联系人,詹小姐,电话:0592-5136448 13606061466 传真:0592-5136281,QQ:254771272
静电容式近接开关:1 SN04-N NPN.NO;感应距离4mm 2 SN04-N2 NPN.NC;感应距离4mm 3 SN04-P PNP.NO;感应距离4mm 4 SN04-P2 PNP.NC;感应距离4mm 5 SN05-N NPN.NO;感应距5mm 6 SN05-N2 NPN.NC;感应距离5mm 7 SN05-P PNP.NO;感应距离5mm 8 SN05-P2 NPN.NC;感应距离5mm 9 SN10-KP2 NPN/PNP;NO/NC共用;感应距离10mm 10 SN20-KP2 NPN/PNP;NO/NC共用;感应距离20mm
瑞科圆型接近开关: 1 SC0801-N M8;NPN.NO;感应距离1mm 2 SC0801-N2 M8;NPN.NC;感应距离1mm 3 SC0801-P M8;PNP.NO;感应距离1mm 4 SC0801-P2 M8;PNP.NC;感应距离1mm
5 SC0802-N M8;NPN.NO;感应距离2mm 6 SC0802-N2 M8;NPN.NC;感应距离2mm 7 SC0802-P M8;PNP.NO;感应距离2mm 8 SC0802-P2 M8;PNP.NC;感应距离2mm
9 SC1202-KP2 M12;NPN/PNP;NO/NC共用;感应距离2mm 10 SC1204-KP2 M12;NPN/PNP;NO/NC共用;感应距离4mm 11 SC1805-KP2 M18;NPN/PNP;NO/NC共用;感应距离5mm
12 SC1808-KP2 M18;NPN/PNP;NO/NC共用;感应距离8mm 13 SC3010-KP2 M30;NPN/PNP;NO/NC共用;感应距离10mm 14 SC3015-KP2 M30;NPN/PNP;NO/NC共用;感应距离15mm
瑞科静电容接近开关: 1 KC1810-B3 M18;NPN;NO/NC;感应距离1-10mm 2 KC1810-P3 M18;PNP;NO/NC;感应距离1-10mm
瑞科光电开关: 1 MFDU30-KP2 M18;NPN/PNP;NO/NC共用;感应距离30cm 2 RMR2N-40金属 M18;NPN;NO/NC共用;感应距离40cm 3 MFR2-KP2 M18;NPN/PNP;NO/NC共用;感应距离2M 4 RMR4金属 M18;NPN;NO/NC共用;感应距离3M 5 MF5-KP2 M18;NPN/PNP;NO/NC共用;感应距离5M 6 RMTD-1000N M18;NPN;NO/NC共用;感应距离10M(对射) 7 RMTD-1000P M18;NPN;NO/NC共用;感应距离10M (对射) 8 SU-B3 U型;NPN;NO/NC;感应距离10mm 9 SU-P3 U型;PNP;NO/NC;感应距离10mm 光电传感器:MF-DU30KP2 SU-B3 MF5-KP2 MF10-KP2 MF15-KP2 MFR2-KP2 RMF-DU40N MMF-DU40N 环形光电开关:RQ36-KP2 电源控制器:ST-1 ST-T2
光纤传感器:FZ-KP2T VRF-SN 光FR-610 FR-610-I FR-610-M FR-610-L FRC-610 FRC-610-S FRC-610-M FRC-610-L FRH-610 FRS-410 FRS-410-S FRS-410-M FRS-410-L FRC-410 FRS-310 FRC-310 FRE-410 FRE-310-M FR-510 FT-410 FT-310 等等
聚焦镜:FL-03 FL-04等]FR—620,FRC—210—Q,FRC—210,FRC—310,FRC—410,FRC—610,FRC—610—I,FRC—610—S,FRC—610—M,FRC—620,FRS—210—Q,FRS—310,FRS—3
