Supply Supply Supply Supply Supply
◤优势品牌:◥
◤优势品牌:◥
ABB Robots、FANUC Robots、YASKAWA Robots、KUKA Robots、Mitsubishi
Robots、OTC Robots、Panasonic Robots、MOTOMAN Robots等
ABB:工业机器人备件DSQC系列(中二中三,中四, S4C , S4C , IRC5)、Bailey INFI 90等。
Westinghouse(西屋): OVATION系统、WDPF系统、MAX1000系统备件Invensys Foxboro(福克斯波罗):I/A Series系统,FBM(现场输入/输出模块)顺序控制、梯形逻辑控制、事故追忆处理、数模转换、输入/输出信号处理、数据通信及处理等。
Invensys Triconex: 冗余容错控制系统、基于三重模件冗余(TMR)结构的最现代化的容错控制器。
Siemens(西门子):Siemens MOORE, Siemens Simatic C1,Siemens数控系统等
Bosch Rexroth(博世力士乐):Indramat,I/O模块,PLC控制器,驱动模块等。
Motorola(摩托罗拉):MVME 162、MVME 167、MVME1772、MVME177等系列
如果您有任何需要,我们能够解决您的缺损部分或交换,欢迎来电查询!
◤ advantage brand: ◥Supply Supply Supply Supply Supply
ABB Robots, FANUC Robots, YASKAWA Robots, KUKA Robots, Mitsubishi Robots, the OTC Robots, Panasonic Robots, MOTOMAN Robots, etc
ABB: industrial robot spare parts DSQC series (in the second three, four, S4C, S4C, IRC5), Bailey INFI 90 etc.
Westinghouse (Westinghouse) : OVATION system, WDPF system, MAX1000 system spare parts Invensys Foxboro (fox polo) : I/A Series system, FBM (field input/output module) sequence control, ladder logic control, accident recall processing, d/A conversion, input/output signal processing, data communication and processing, etc.
Invensys Triconex: redundant fault-tolerant control system, based on the triple modular redundancy (TMR) structure of the most modern fault-tolerant controller.
Siemens (Siemens) : Siemens MOORE, Siemens Simatic C1, Siemens numerical control system, etc
Bosch Rexroth (Bosch Rexroth) : Indramat, I/O module, PLC controller, drive module.
Motorola (Motorola) : MVME 162, MVME 167, MVME1772, MVME177 series etc
If you have any need, we can solve your defect part or exchange, Welcome to call or letter advice, negotiate!
联系人:陈楚君
电话:0592-5173279
传真:0592-5165561【请备注“陈楚君”收】
Q Q :1795930027
Contact:Luna
TEL: 0592-5173279
FAX: 0592-5165561(Please make out Luna receive)
QQ: 1795930027
Email: 1795930027@qq.com
Web: http://www.zxdadsqc.com
Address:A unit eighteen layer ,East Lake Building,Siming Lake,Xiamen City.
Flex-Core 2000/5 Amps 仲鑫达专业销售
Phcenix Contact FL Switch SF 8TX Ord No. 2832771 仲鑫达专业销售
TDK ZRAC2210-11 Noise Filter 仲鑫达专业销售
7044-9010 DX Series Rev B Board 仲鑫达专业销售
OMRON SOLID STATE RELAY G3PB-245B-VD 仲鑫达专业销售
Allen Bradley AB H010 1492-CB1 仲鑫达专业销售
VOCMOD 000684 Board 仲鑫达专业销售
