDD
51196661-104-RP BELDON8334 SHLEDTWPR
51196694-100-RP DESKSIDE IKB W/O TKB
51196696-200-RP CRT,
51196697-100-RP Printer C-DSP50
51196707-100-RP CD ROM
51196710-300-RP Monitor, Basic in Univ. Furn.
51196713-200-RP MOUSE, USX
51196742-200-RP Cable, Video,
51196742-400-RP Cable, Video,
51196863-920-RP Cleaning Cartridge,
51196877-100-RP PWB, CLM BB/MODB
51196879-100-RP UCPU Repl Kit for Basic Ctlrs
51196885-100-RP UDHI REPL KIT
51196886-100-RP UCIO REPL KIT
51196920-400-RP Cable, CRT Signal,
51196966-300-RP Cleaning Kit, TR-4 Streaming Tape Drive
51196968-100-RP 9.1 GB HARD DRIVE
51196979-100-RP CRT
51196982-901-RP Keyboard, 104
51196990-200-RP Cable, Serial Extension, DB
51197000-100-RP 21 FST CRT
51197002-100-RP CRT, Hi-Resolution
51197018-100-RP CRT,
51197021-100-RP CRT,
51197022-201-RP 21 T/S
51197066-200-RP A/C POWER ENTRY
51197090-100-RP CRT, Sony
51197096-100-RP CRT,
51197149-100-RP CRT,
51197178-100-RP CRT,
51198706-100-RP CTLR UPGRADE KIT
51198947-100-RP Process Manager
51199171-200-RP WKS1 Workstation w/o CD, LCNP4, IKBI2
51199451-100-RP Icon OEP Kybd Pkg
51199569-300-RP Hard Drive, 36.7GB
51200070-100-RP MEPS CARD GUIDE
51200520-483-RP Al SPACER:.22ID,
51200884-102-RP CABLE, KEYBOARD
51200922-100-RP PWA, Serial Rep
51200941-100-RP SERIAL PEPEATER
51201043-101-RP LCS CABLE
51201394-100-RP 2-dro TAP ASSY
51201396-003-RP CABLE,
51201397-001-RP (MU-KDPR00) PM POWER CABLE,
51201420-003-RP (MU-KFTA03) FTA I/O CABLE (
51201421-100-RP Cable, Redundancy
51201553-100-RP Adapter, Female Din/Male Phone
51201557-100-RP I/O
51201561-003-RP (MU-KFTD03) OMS/
51201667-100-RP Cable, HPM Redundancy
51201748-110-RP RESISTOR PLATE ASMBL
51201828-100-RP LOAD RES. MT. BKT
51204033-030-RP (MU-KFTS30) FTA I/O CBL (
51204126-002-RP Cable Set, PM Power w/
51204126-915-RP Cable Set, PM Power w/
51204138-002-RP Cable Set, PM Power w/
51204146-010-RP ControlNet Trunk Cable (
51204160-175-RP FTA, D/I 24VDC, Comp Term, CC, CE
51204162-175-RP (MC-TDOY22) DO 24 FTA/CO EC CC
51204166-175-RP (MC-TDOY23) DO REL COMPR EC CC
honeywellC200系统:TK-PRR021,TK-FTEB01,TC-RPA001,TC-RPFM01,TK-FPCXX2
honeywellC300系统:CC-PAIM01,CCTAIM01,CC-TAOX01,CC-PDOB01
公司名称:南京崇基信息科技有限公司
联 系 人:周销售
联系方式:025-8458
公司邮箱:
