南京崇基,拥有大量Honeywell DCS卡件库存,质优价廉!亦提供库存备件以外的Honeywell DCS集散控制系统:TDC3000(US操作站)、S9000、TPS(GUS操作站)、PKS、PlantScape等系统卡件订货服务,货期短,货源正,联系电话:025-84584473,84584476 ,传真:025-84584479。
TK-IDWvalue="161" unitname="ac" w:st="on">161 AC Input 220vac value="16" unitname="pt" w:st="on">16pt, CIOM-A, Coated TK-IDX161 DC Input 10-30vdc value="16" unitname="pt" w:st="on">16pt, CIOM-A, Coated 51192416-305 ControlNet Trunk Raw CBL 900' value="275" unitname="m" w:st="on">275M TC-FOA041 4 Point Analog Output Module, RIOM-A TC-FIAH81 8 Point Analog Input Module, RIOM-A TK-ODD321 DC Output 24vdc value="32" unitname="pt" w:st="on">32 pt, Coated TC-FXX132 13 Slot Chassis, 13 Amp TK-ODAvalue="161" unitname="ac" w:st="on">161 AC Output 120/220VAC value="16" unitname="pt" w:st="on">16pt, CC TK-ORCvalue="161" unitname="a" w:st="on">161 A-B Relay Output Module, 16 Channel, CC TK-ODJ161 DC Output 24vdc value="16" unitname="pt" w:st="on">16pt, Coated TK-FXX131 Conformal coated 13 Slot Chassis TK-FXX132 CHASSIS, 13 SLOT COATED 13 AMP TC-FCCR01 ControlNet Gateway, Redundant, RIOM-A TC-ODX161 DC Output Module 10-30vdc value="16" unitname="pt" w:st="on">16pt (diag), CIOM-A TC-ODKvalue="161" unitname="ac" w:st="on">161 AC Output Module 120/220vac value="16" unitname="pt" w:st="on">16pt, CIOM-A TC-RPFM01 CNet Repeater Fiber Optic (value="3000" unitname="m" w:st="on">3000M) FM TC-FXX172 17-Slot Chassis, 13 Amp TC-FPDXX2 24Vvdc Pwr Supply TC-FPCXX2 120/240vac Pwr Supply TK-ODX161 DC Output 10-30vdc value="16" unitname="pt" w:st="on">16pt, Coated TK-ODKvalue="161" unitname="ac" w:st="on">161 AC Output 120/220vac value="16" unitname="pt" w:st="on">16pt, Coated TC-RPDXX1 24 VDC Redundant Power Supply TC-RPCXX1 120/240 VAC Redundant Power Supply TC-FIL081 8 Point Thermocouple Module, RIOM-A TC-FIR081 8 Point RTD Module, RIOM-A TC-RPA002 ControlNet Repeater Adapter FM TC-FFRP02 PWA, FIELDBUS RTP POWERED TK-FPDXX2 Power Supply, 24VDC, CC TK-FPCXX2 ConFORMAL COATED 120/240VAC PWR SUPPLY TK-ODXvalue="81" unitname="ac" w:st="on">081 AC Output 120vac value="8" unitname="pt" w:st="on">8pt, Coated TC-IAH161 AI 16 Module (single or 8 diff.), CIOM-A 51404351-175 Pulse Input, 8 Ch In/2 Ch Out CC 51204146-500 ControlNet Trunk Cable (value="500" unitname="m" w:st="on">500M) TK-RPDXX1 24 VDC Redundant Pwr Supply, Coated TK-RPCXX1 120/240 VAC Redundant Pwr Supply, Coated TK-IAH161 AI 16 Module, CIOM-A, Coated TC-ODXvalue="81" unitname="ac" w:st="on">081 AC Output Module 120vac value="8" unitname="pt" w:st="on">8pt (diag), CIOM-A TC-CCR014 PWA, CNI CARD RED MEDIA TC-IAH061 Analog Input value="6" unitname="pt" w:st="on">6pt Module, CIOM-A TC-OAV081 AO Module value="8" unitname="pt" w:st="on">8pt (4-20ma & 10V), CIOM-A TC-PIA081 Analog Input value="8" unitname="pt" w:st="on">8 pt, RIOM-H TK-OAV081 Analog Output value="8" unitname="pt" w:st="on">8pt, CIOM-A, Coated TK-IAH061 Analog Input value="6" unitname="pt" w:st="on">6pt Module, CIOM-A, CC TC-IXR061 RTD Input Module value="6" unitname="pt" w:st="on">6pt, CIOM-A TC-IXL062 PWA, THERMOCOUPLE INPUT value="6" unitname="pt" w:st="on">6PT CIOM-A TC-HAI081 Hart A/I Module TK-IXL062 PWA, THERMOCOUPLE INPUT value="6" unitname="pt" w:st="on">6PT CIOM-A CC 9904-RPTD Control Net Repeater Coax, 24VDC TK-IXR061 RTD Input value="6" unitname="pt" w:st="on">6pt, Coated TK-IXL061 PWA, THERMOCOUPLE INPUT value="6" unitname="pt" w:st="on">6PT CIOM-A CC TK-HAI081 Hart A/I Module, CC 1757-SRM/B PROCESSLOGIX REDUND MOD. TC-OAV061 Analog Output Module value="6" unitname="pt" w:st="on">6 pt (10V), CIOM-A TC-OAH061 Analog Ouput value="6" unitname="pt" w:st="on">6pt Mod (4-20MA) CIOM-A TK-OAH061 Analog Ouput value="6" unitname="pt" w:st="on">6pt (4 - 20ma), CIOM-A, CC 51403420-275 MODULE, FIELDBUS INTERFACE ASSY CC TK-OAV061 Analog Output value="6" unitname="pt" w:st="on">6pt (10v), CIOM-A, Coated 51196398-100 2504 TERM SERVER TC-HAO081 Hart A/O Module TK-HAO081 Hart A/O Module, CC 1757-CN2FF Fieldbus linking Device 51198110-001 FF CONFIG,SINGLE ISA 51198111-001 FF CONFIG,PCMCIA,SNG 1757-PIM/A PROCESSLOGIX PI MODULE 1757-PLX52/A PROCESSLOGIX ConTROLLER MOD ASSY, PLX52 (A-B) 1757-SRM/A PROCESSLOGIX RED MODULE 51191311-100 Surge Suppressor 51191782-100 TRANSCEIVER 51192418-100 Connector, 75 Ohm 51192419-100 Connecter, BNC Barrel (Qty 2) 51195583-350 PCDM CABLE, value="50" unitname="ft" w:st="on">50FT ConNECT HIWAY TO PCDM 51195947-200 DB78 - (8)DB25 51198983-105 CABLE, SIM 5 METERS LONG 51198983-110 CABLE, SIM 10 METERS LONG 51202300-100 PROVOX Cable Assy. value="10" unitname="m" w:st="on">10m 51202301-100 PROVOX Cabble Assy value="10" unitname="m" w:st="on">10M 51202302-100 PROVOX Cable Assy value="10" unitname="m" w:st="on">10m 51202302-200 Provox Cable Assy value="20" unitname="m" w:st="on">20m 51204120-100 value="1" unitname="m" w:st="on">1M FB COMM Cable 51204120-200 value="2.5" unitname="m" w:st="on">2.5M FB COMM Cable 51204120-300 value="5" unitname="m" w:st="on">5M FB COMM Cable 51204120-400 value="10" unitname="m" w:st="on">10M FB COMM Cable 51204123-100 PROVOX Cable Assy value="5" unitname="m" w:st="on">5m 51204123-200 PROVOX Cable Assy value="10" unitname="m" w:st="on">10m 51204124-100 PROVOX Cable Assy. value="10" unitname="m" w:st="on">10m 51204146-001 ControlNet Trunk Cable (value="1" unitname="m" w:st="on">1M) 51204146-003 ControlNet Trunk Cable (value="3" unitname="m" w:st="on">3M) 51204146-010 ControlNet Trunk Cable (value="10" unitname="m" w:st="on">10M) 51204147-003 Redundancy Cable, value="3" unitname="m" w:st="on">3M 51204147-010 Redundancy Cable 10 Meter 51309241-175 PWA, BATTERY EXTENSION MODULE CC 51309283-300 PCM Mod Assy, Hon RM 51309288-375 PWA, REDUNDANCY MODULE CC 51309512-175 FTE Bridge Module, CC 51309516-125 SIM Power Adapter Assembly 51309516-175 FTA, SIM POWER ADAPTER CE CC 51309516-275 FTA, SIM POWER ADAPTER ASSY CE, CC 51309582-225 FIM, Redundant RTP, Unpowered 51403427-275 MODULE, I/O LIM ASSEMBLY 51403444-125 PROVOX Transition PWA 51404305-325 PWA, C200 ConTROL MOD CE (TC-PRS021) 51404305-325 PWA, C200 ConTROL MOD CE (TC-PRS021) 51404305-375 PCM ASSY, CE CC 51404391-275 PWA MODULE, SERIAL INTERFACE CC TC-CCN014 PWA, CNI CARD SGL MEDIA TK-CCR014 PWA, CNI CARD RED MEDIA CC 51196982-910 Filler Plate 51305424-100 Cable, DC Y-Power 51199478-100 VELCRO, ICON RECLOSEABLE FASTNER value="6" unitname="in" w:st="on">6 IN 51198718-910 Filler Plate 51197103-109 KIT, RETROFIT GUS IKBIvalue="2" unitname="F" w:st="on">2 F/W 97-03/99-02 51190921-110 Pwr Cord, 110V, value="3" unitname="m" w:st="on">3M 51305482-502 CABLE, value="2" unitname="m" w:st="on">2M 100 base T WHITE BOOT 51308003-300 AIR FILTER 51305482-503 Cable, CAT5 ScTP Ethernet w/White Boot, value="3" unitname="m" w:st="on">3M 51305557-100 CABLE, POWER 220V 51197015-400 Touchscreen Buttons (Set of 4) 51199581-907 Fan and Heatsink for WKS2/SVR2 CPU 51305567-100 Power Cord, 120VAC 51403224-100 BRACKET, LCNP PWA 51305562-402 Cable, 100base T, Black Boots, 2 Meter 51305752-106 EIDE Adapter Cable 51308125-100 CBL, CART DR PWR 51305381-100 CABLE, IKBI2 PS/2 KYBD value="18" unitname="in" w:st="on">18IN 51153979-100 ADAPTER, USB TO PS/2 51403655-100 WKS1/SVR1 Alignment Fixture, Classic Console 51305384-100 Cable, Console AC, value="28" unitname="in" w:st="on">28in 51305724-100 Cable, MIM USB 51305450-900 PWR CORD, AC value="3" unitname="m" w:st="on">3M 51305707-100 Cable, Keyboard I/F 51403260-100 Bracket, Pwr Entry 51305538-100 DESKSIDE CD SCSI CBL 51305381-200 CABLE, IKBI2 PS/2 KYBD value="72" unitname="in" w:st="on">72IN 51305711-100 Cable, PS/2 51305482-510 CABLE, value="10" unitname="m" w:st="on">10M 100 base T WHITE BOOT 51305544-300 POWER CORD 51196972-100 SCSI Adapter 51305543value="300" unitname="a" w:st="on">-300 A/C POWER CORD 51305482-110 CABLE, value="10" unitname="m" w:st="on">10M 100 base T YELLOW BOOT 51305482-210 CABLE, value="10" unitname="m" w:st="on">10M 100 base T GREEN BOOT 51305482-505 Cable, CAT5 ScTP Ethernet, Wht Boot, value="5" unitname="m" w:st="on">5M 51199954-100 Adaptor Cable, USB 2.0 to IDE, value="10" unitname="in" w:st="on">10in 51308107-100 Cable, Annunciator 51305489-400 Pwr Cord, EC/Shield, 240V, value="3" unitname="ft" w:st="on">3FT 51192887-100 Adapter, ST-SMA 51305489-500 Pwr Cord, EC/Shield, 240V, value="4" unitname="ft" w:st="on">4FT 51305544-200 POWER CORD 51403687-100 Filter frame 51305543value="200" unitname="a" w:st="on">-200 A/C POWER CORD 51305742-100 Cable, EIDE Adaptor, value="15" unitname="in" w:st="on">15in 51305730-100 Cable, Horiz Sync Adj. 51305070-200 CBL, SCSI W/DAT 51305070-202 SCSI CBL 51305482-520 CABLE, value="20" unitname="m" w:st="on">20M 100 base T WHITE BOOT 51305739-100 Mouse Cable, non-CE 51305729-100 Cable, Y 51305418-200 Cable, TPS100 OEP Kybd 51195124-500 Fan Assy 51199171-913 Fan Assembly 51305380-100 Cable, MAU, EC 51305418-300 TPS100 OEP KBD CBL 51305785-100 ADAPTER, LEGACY KYBD/TOUCHSCREEN 51305547-100 RT ANGLE CASCADE CBL 51199473-100 USB Mini Hub Plus, 4 Port 51305783-200 Cable, USB/IKB Annunciator, value="5" unitname="ft" w:st="on">5FT 51196694-928 PS/2 IKB Trackball Firmware Upgrade Kit …
honeywellC200系统:TC-MDP081,TK-IXR061,TK-ODD321,TK-IDD321
honeywellC300系统:CCTAIM01,CC-TAOX01,CC-PDOB01,CC-TAIX01
