EXP-640 带清洁段底片贴膜机
一、 特点:
1. 适用棕片及银盐片之贴保护膜。
2. 具有自带粘尘清洁装置及消除静电功能装置。
3. 采取铝合金属材料,永不生锈,美观耐用。
4. 辊轮同步性好,进口马达及同步带经久耐用。
5. 使用特殊张力调节系统,能很好地保持平整。
规格参数:
*型号:EXP-640
*贴膜宽度:580-660MM ( 23-26英寸)
*工作厚度:0.18MM-2MM
*速度0~8M/min可调
*电源: AC 220V 1¢50HZ 5A
*粘尘纸:620 X 2卷(不含在内,需方自购)
*净重:80KG
*机械尺寸:1300MM X 520MM X 560MM
EXP-640底片贴膜机现推出贴膜宽度为26英寸(660MM)供客户选择,价格有所差异!!
Memrane Sticking Machine’Features:
*The machine has the stiff dirt cleaning device and the device of getting rid of static selff to guarantee to be pasted negative
*The tension system of the exact centrifugal paper to be more smooty to be pasted mast
*Feet treading controlling negative,which making it moreconvenient to use progress and more easy to control and save the mast
Expensive protecting mast
*the design of the machine is excellent with reasonable
Structure and low rate of failure
*Applying in palm piece,silver salt piece and other pasting masts
Of slice production of unnecessary heating pasting mast
*Type:EXP-640
*Width of pasting mast:580-660mm (23-26 inch)
*Thickness of working:0.18mm-2mm
*Power supply:AC 220V 1¢50HZ 5A
*Stiff dirt paper:620mm X 2roll
*Net weight:80kg
*Dimension of machine:1300mm X 520mm X 560mm
