全自动油墨旋转混油机
型号:MDP-30A
适用范围:0.5升-20升桶装涂料及油墨
适用混合桶的高度范围:70mm-390mm ,直径小于或等于300MM范围内
公转旋转速度:60-200r/min
自传旋转四度:120-400 r/min
工作电压:220V 50Hz
功率:0.75KW
净重:187Kg 毛重:228Kg
机器尺寸:1010(高)×860(宽)×710(深)mm
包装尺寸:1095(高)×900(宽)×800(深)mm
优越性能:
每次开机自动运行自检程序,直到机器各部件满足起动要求才可运行,
如有异常,控制器自动通过数码显示及蜂鸣器输出提示,要求重新复位(复位工作机器自动完成),确保机器安全运行。
全数码显示实时运行状态或运行时间,保证操作者清晰了解运转情况,机械内容器支承台可平稳移动和固定,应用时省时省力。
自动判别桶状容器的容量类别,输出适合旋转混合速度。
混合时公转,自转全方位同时进行。
多段智能变频调速,运行时快慢控制输出恰到好处,确保运行平稳。
开门停机保护装置,安全可靠!
高速彻底的混合,采用上下前后连续多抖式运转。
Technical date:
Applicable range:0.5-20L(paint in drum)
Height in the drum:70mm to 390mm
Revolution speed:60-200r/min
Rotation speed:120-400 r/min
Power supply:750W
Net weight:187Kg
Cross weigth:228Kg
Case size:1010(H)×860(W)×710(D)mm
Packing size:1095(H)×900(W)×800(D)mm
Feature of MDP-30A
Start self-checking program automatically before operation, In case of any abnormality,the controller will activate alarm through digital display and buzzer will sound.
Digital display will show the actual time set and time used,so that the operators may have exact mixing time idea foe better result.
Easy moving of fixing of interior case support.
Automatic identifyin size of the drum to offer adequate clamping power and rotaing speed.
Automatic clamping and open setting ,revolution and rotation may start synchronously during paint mixing.
Multi-grade intelligent timing inverter,adequate speed control ensures the machine works steadily.
