全自动油墨振荡混油机简介
型号:MDP-30C
适用范围:0.5升-20升桶装涂料及油墨
适用混合桶的高度范围:90mm-380mm
振荡时间选择:60/120/240秒
振动频率:680-710次/分
主电机功率:750W
电机转速:1400转/分
工作电压:220V±10% 50Hz 10A
净 重:210Kg 毛重:245Kg
机器尺寸:1060(高)×760(宽)×825(深)mm
包装尺寸:1125(高)×800(宽)×830(深)mm
优越性能:
外形小巧,占地面积小!
由主振器,容器压盖和PLC微电脑及积体电路设计组合成,全自动控制. 最大载荷重量为35Kg。
自动脱开—可随意选择调节混匀时间,使用寿命长。
自动加紧,可根据不同规格的涂料桶自动施加不同的压力,操作过程中不会出现压坏,压榨涂料桶的现象。
Technical date:
Applicabie range:0.5L-20L(paint in drum)
Height in the drum:90mm to 380mm
Shaking time:60/120/240s
Shaking frequency:680-710t/min
Power:750W
Speed:1400r/min
Power supply:220V±10% 50Hz 10A
Net weight:210kg Gross weight:245kg
Case size:1060(H)×760(W)×825(D)mm
Packing size:1125(H)×800(W)×830(D)mm
Small size,save space.
Compose with main vibrator,container press cover and microcomputer controller and so on,is suitable to 0.5-20L all kinds of can/barrel.
Max load weight is 30kg.
With PLC micro-computer control---can choose and readjust the shaking time freely ,with long use life span.
Automatic clamp and bring different pressure to bear on the according to the can size,will not squish or stave the can.
High speed and thoroughly mixing---with up and down, front and back continuous multi-shake movement.
