| 供电电压voltage:1.8V~5.5VDC | 表面硬度surface hardness:≥6H(钢化玻璃面板Tempered glass panel) ≥3H(PET面板PET panel) |
| 输入方式:导电金属笔或者手指 Input mode: conductive metal pen or finger | 寿命:大于100万次 lifetime: over 1 million times |
| 触点抖动时间:≤15ms(各家IC参数有差异)Contact jitter time:≤15ms(different IC parameters are different) | 操作压力:电容感应,无需操作压力 Operation force:capacitive sensing,no operation force is needed |
| 操作温度Operation temperature: -40°C~+85°C (产品表面不结冰的情况下on the condition that the surface of the product is not frozen) |
储存温度Storage temperature:-40°C~+85°C |
| 面板种类: 普通玻璃,化学强化玻璃,钢化玻璃,PC板, 亚克力板PET 客户塑胶机壳Type of panel: Common glass, chemically strengthened glass, tempered glass, PC board, Acrylic PET customer's plastic case |
玻璃厚度glass thickness:0.55mm、0.7mm、1.1mm PET厚度 PET thickness:0.188mm,0.25mm PC板、亚克力根据需要厚度不等thickness of PC board and acrylic is different according to different need |
| Sensor材料: ITO Film、ITOGlass、FPC线路、PET印刷导电油墨 Sensor material:ITO Film、ITOGlass、FPC circuit、PET conductive ink printing |
双面胶: 3M胶/OCA光学胶 Double-sided adhesive: 3M adhesive /OCA optical adhesive |
| 支持操作系统: Android,Linux,Windows,单片机 Support operating system: Android, Linux Windows, microcontroller |
| 通讯接口类型: IIC或按键一对一输出Communication interface type: IIC or output one to one |
通过中国触摸屏网金牌会员认证
