IPC-BX7102
Robust, Fanless Box PC with Intel Pentium M Platform
盒式工控机IPC-BX7102
无风扇设计
宽幅直流电源输入
加固防震动设计
丰富的载板I/O接口,PCI × 2
易安装维护
IPC-BX7102
盒式工控机IPC-BX7102
无风扇设计
宽幅直流电源输入
加固防震动设计
丰富的载板I/O接口,PCI × 2
易安装维护
系统
CPU Support Intel Celeron M/Pentium processor up to 1.8GHz
with 400MHz FSB
Memory 2 x 240-pin DDRII DIMM 400MHz up to 2GB
Chipset Intel 910GMLE + ICH
Graphics Integrated with Intel Graphics Media Accelerator (GMA900)
ATA 1 x Serial ATA ports with 150MB/s HDD transfer rate
1 x 44-pin IDE interface, support UDMA33 IDE device
LAN Chipset 2 x Realtek RTL
WatchdogTimer 1~255 level reset
输入/输出接口
Serial Port 1 x DB44 female connector
Support 4 x RS-232 ports + 1 x 4-bit GPIO
(1 x RS-422/485 port shared with COM2)
USB Port 6 x USB 2.0 ports
LAN 2 x RJ45 ports for GbE
KB/MS 1 x 6-pin Mini-DIN for Keyboard and Mouse
Video Port 1 x DB15 female connector for Analog Output
Selectable Port Either of DVI or digital I/O or LPT
DVI-D: Female connector for Digital Video Output
Digital I/O: 12-bit,
LPT: SPP/EPP/ECP mode
Audio
Expansion Bus 2 x PCI slot w/ riser card
1 x Mini-card slot
环境
Operating Temp. -20 ~
Storage Temp. -40 ~
Relative Humidity 10 ~ 95% @
Vibration
MIL-STD
Shock & Crash
Operating
Operating
Crash
认证
CertificationCE, FCC
电源
Power Input DC 10V~28V input (w/ 4-pin DC input terminal block
combine remote power on/off switch)
Power Consumption 50W (Max.)
存储
Type 1 x 2.5" drive bay for HDD/SDD
1 x CompactFlash Type II socket
结构
Construction Aluminum alloy
Mounting Support wall-mounting
Weight
Dimensions (Wx D x H) 195 x 268 x
