联系方式
公司名:厦门鑫盈宇自动化科技有限公司
联系人:方成龙
商务QQ:2232804221
手机: 13799254562
邮箱:2232804221@qq.com
地 址:厦门市思明区嘉禾路297号之一1003单元
销售原装进口全新有保质期的停产淘汰老型号产品
SIEMENS低压电器产品,包括尚未取得3C(CCC)认证的产品.
熔断器 接触器 继电器 变压器 断路器 传感器等等, 包括尚未取得3C(CCC)认证 的均为依法原装进口。
3RG6013-3AD00 \SIMATIC PXS210 SONAR SEN
6ES7131-1BH00-0XB0 \ET200L, EL-BLOCK, 16
6ES7141-1BD30-0XA0 \ET200X, EM141, 4DI,
6ES7413-1XG01-0AB0 \SIMATIC S7-400, CPU
6ES7414-1XG01-0AB0 \SIMATIC S7-400, CPU
6ES7414-2XG01-0AB0 \CPU414-2DP, MPI/DP,
6ES7421-5EH00-0AA0 \SM421, 16DI, AC120V,
6ES7422-1FF00-0AA0 \SM422, 8DO, 120/230V
6ES7422-5EH00-0AB0 \SM422, 16DO, 20-120V
6ES7952-1KS00-0AA0 \SIMATIC S7, MEMORY C
6GK1610-0TA01 \SIMATIC HMI, MOBIC T8, E
6GK7343-1BA00-0XE0 \COMMUNICATION PROCES
3SB3305-0AA21 \COMPLETE UNIT, SQUARE
6FM1480-6KB30-1AA0 \N GRACIS PROCESS OPE
6FX6002-5AA51-1BA0 \STEPDIRVE C and moto
C98043-A1204-L24 \W40 DC MAIN SPINDLE DR
6FM2805-1WB00 \CONTINUOUS PATH CONTROL
6FC5260-4FX08-1AB0 \REMOTE HOST V4.1
EWN:1702022001000 \N/BUILT-ON-FLANGE 1 P
EWN:3333028463000 \N/CNNCTR CMPLT 1FT604
EWN:1291118002000 \N/ENDSHIELD BS 1FT610
GWE:670411500000-Q1 \HALTELEISTE EINGANG
GN735A \INT.MASCH.STEUERTAFEL 7M
3NA7803-6 \LV HRC FUSE
34242350A \Assem-Pendant, TC, Eng,
34242400A02 \FOR SERVICE
34242374A01 \FOR SERVICE
34242383A01 \WS CPU board
34242290A02 \Assem-WSCPU, P5-200, 64
34242383A \Assem-Hard Drive, 10.2 G
35421339A \FOR SERVICE
D40008-W1212-Z6 \Label
D4844-W925-F \Label
C97500-Z1002-C15 \Edgr Guard
C98130-A1234-C572 \Hanging
5SX2506-6 \CIRCUIT BREAKER T55 6KA
5SF6215 \SR60-BASE DIAZED DIII 3
GN711B \MESSKREIS TEILBESTUECKT
GWE:000000580555 \WID,MET-SHT- 0204 50
6FX1126-1AA01 \FOR SERVICE
N-000000130898 \DIODE,Z-AX- ,BZX97/C15 ,
N-000000174102 \DIOD,Z-AX- BZX97/C16 5
N-000000185504 \Diode,611 repair
D439_BM5-04 \nut
GN726A \FOR SERVICE
C98121-S1002-C12 \Base
GWE:000000174102 \DIOD,Z-AX- BZX97/C
D912_M6X18/01 \Head Screw
D125_A4.3/04 \Scheibe Din
GWK:10545270 \SCREW
1323105800
1323120900
A5E01065612 \Warnhinweisschild
248187 \Accessory
261071 \Accessory
N-A5E00144275 \Warnschild Power Section
N-A5E00144276 \Warnschild UE S1 Setting
GWE:000000398792 \RM5 47U 50V 2000H 85C
N-462008013500 \GWE-462008013500 BRUECKE
1385108300
217703
GWE:A5E00162546-Q1 \Abstandsstueck M4x13
N-000000642363 \DIOD,Z-SUP-SMD SM6T200A
A5E00104028 \ISOLATION socket
1366192000
Accessory
MS122 \FOR SERVICE
570.844.0895.23 \FOR SERVICE
570.844.0894.23 \FOR SERVICE
462010906182 \FOR SERVICE
3NA3136-6 \LV HRC FUSE
6FC5598-4AA31-3RP0 \6FC5598-4AA31-3RP0
6FC5597-4AA31-3RP0 \6FC5597-4AA31-3RP0
N-231897000167 \TRANS,PNP- BDP948
500000087775 \Accessory
A5E00259974 \WARNSCHILD_HEISSE_OBERFL
GWE:000000295188 \KOND,EL-AL- RM2,5 2
6FC5253-6BX40-4AG3 \PC/PG HMI_ADVANCED C
N-231897000229 \TRANS,NPN- BDP947 SOT-
3SB3901-0AC \ACCESSORIES FOR 3SB3
A5E00151061 \cable support
A5E00475064 \CONTROL BOARD
A5E00104035 \support
A5E00115667 \support 37
GWE:A5E00162545-Q1 \Abstandsstueck M4x37
D7603_A14X18_CU \connectors
1323126300
1323125800
1323125900
EWN:0000217465000 \spring washer
5SH5416 \NEOZED SPECIAL ADAPTER D
GWE:000000581686 \DIODE SMD 1000V 1
GWE:000000582882 \KOND,EL-AL- RM2,5 4
GWE:A5E00111556-Q1 \Abstandsstueck M4
5SH5400 \NEOZED RETAINING SPRING
GWE:A5E00111744-Q1 \Abstandsstueck M4x35
A5E01065611 \Warnhinweisschild UE/UEB
3SB1901-3AA \IN
GWE:462008020100 \ABDECKUNG
221516 \Accessory
1385120300
5ST2155 \END CAP F. FOR SS 1+2PH
5SE2225 \NEOZED FUSE
5SE2325 \NEOZED FUSE
GWE:000000583872 \OPTO-KOPPLER QCPL-45
GWE:462008013500 \BRUECKE
A5E00115670 \support 49
A5E00273612 \A5E00273612
A5E00277004 \A5E00277004
N-462118000810 \GWE-462118000810
3RV1917-7A \CONTACTOR SOCKET
A5E00276959 \A5E00276959
F_28X14.2X1.25 \Disc spring 28x14,2x1,25
5SH4362 \NEOZED SCREW CAP PORZ.D0
C98130-A1234-C491 \Spacing roller
A5E00175372 \connector FEMALE_4pole
3SB3925-0AV \PLATE HOLDER/17.5X28MM/R
8WA1805 \END RETAINER, STEEL
C98130-A1234-C585 \Mounting
5SE2825 \SAFETY COMBINATION, SIGU
1932118700
C79298-A3238-C248 \flap
3RT1922-2D \MECH. CONNECTOR FOR 3RT1
C98130-A1234-C490 \Thread base plate
E_5_10/9ZY \sensor clamps
D-220971 \cable
3LD9286-1A \FRONT LABEL GE/EN F. 3LD
3SB1902-0AR \ACCESSORY F.3SB1 BLIND P
A5E00174082 \ISOLATION
C98130-A1235-C690 \Spacing roller
GWE:000000576900 \KUE-KOERP KL-196/
A5E00262340 \A5E00262340
GWE:000000132696-V2 \Abstandsstueck M3X
3RV1917-5A \PLUG CONNECTOR,
3RA1911-2A \CONNECTING MODULE (EL.)
C98130-A1234-C492 \Spacing roller
GWE:000000385823 \SFH6106-2
GWE:000000107953-Q1 \Abstandsstueck M4X
N-A5E00342534 \IC GATE_ARRAY_SIDU04_IGBT
5SH320 \D-TYPE ADAPTER SCREW DII
3LD9221-0A \TERMINAL COVER 3P F. 3LD
GWE:A5E00157067-Q1 \Schienenhalter
5SA221 \DIAZED FUSE
A5E00156396 \OPTO_KOP_4fach_TLP281-4_
GWE:000000636241 \OPTO-KOPPLER QCPL-14
3LD9201-1A \TERMINAL COVER 4P F.3LD2
EWN:0304042208501 \O-Ring for power plug
A5E00175364 \connector FEMALE_8pole
EWN:0594033301000 \N/Gummipuffer
A5E00165497 \PE-TDB 2
E_6-6/01 \Cable
6FX1410-0CX57 \SINUMERIK
6FC9301-0BA \SINUMERIK
6ES5763-0AA11 \N bridging comb
3NW6001-1 \CYLINDRICAL FUSE GG 10X3
8WA1011-1PF00 \PE-TERM.2.5SQMM,2CONN.
GWE:A5E00269468 \EM-Brake Interface Modu
E_10-6/01 \Cable
GWE:000000569152 \DROSSEL NLC5650
3SB1400-0C \CONTACT BLOCK 22 AND 30
8WA1822-7EF25 \G FUSE,QUICK, 6.3A
N-000000587899 \PLUG_RECT_FEMALE_8P_ANG_
C98130-A1234-C579 \Cable channel
WKC:A5E00228825 \IC
EWN:0304042224000 \N/O-ring 100x2 1FK606
LZX:PT78704 \SOCKET FOR RELAYS
3RA1921-2F \AUXIL. SWITCH, LATERALLY
C98130-A1234-C580 \Cable channel
A5E00273602 \A5E00273602
6ES7194-1BA00-0XA0 \ET200, LABELLING PLA
3SB3921-0AA \delete
A5E00185201 \ISOLATION output PWB rec
A5E00262301 \A5E00262301
GWE:A5E00338013 \bridge X260
EWN:0304109705000 \Terminal box mat
3NA7836 \LV HRC FUSE
LZX:MT78750 \MINI-RELAY
C98130-A1234-C582 \Cable channel back
KLA_45R/8 \RING
3TX4490-3G \SURGE SUPPRESSOR VARISTO
LZX:PT570024 \PLUG-IN RELAY, 4 CO CONT
C97104-Z1001-C540 \RRU terminal
GWE:A5E00163026-Q1 \Verbindungsschiene
RG_175743_420 \Adjusting ring
GWE:A5E00165782-Q1 \Anschlussschiene
GWE:000000348334 \ISOLATION OB 4171 20
C98130-A1234-C581 \Cable channel
6FC3986-4DN \PLC OUTPUT MODULE
N-462018701000 \ZK-ABDECKUNG 50KPL 611A/
A5E00295918 \A5E00295918
3NA6822 \LV HRC FUSE
C98130-A1234-C578 \Bracket
C98130-A1234-C577 \Cover for electronic
A5E00142492 \cable transformer FS J
N-462008705002 \FRONTPLATTE 50KPL 611 RE
EWN:0304042238000 \O-ring/2pcs for 1FT61
A5E00262302 \A5E00262302
MTL_175391_2 \ Disc
EWN:0064053904000 \Torque brackets asyn
D-220126 \cable
NMA:A5E00702525 \Torque prop
A5E00093074 \A5E00093074
GWE:A5E00365967 \bridge X42/X41
GWE:A5E00366272 \bridge X260
GWE:A5E00422907 \terminal du/dt
GWE:462018701000 \ZK-ABDECKUNG (CRC) 50
C98130-A1234-C587 \Plastic Bar
6XV1820-5AH10 \FIBER OPTIC CABLE STANDA
3NA3803 \LV HRC FUSE
EWN:0304003615000 \O-Ring (DE)
3NA3822-6 \LV HRC FUSE
3RV1915-1AB \3-PHASE BUSBARS
3SB1902-2AH \Accessory
BUS_Q04115/01
GWE:A5E00104021-Q1 \Halteleiste FS G
3NA7824 \LV HRC FUSE
3SB2204-6BD06 \INDIC. LIGHT, YEL., W2X4
3SB2204-6BE06 \INDIC. LIGHT, GREEN, W2X
D-MA5E00163090 \form cable
NMA:1471108800 \Ring Gamma
A5E00100386 \cable MIVI - PSB 15
A5E00138314 \ISOLATION output inverte
A5E00162046 \ISOLATION output PWB 2x
GWE:000000575563 \IC INTERFACE SN 75LB
GWE:000000572891 \HDFK 10I NZ572891
A5E00142532 \grounding plate TDB
5UB0770-1NC1 \5UB0770-1NC1 5A 3polee
3SB3203-0AA21 \delete
A5E00124346 \DSA bridge 350mm
C97104-Z1001-C543 \RRU terminal
3NA3805 \LV HRC FUSE
576522501000 \Accessory
GWE:570790003100 \611 repair part
N-462008012600 \LTG,VERB-VSA/50 34POL 61
GWE:A5E00366274 \bridge X42/X41
C98130-A1234-C522 \Shaft
YAS:JZSP-CNB00-1 \N/ELECTRONIC CABLE
3SB3758-4AD11 \KEY SELECTOR SWITCH,
D-576522500400 \isolation paper
A5E00164515 \ISOLATION
YAS:JZSP-CNB00-2 \N/ELECTRONIC CABLE
3RT1926-1CB00 \RC-ELEMENT,
3RT1936-1CB00 \RC-ELEMENT,
A5E00297350 \A5E00297350
6FC5095-0AA10-0AP0 \LOG BOOK A
6ES7193-4CB70-0AA0 \ET200S, TERM.-MOD. T
3NW6305-1 \CYLINDRICAL FUSE GG 8.5X
M27C256B-12F1 \chip
3SB3217-6AA60 \COMPLETE UNIT, ROUND
3SB3244-6AA60 \COMPACT UNIT ROUND
GWE:462018701100 \ZK-ABDECKUNG (CRC) 100
3SB1400-0B \CONTACT BLOCK 22 AND 30
3NA3822-7 \LV HRC FUSE
A5E00150295 \connection bar precharge
D-576512505600 \ISOLATION PAPER
3RH1921-2FA40 \AUXILIARY SWITCH BLOCK,
A5E00164414 \ISOLATION heat sink belo
EWN:0000531044000 \shaft ring
3SB1902-2BN \ACCESSORY FOR 3SB3
A5E00167870 \ISOLATION PWB
GWE:A5E00322386 \ISOLATION heat sink bel
GWE:A5E00237204 \Clamping plate 2.8mm Fl
GWE:A5E00757592 \Simovert Masterdrive Fu
6ES7193-4CC30-0AA0 \ET200S, TERM.-MOD. T
A5E00294451 \A5E00294451
A5E00165484 \ISOLATION mounting plate
RS_233.2753 \socket
D-576512506100 \ZZZ
C98130-A1234-C519 \Cabel rod
EWN:0000251069501 \N/Bearings DE without
576522504200 \Accessory
YAS:JZSP-CGB02-11 \DC POWER BUS RAIL 100
3NA7252 \LV HRC FUSE
6FX4002-5CA21-1BA0 \Power cable
3TB4022-0XM0-Z \AC 9A 2NO+2NC 220V.
C98130-A1235-C677 \Mounting
A5E00165495 \PE-TDB 1
6FX6002-5AA51-1AF0 \N CONN. ELEMENTS CAB
C98130-A1235-C642 \Bar
EWN:0304003612000 \O-ring for encoder c
YAS:JZSP-CNB00-5 \ELECTRONIC CABLE (P1/N
3RT1916-1GA00 \ADDITIONAL LOAD,
A5E00180902 \support Minus bar
BTL_174416_2 \cap
3NC1091 \SITOR F SWITCH DISC. 1-P
6ES5497-4UA12 \490 FRONT CONNECTOR, 42-
C98130-A1235-C671 \Cover
3SB3201-2KA11 \COMPLETE UNIT , ROUND
A5E00295929 \A5E00295929
BAL/BES8.0/01 \BES 8.0-KH-2S KLEMMHALTER
A5E00295923 \A5E00295923
A5E00278267 \Impulsleitung 34/20pol R
576522500900 \Accessory
A5E00196175 \ISOLATION inverter
6FC5398-1CP10-3RA0 \NUMERIK.DOK 6FC5398
6SE6400-7AA00-0AJ0 \MICROMASTER 420/440
A5E00152553 \grounding plate 2 TDB
EWN:3334015103000 \N/COUPLER PLUG 1FT5
3SB3210-2DA11 \COMPACT UNIT, ROUND
6SN1162-0BA06-0AA0 \N FIXING BRACKET FOR
GWE:A5E00161796-Q1 \Isolierung Vorladewi
6FC9348-7AT \CONNECTOR FOR SIMODRIVE
GWE:A5E00124347-Q1 \DSA Bruecke 600mm
GWE:A5E00152630-Q1 \Luefterhalter RG28 F
3TH8244-0XM0-Z \AC 4NO+4NC 220V
C98130-A1235-C672 \Cover
3SE3200-8C \S4/POSITION SWITCH
A5E00161768 \PE bridge TDB
576522501200 \Accessory
GWE:A5E00161817-Q1 \Isolierung GR
5SD601 \DIAZED FUSE-
GWE:A5E00205710 \connection bar precharg
3SB3221-0AA61 \COMPLETE UNIT, ROUND
6ES7153-1AA00-8AA0 \SIMATIC DP, MANUAL F
GWE:N820.001.132B \fan cover
A5E00205009 \PE mounting
3TX4401-1A \AUXILIARY CONTACT BLOCK
MAP_MN5218-09 \HSKA-80 coolant pipe
3NA3372 \LV HRC FUSE
YAS:JZSP-CGB02-6 \N/DC POWER BUS RAIL
A5E00768515 \A5E00768515
A5E00150283 \TDB fastener minus
G33928-N1573-C4-A4-6 \G33928-N1573-C4-A4
3SB3247-0AA21 \COMPLETE UNIT ROUND
GWE:A5E00205708 \connection bar precharg
3NA3132 \LV HRC FUSE
A5E00105075 \USB-Docking FBG USB-Doc
GWE:A5E00138265 \adapter plate for ES100
3SB3000-4DD11 \ACTUATING ELEMENT, ROUND
A5E00292122 \terminal
6FX2003-0AA15 \STE LST,BU- KP 15POL M.G
3SB3647-0AA41 \COMPLETE UNIT ROUND
3SB3647-0AA61 \COMPLETE UNIT ROUND
3NA3820-6 \LV HRC FUSE
BAL/BES18,0/01 \BES 18.0-KH-2S KLEMMHALT
A5E00109806 \ISOLATION basic plate F
A5E00191604 \connection bar precharge
A5E00275143 \A5E00275143
3RT1956-1CE00 \SURGE SUPPRESSOR./RC ELE
3TX7004-1LB00 \OUTPUT INTERFACE
GWE:A5E00322313 \cable rectifier FS-F sy
ICP_61.159.23 \PIN
3NE1803-0 \SITOR S.-COND. FUSE 35A
EWN:0000251229000 \BALL BEARING DIN625-6
A5E00133679 \cable basic unit FSJ
YAS:JZSP-CGB02-5 \N/DC POWER BUS RAIL
6SN1162-0EB00-0BA0 \SHIELD PLATE 100MM 6
A5E00262343 \A5E00262343
GWE:A5E00096528-Q1 \WID_MET_OXI_4K7_+-3%
C98130-A1235-C714 \Bar
A5E00140505 \GAP PAD
LZX:MT323024 \PLUG-IN RELAY
6SE6400-0GP00-0AA0 \MICROMASTER 4 GLAND
A5E00165474 \Plus bar 2
A5E00165478 \Plus bar 3
A5E00178994 \fan carrier
A5E00255829 \A5E00255829
A5E00262357 \A5E00262357
GWE:A5E00171306-V2 \MM430
A5E00179971 \Plus bar 4
YAS:JZSP-CGB02-20 \DC POWER BUS RAIL 250
5SH5004 \NEOZED ADAPTOR SIZE D01
A5E00203312 \connection bar precharge
3TF4211-0XM0-Z \AC 16A 1NO+1NC 220V50Hz
3LD2103-0TK51 \MAIN SWITCH 25A/690V 400
EWN:8399501468000 \N/1PH713.KIT6.30DRIVE
EWN:0853006701000 \EWN:0853006701000
EWN:8399501438000 \N/1PH713.KIT6.30 END
EWN:8399501408000 \N/1PH710.KIT 6.30 END
D-576522500800 \ZZZ
A5E00179975 \TDB grounding 3
5SD602 \DIAZED FUSE-
SWC:SA5E00391580 \CU Interface Board FSB
N-462008701600 \KLEMENANSCHLUSS 95MM 2KP
3RA1911-1A \
576522500800 \Accessory
GWE:462018701201 \ZK-ABDECKUNG KPL. 1
GWE:A5E00342188 \cable power supply rect
95.100.848.5.5 \Sealing ring
C98130-A1235-C611 \Busbar
3TY7561-1AA00-Z \AUXILIARY CONTACT BLOCK
C98130-A1234-C529 \Cover
WDR_042/01 \Sealing Ring
A5E00179980 \cable extention R30
3SB3201-4AD11 /delete
N-462018000600 \GWE-462018000600 100MM F
EWN:0704161106000 \sleeve shaft
3RT1025-1AL20 \CONTACTOR, AC-3 7,5 KW/4
A5E00161601 \resistor 2K7_+-5%_115W
EWN:8399501731000 \N/1FT506.KIT
LEE_CCFM1550240 \Valve
A5E00172800 \transformer output compl
N-462008705413 \GWE-462008705413 611 REP
N-462008706001 \GWE-462008706001 611 REP
D-576522502000 \insulation SMV/SML
A5E00498144 \ISOLATION FOIL
A5E00179970 \customer terminal PE
6FX2006-1BG44 \MINIBHG_ADAPTER BOARD_F_
6EP1971-1BA00 \S7-300 INSTALLATION ADAP
6SL3200-0SF01-0AA0 \Fan FSA and FSB
GWE:475509500900 \Ribbon cable
6FC5247-0AA20-0AA0 \N HOUSING F. DISKETT
N-462008705202 \GWE-462008705202 FRONTPL
EWN:0302000005000 \surface seals
LZE:SLS-00000192 \METAL LAYERD RESISTANC
LZE:SLS-0000040 \LABELS
A5E00262349 \A5E00262349
5SX2104-5 \CIRCUIT BREAKER T55 6KA
C98130-A1235-C713 \Bar
C98130-A1235-C698 \Cover
GWE:A5E00161579-Q1 \SICHERUNG C14G1_1A_6
GWE:A5E00168268-Q1 \SICHERUNG C14M4_4A_6
6FC5598-1AC00-0RP0 \FOR SERVICE
C79298-A3238-B510 \Measuring Lead, 4mm
3ND1822 \LV HRC FUSE
A5E00272906 \A5E00272906
3NA7805 \LV HRC FUSE
C98130-A1234-C517 \Cover
6FC9344-2BB \ACCESSORIES F.SINUMERIK
GWE:A5E00339564 \cable rectifier FS-F sy
6GK1901-1BB30-0AB0 \IE FC RJ45 PLUG 145
N-A5E00157447 \Frontplatte 100 MM ER Kom
GWE462011970100 \FOR SERVICE
C67067-A2802-A20 \FOR SERVICE
N-462018000200 \GWE-462018000200 150 F.A
C98130-A1235-C659 \Bar
6ES7120-1AH00-0AA0 \ET200L-SC, ADD. TERM
GWE:A5E00336609 \cable power supply rec
EWN:0704161120000 \sleeve
95.600.411.4.1 \Screw
SWC:S1790L996-V2 \N MM44 IC Top Switch
WKC:A5E00162089 \Insulation_small
3NE4121 \SITOR S.-COND. FUSE 100A
C98043-A1600-L111 \FOR SERVICE
6FC9348-2FB \READY-MADE SIGNAL LEAD C
6SN1161-0BA06-0AA0 \N INFEED REGEN. FEED
GWE:231897000005 \N MM4344 DIOD-MOD MDD
EWN:1173000301000 \bearing cover for 1PH
N-462008705123 \GWE-462008705123 FRONTPL
C98130-A1235-C608 \Busbar
MU_174416_2 \NUT
3TX7004-3PB54 \OUTPUT INTERFACE,
6GK5795-1TR10-0AA6 \IMPEDANCE TI 795-1R
3NE8722 \SITOR FUSE-
D-032605 \FUSE;800V;80A
6ZY1080-1AA00 \BRIDGE RECTIFIER SKD 25/
3RH1131-1KB40 \COUPLING RELAY, 3NO+1NC,
3RH1122-1KB40 \COUPLING RELAY, 2NO+2NC,
3RT1016-1KB42 \COUPLING RELAY,
576529701300 \Accessory
3RA1931-1B \
3TF2001-0BB4 \CONTACTOR, SIZE 00, 3-P
D-576248700028 \flat cable
3TX7002-1BB00 \OUTPUT INTERFACE
GWE:A5E00447089 \adapter for ES2000
A5E00171124 \transformer output compl
8UC9253 \COUPLING PIECE F. 8UC6
GWE:A5E00468563 \cable sym. resistor FSF
6FC9340-8LY00-1AA5 \N/CABLE
6AV3972-1XB00-0AA0 \BACKUP BATTERY 3VDC,
A5E00158263 \ISOLATION sym. resistor
3NC1491 \SITOR F SWITCH DISC. 1-P
EWN:0853072105002 \motor cover for IP67/
YAS:JZSP-CMP9-1 \N/ CONN. ACCESSORIES
C98130-A1235-C697 \Cover
EWN:8399501732000 \N/1FT507.KIT
6FC9348-2TB \ZUBEHOER FUER SIMODRIVE
6ES7390-0AE80-0AA0 \FOR SERVICE
EWN:0852009505002 \motor cover for IP67/
3TF4511-0XM0-Z \AC 38A 1NO+1NC 220V50Hz
GWE:A5E00170488-Q1 \Stromschienensatz
D-576525010600 \CU BAR
3KX2231-1A \ACC. F. SWITCH 3KE42-45
A5E00152492 \Motor connection bar
GWE:A5E00173024 \1FK Starkverdrahtung
A5E00262299 \display
C98130-A1235-C630 \Axis
MAP_VEZ63-08 \ejector pin?
6ES7193-0CD40-7XA0 \SHIELD CONNECTION F.
6GT2090-0BA00 \SLG-CONNECTOR 6-POLE
A5E00088527 \DISPLAY PLATE
6FC9344-4XN \SINUMERIK 840C, VERB.KAB
C79298-A3238-C233 \Display foam
3RV1011-0CA10 \CIRCUIT-BREAKER 0.18...0
3RV1011-0FA10 \CIRCUIT-BREAKER, 0.35...
PFED_175003C_1 \fitting key big
3RV1011-0EA10 \delete
C98043-A1052-L1 \R0 PULSE TRANSFORMER MO
N-462008705512 \GWE-462008705512 611 REP
N-462018718096 \FORMABEL FOR REPAIRING
6GT2300-0BB00 \MDS E611 MOBY E EPOXY-CA
6SY7000-0AE88 \fan compact plus
MAP_SB80-09R \ Coolant hoses dummy plugs
EWN:0704136204000 \N/SLEEVE 1FT606
6ES7390-1AF30-0AA0 \SIMATIC S7-300, RAIL
6SL3200-0SF03-0AA0 \Fan FSC
3LD2504-0TK51 \MAIN CONTROL SWITCH 3-PO
3RN1000-1AB00 \THERMISTOR MOTOR PROTECT
6SL3262-2CA00-0AA0 \TERMINAL STRIP X9, B
EWN:0852001401000 \EWN:0852001401000
3NE1022-0 \SITOR S.-COND. FUSE 125A
5ST2545 \CABLE CONNECTOR, 2X100 A
6FC5597-2AA20-0RP0 \FOR SERVICE
3LD2504-0TK53 \MAIN/EM. STOP SW. 63A/69
3RH1262-1BB40 \CONTACTOR RELAY, 6NO+2NC
6ES7492-1BL00-0AA0 \FRONT CONNECTOR F. S
EWN:8399501715000 \N/1FT507.KIT GASKET S
C98130-A1235-C695 \Isolation
GWE:462008701600 \KLEMMENANSCHLUSS 95MM2
6ES5755-4AA11 \N-TYPE COAXIAL CONNECTOR
3NE1021-0 \SITOR S.-COND. FUSE 100A
A5E00097129 \resistor 2K7_+-5%_115W
3NE8020-1 \SITOR S.-COND. FUSE 80A
3RK1903-2AC10 \65MM TERMINAL BLOCK PEN
A5E00143631 \ISOLATION rectifier TDB
EWN:8399501420000 \N/1PH710 KIT8.30 BUIL
3NE1022-2 \SITOR S.-COND. FUSE 125A
A5E00175523 \cable TDB bridges FSH
GWE:462008500604 \IC STM-VERSORGUNG 611A
D-MA5E00163089 \form cable
6SL3352-7BH31-5AA0 \SICHERUNG_SONST_C14G
3NE1802-0 \SITOR S.-COND. FUSE 40A
EWN:1173000401000 \bearing cover for 1PH
C98130-A1234-C586 \Transportplate
3RV1011-1AA10 \delete
GWE:A5E00216335 \cable inverter PWB DC/A
A5E00255517 \24V-cable
EWN:0853072101002 \N/BRAKE EBD 1.2B;0.25
3NE8017-1 \SITOR S.-COND. FUSE 50A
3RG4014-0AA00 \SIMATIC PXI330 INDUCTIVE
GWE:A5E00338766 \ISOLATION
3RG4638-3AN01 \SIMATIC PXI440 INDUCTIVE
GWE:A5E00163088-V2 \FK FSG P.Bl.690V Sym
D-220130 \cable
3RT1017-1BB44-3MA0 \CONTACTOR, AC-3, 5.5
C79298-A3238-B203 \Batterie lid
A5E00768514 \A5E00768514
3NE8015-1 \SITOR S.-COND. FUSE 25A
3RG4142-6AD00 \SIMATIC PXI360 INDUCTIVE
3RT1026-1AP00 \CONTACTOR, AC-3 11 KW/40
A5E00145319 \Cursortaste FBG cursor
EWN:0853084501002 \N/BRAKE EBD 1.2B;0.25
YAS:JZSP-BA01 \BATTERY FOR SGDH
3RV1021-0EA10 \CIRCUIT-BREAKER, 0.28...
A5E00180151 \transformer cable FS H
6FC9340-8PB \SINUMERIK SIROTEC (ACCES
EWN:2923001101000 \Terminal
3RV1011-0CA25 \CIRCUIT-BREAKER, SIZE S0
6SC6500-0BA80 \Accessory
6SC6500-0BA00 \FOR SERVICE
3RV1011-0EA25 \CIRCUIT-BREAKER, SIZE S0
3RT1034-1AP00 \CONTACTOR, AC-3 15 KW/40
WU33D3023-2 \spacer ring
A5E00155427 \Motor outgoing bar V
8MR2170-1A \THERMOSTAT
D-576520004901
6ES7193-1FL20-0XA0 \ET200L, ADD.TERM. 1
EWN:0853084505002 \motor cover for IP67/
6FX2003-0SU10 \SIGNAL CONNECTOR,
3NA3824-6 \LV HRC FUSE
3NA3812-6 \LV HRC FUSE
3NA3814-6 \LV HRC FUSE
HUM_HSK_MZ/08 \CONNECTION
6FC5148-0AA01-0AA0 \N DUMMY FRONT PLATES
A5E00154296 \DC-bar FS G
GWE:A5E00207693 \cable sym. resistor DC
A5E00106361 \cable transformer FS J
3RV1021-1DA10 \delete
3RV1021-1EA10 \delete
3RV1021-1CA10 \delete
3RV1011-0HA25 \CIRCUIT-BREAKER, SIZE S0
N-462018007100 \GWE-462018007100 300 LT
C79298-A3238-C232 \disk drive foam
6ES7972-0BB40-0XA0 \SIMATIC DP, BUS CONN
EWN:8399501733000 \N/1FT510.KIT GASKET
MU_175338_1 \nut
U_MTL_174416_1 \anti twist device insert
A5E00162124 \ISOLATION
SCH_174791A_1
3NE1225-0 \SITOR FUSE-
6FX1116-6AA01 \R0 MS510-A,LOGIC MOD. 3,
JBK3-400W \TRANSFORMER
3NA3805-6 \LV HRC FUSE
3NA3807-6 \LV HRC FUSE
W75070-G1636-S64 \connector strip 64 pin
6ES7132-4BB00-0AB0 \SIMATIC DP, 5 ELECTR
N-A5E00238090 \Gehaeuse kpl. f. UE 5 Kw,
95.102.188.4.1 \COUNTER SCREW M20X1,5
6FX8002-2CP00-1AG0 \SIGNAL CABLE, PREASS
3RV1421-0JA10 \CIRCUIT-BREAKER, 0.7...1
3RV1421-1DA10 \CIRCUIT-BREAKER, 2.2...3
EWN:1874011801000 \Balancing disc (NDE)
3RV1011-0KA25 \CIRCUIT-BREAKER, SIZE S0
3RV1011-1AA25 \CIRCUIT-BREAKER, SIZE S0
EWN:0844085205000 \N/TERMINAL BOX UPPER
A5E00154828 \DC-bar
EWN:2923030001000 \signal leading for EQ
MTL_174416_3 \Rod
6FX2001-6AK12-0HA0 \ADAPTER BOARD 1
A5E00165492 \connection bar precharge
A5E00262296 \A5E00262296
3RV1011-1GA25 \CIRCUIT-BREAKER, SIZE S0
3RV1011-1CA25 \CIRCUIT-BREAKER, SIZE S0
3RV1011-1DA25 \CIRCUIT-BREAKER, SIZE S0
GWE:462018000600 \GEHAEUSE 100MM F
EWN:8399501455000 \N/1PH71..KIT 8.30BUIL
EWN:8399501450000 \N/1PH71.KIT 8.30 BUIL
3RP1513-1AP30 \TIME RELAY, ON-DELAY,
A5E00497965 \Displayblech (for new Di
GWE:A5E00322316 \cable rectifier FS-F sy
6FC5698-2AA20-0BP1 \NUMERIK.DOC 6FC5698
6ES5498-1AA51 \MEASURING RANGE MODULE,
6SL3362-2CA00-0AA0 \TRAG_KLEMME_ANREIH_2
A5E00179976 \Minus bar 2 rectifier
EWN:0853019102000 \N / DECKEL 1FK608./61
6FC9340-8MA \CABLE
6FX2001-7KF06 \COUPLING 6FX2001-7
6ES5760-0HA11 \TERMIN.RESIST.CONN. F. I
EWN:3834007005000 \temperature sensor
6FC9341-2AA00 \N SINUMERIK (ACCESSORIES
6ES5981-0FA11 \DUST FILTER HOLDER F. S5
6ES5981-0JA11 \DUST FILTER F. LONG RACK
C98130-A1235-C664 \Isolation
DK_175339_2
A5E00135278 \wiring harness
6FX8002-4AA41-1AD0 \SIGNAL CABLE, PREASS
SCH_176173_1 \pressure cover
6ES5498-1AA31 \MEASURING RANGE MODULE,
EWN:3333000811000 \signa plug
A5E00110425 \ISOLATION
6FC9348-5MF \SIMODRIVE 611 1FT5 (ACCE
3LD2704-0TK51 \MAIN CONTROL SWITCH 3-PO
6FX6002-5AA51-1AH0 \N CONN. ELEMENTS CAB
MMR30x1,5 \nut (draw bar rear end)
6FC5147-0AA04-0AA0 \N ELECTRONIC INTERFA
3NE1815-0 \SITOR S.-COND. FUSE 25A
6FX6002-3BA31-1AD0 \SIGC,ECU-STEPDIVE,3
EWN:1292480002000 \EWN:1292480002000
A5E00181688 \terminal bar output
GWE:A5E00321123 \cable rectifier FS-F sy
SWC:STR01980 \N MM42 Skip Module
FK_175176_2 \Spring cage
EWN:2923002301000 \signal leading for re
EWN:2923003071000 \Cable
WU33D3023-1 \spacer ring
6ES5981-0EA11 \DUST FILTERS F. S5-135U/
A5E00498390 \Flexplatine kpl. (for ne
GWE:A5E00163188-V2 \STR.SCH.SATZ/E/690V/
EWN:000251294000 \bearing
6ES5498-1AA71 \MEASURING RANGE MODULE,
MTL_174416A_5 \holder
SWC:STR01881 \N MM44 Modul20NAB12IT38
C98130-A1235-C617 \Busbar
EWN:0000531056000 \sleeve
A5E00112393 \wiring harness
A5E00135256 \wiring harness
GWE:462018000200 \GEHAEUSE 150 F
N-462118700102 \GWE-462118700102 50KPL.E
N-462118700105 \GWE-462118700105 50KPL.E
C98130-A1235-C616 \Busbar
A5E00168500 \TDB bridge
3RG4031-6KD00-2AA1 \PROXIMITY SWITCH BER
6SY7000-0AB75 \Fuse
MU_174686_1
3RT1036-1AP00 \CONTACTOR, AC-3 22 KW/40
A5E00165476 \Plus bar 1
RG_175391_6 \N/RING
6FC5253-7BX40-2AG3 \N/SOFTWARE
6ES5497-4UB31 \490 FRONT CONNECTOR, 42-
6SE7034-5UK84-1BH0 \STANDARD MODULE ABO
MTL_174416A_2 \holder
MTL_174416A_3 \holder
BUS_RS040/01 \TURC_STEPSEAL RS1500400-T4
3VL9400-8CB30 \ACC. F. VL400, TERMIN. C
EWN:3333032235000 \N/angle box complete
EWN:0854102002000 \motor cover for IP67/
6RB2110-0FD00 \FOR SERVICE
N-A5E00201816 \Gehaeuse 300LT UL,611 rep
MTL_174416A_6 \holder
GWE:462018000701 \GEHAEUSE 100MM F
WU33D3023 \Ring for Drawbar
6ES5755-3AA11 \TERMINATION RESISTOR
GWE:475502501800 \Isolation paper
GWE:A5E00647673 \cable sym. resistor FS
A5E00171308 \cable sym. resistor FSF
6FC9340-8NE \N SINUMERIK SIROTEC (ACC
6FX2003-1AA25 \N SIGNAL CONNECTOR
XZM:27000910470350 \REPAIRPART FOR MOTOR
D912_M4X12/01 \Screa Din
JC_SEZB17_V_3 \Connector
3RG4042-6KD00 \SIMATIC PXI350 INDUCTIVE
3SE3120-1C \S4/POSITION SWITCH
N-462018000701 \2*50A housing,611 repair
GWE:A5E00342197 \cable rectifier FS-G sy
EWN:2923002071000 \cable
EWN:0000995031000 \N/SEALING WASHER
6XV1830-1BH30 \830-1 CONNECTING CABLE 3
6FX6002-2CA31-1AD0 \Signal Cable 3M
RG_176024_3 \connec housing
EWN:0853080011000 \N/DECKEL BS 1FK604
MTL_174416A_4 \holder
3RP1527-1EM30 \TIME RELAY, ON-DELAY,
N-462008715596 \GWE-462008715596 FORMKAB
BES516-371-SA13 PU-00.5 \sensor
3RT1926-2EJ21 \SOLID-STATE, TIME-DELAYE
EWN:0854101001000 \N/BRAKE EBD 1.2B;0.25
EWN:0704156201000 \space sleeve for 1FT6
EWN:2923002451000 \Cable
EWN:2923002111000 \Cable
GWE:A5E00207354 \cable PWB
GWE:A5E00252095 \output bar transducer
6EP5306-5BG00 \CAB_SET_FRC_6M_50PIN A.
6FX5002-2CA31-1AB0 \SIGNAL CABLE, PREASS
6ES5490-7LB21 \490 FRONT CONNECTOR, 46-
3TH4262-0BB4 \CONTACTOR RELAY 62E EN 5
6SC6500-0UB02 \N P.C.B DISPLAY
EWN:1703138801000 \N/FLANGE FOR ROD 426
EWN:1703140801000 \N/FLANGE 1FT5030
EWN:0853002102000 \N/Cover for 1FT604
EWN:0853082601000 \N/COVER 1FT504
EWN:0853082401000 \N/COVER 1FT503
EWN:1174303301000 \N/ BEARING CAP
EWN:1703159601000 \N/ADAPTER FLANGE 1FT5
6SE7024-7UD84-1HG0 \FB1 MODULE 6SE7024-7
6SL3200-0SF04-0AA0 \PM250 FSD/E fan SUNO
BUS_RS055/01 \TURC_STEPSEALRS15005500-T4
C98130-A1235-C657 \Transportplate
3NA3360-6 \LV HRC FUSE
GWE:A5E00324361 \ISOLATION heat sink abo
6FC5698-2AA00-1RP4 \NUMERIK.DOC 6FC5698
6GK1970-1AA20-0AA0 \SIMATIC NET, MANUAL
6FC5698-2AA00-1BP4 \NUMERIK.DOC 6FC5698
C79298-A3238-B456 \IRDA-FBG, intern IRDA
HL_175391_3 \-RING 34X2-VITON
A5E00088240 \DVD-Adapter FBG DVD-Adap
A5E00160483 \MOD. FAN CPL 24V DC 45W
6FX2002-4AA31-0BF0 \N/SIGNAL CABLE
EWN:0853077005000 \motor cover for IP67/
BUS_PT075/01 \TURC_GLYDRING PT0200750-T4
EWN:2923003055000 \Cable
NMA:A5E00602210 \encoder cover
C98130-A1234-C570 \Side
C98130-A1234-C571 \Side
EWN:1703008301000 \Discplate
GWE:A5E00162372-V2 \Str.Sch.Satz PB-WR A
EWN:8399501565000 \N/1FK606 KIT 8.30 enc
3SE3902-0AA20 \FOOT-OPERATED BUTTON
3TH4244-5KB4 \CONT. RELAY, 2 LEVELS,
3TH4262-5KB4 \CONT. RELAY, 2 LEVELS,
3TF2001-6BB4 \CONTACTOR, SIZE 00, 3-PO
EWN:0854102001000 \N/BRAKE EBD 1.2B;0.25
GWE:A5E00156731-Q1 \ZK-Verschienung
A5E00093174 \Dock-Connect-Ext FBG Doc
6ES7370-0AA01-0AA0 \SIMATIC S7-300, DUMM
6FC9340-8WY00-1AC0 \N SINUMERIK 800 (ACC
6SL3054-1CE00-1AA0 \SINAMICS G150
3RA1110-0CD15-1BB4 \LOAD FEEDER FUSELESS
C79451-Z1531-K2 \SIMATIC S7, SPARE PART
6XV1830-1CH30 \CONNECTING CABLE 830-1T
95.102.201.9.2 \Drawbar connection
N-A5E00196352 \TRANS_NPN_IGBT_3MBI50SX-1
3RT1025-1DB44-0KV0 \CONTACTOR, AC-3 7.5K
3RG4613-1AB01 \SIMATIC PXI340 INDUCTIVE
EWN:2923002051000 \Cable
EWN:0844073701000 \N/TERMINAL BOX UPPER
EWN:1703123801000 \N/FLANGE 1FT5072-5108
EWN:0853007301000 \N/COVER FOR FLANGE-BO
EWN:0853016001000 \N/Cover 1FT5062-5065
N-462008713698 \FORMKABEL ER 36KW 611A-V
EWN:3333203025000 \connector complete 1F
N-000000572198 \SHUETZ,W-STM- 3TF3570-0
SWC:SA5E00226548 \IGBT FSB 4,0kW
SWC:STR02057 \N MM44 Module 600V 20A
A5E00262433 \A5E00262433
A5E01549598 \POY_PRECHARGING_UNIT_WIN
GWE:000000624460 \GWE:000000624460
6FC9344-3SB \SINUMERIK (ACCESSORIES)
8WA1011-6SF24 \CIRCUIT-BREAKER TERMINAL
5SK9011-6KK25 \CIRCUIT BREAKER
A5E00296553 \Inverter (for new Displa
C79298-A3238-B913 \CD ROM adapter
5SX2510-7CC \MCB 1P+N 10A 6kA-C
EWN:3333202021000 \N/CONNECTOR 1FT604./6
EWN:2923003051000 \Cable
6ES5700-8FA11 \BUSMOD. W.TERM.BLOCK F.
3RK1903-0AK10 \65MM TERMINAL MODULE
GWE:000000598540 \KOND,EL-AL- 6500UF
WKC:A5E00091034 \MCP THYR.MCC162-16io1
6FX8002-2CA51-1AC0 \N SIGNAL CABLE
6SL3054-0CE00-1AA0 \SINAMICS COMPACTFLAS
6RY1703-0FA10 \TSE CAPACITOR MODULE
EWN:0853000701000 \N/COVER 1FK608/610F.E
EWN:0853002601000 \N/COVER 1FK604 STANDA
EWN:0853005701000 \N/COVER 1FK606
3TH4382-0BB4 \CONTACTOR RELAY 82E EN 5
6FX8002-2CA80-1AJ0 \SIGNAL CABLE, PREASS
GWE:A5E00225675 \cable inverter PWB DC/A
A5E00645136 \Gehause 150mm LT 108A /
C79298-A3238-B201 \Bottom part of case c
EWN:1292020401000 \NDE shield for 1PH710
A5E00088655 \diagnosis cable
NMA:2510142400 \bearing 6216-C3
3RP1505-1AQ30 \TIME RELAY, MULTI-FUNCTI
A5E00179973 \ISOLATION Thyristor
6FX2003-1CA10 \N POWER CONNECTOR SIZE 1
3SE2120-1J \POSITION SWITCH METAL-EN
EWN:2923030201000 \signal leading for 1P
6FC5398-2CP10-1BA0 \NUMERIK.DOK 6FC5398
3RG4043-6KD00 \SIMATIC PXI350 INDUCTIVE
GWE:A5E00180518 \FK MeMa FSJ PWB-WR 690v
GWE:A5E00252087 \transformer output bar
EWN:8399501734000 \N/1FT510.KIT GASKET
N-462118007100 \GWE-462118007100
GWE:462018000322 \GEHAEUSE 200 F.
6ES7221-1BF22-0XA0 \EM 221, 8DI, DC 24V,
A5E00214148 \MOUDUL TESTER FBG MSC
A5E00165480 \Minus bar
EWN:1703136001000 \N/FLANGE 1FT504 ROD 4
EWN:3804054501000 \N/COUPLING
GWE:A5E00097691-Q1 \WID_MET_OXI_70R_+5%_
YAS:JZSP-CNS90-9 \N/TERMINATING RESISTOR
A5E00163105 \cable FSG PWB 400V sym.
6SC6100-0SA21 \N SETTING MODUL.
6FX2003-8LS50 \N
ZWR_943803AA_1 \Spacer ring for encoder
6FX1125-7BA00 \PLC-EINGABEBAUGRUPPE 64E
6FX2003-1CF17 \CONNECTOR
EWN:0853077001000 \N/BRAKE EBD 1.2B;0.25
D-056011790366 \cable pulse form
D-056011790766 \cable pulse form
D-056011791166 \cable pulse form
D-056011791566 \cable pulse form
D-056011791966 \cable pulse form
D-056011792366 \cable pulse form
6SC6600-4EA00 \N DISPLAY P.C.B
6FX2003-8LB50 \N
N-000000584987 \TRANS-MOD-IGBT BSM100GT1
6FC5398-1CP10-3BA0 \NUMERIK.DOK 6FC5398
6FC4600-0AJ67 \DISTRIBUTOR BOX
6SL3211-0AB15-5UA1 \G110 CPM110 1AC230 0
A5E00089385 \Inverter/Weckselrichter
6ES5988-3LB11 \FAN EXCHANGE PACK.
6FC9344-1VM \SINUMERIK (ACCESSORIES)
ZWR_71912x7_01 \ZWISchenring
A5E00151306 \cable inverter PWB FSJ
A5E00163090 \cable FSG PWB bridge 20
GWE:000000111211 \spacer SN61550- A M 4X
A5E00365688 \A5E00365688
GWE:A5E00156823-V2 \STR.SCH.SATZ/E/690V/
6SE6400-3CC00-4AB3 \MICROMASTER 4
3NA7822 \LV HRC FUSE
6FC9344-4GB \SINUMERIK (ACCESSORIES)
6SL3760-0GD00-0AA0 \RESISTOR 40OHM
A5E00093160 \Inverter/Weckselrichter
C79298-A3238-B515 \Measuring Lead with b
A5E02268101 \Bgr. MM4F RCC5 30kW/230V
EWN:3804056101000 \N/COUPLING 1FT5
6FC9301-0CD20 \N RAPID TRAVERSE OVERRID
6FX2001-6KC10-1CA0 \CABLE MOD. 0.2 M 6FX
N-000000586602 \WID,DRAHT- PULSW FEST 17
N-462018757110 \SICHERUNGS-BGR200-400A/V
3TF4322-0BB4 \CONTACTOR, SIZE 1, 3-PO
EWN:0853011801000 \N/DECKEL BS 1FK604
WKC:A5E00400028 \insulated paper
6FX2001-6FK12-0AA0 \COMPLETION TOOL FOR
GWE:475502500500 \Insulationpaper B3
6FX6002-2CF02-1AG0 \SIGC(6m)
3RT1035-1BB40 \CONTACTOR, AC-3 18.5 KW/
3RV1031-4BB10 \CIRCUIT-BREAKER, SIZE S2
3LD2113-1TL51 \MAIN SWITCH 25A/690V 400
6FC9344-4GM \N SINUMERIK (ACCESSORIES
YAS:OPR-109A \G/POWER SUPPLY FOR BRAKE
6FC5148-0AC01-0AA2 \N NON-REFLECTIVE MON
6FC5148-0AC01-0AA1 \N MONITOR SHIELD
GWE:A5E00333643 \cable PWB FS F rectifie
EWN:1513000202000 \N/END SHIELD BS 1FK60
EWN:1513000201000 \N/END SHIELD BS 1FK60
EWN:1513000207000 \N/MOTOR SPARE PARTS
3RK1903-0AL10 \130MM TERMINAL MODULE
EWN:5193003912000 \Encoder
YAS:JZSP-CNS90-2 \LOCAL BUS (DRIVE BUS)
3RK1408-8KE00-0AA2 \AS-INTERFACE SLIMLIN
3TK2830-1CB30 \SIRIUS EXPANSION UNIT 4N
N-A5E00107173 \TRANS_NPN_MOD_BSM400_1.2K
GWE:A5E00388700 \cable PWB FS-G rectifie
6ES7321-1FF01-0AA0 \SM321, 8DI, AC120/23
GWE:A5E00263048 \DC-bar
6ES7953-8LG11-0AA0 \S7 MICRO MEMORY CARD
6ES5980-0AA11 \N battery
YAS:LPSE-2H01 \G/POWER SUPPLY FOR BRAKE
YAS:SGDK-CF01A \G/MODULE FOR PG CONNECTI
MU_175743_1 \Front Nut
EWN:8399501735000 \N/END SHIEL DAS AFT50
DK_175384B_1 \cover
N-462018007180 \GWE-462018007180 300INT
6FC9348-2BY00-1BA0 \N/SIGNAL CABLE
N-462008718096 \GWE-462008718096
6FX2002-5BA01-0CB5 \N POWER CABLE
A5E00718718 \CABLE
3RA1120-1GD24-0BB4 \LOAD FEEDER FUSELESS
3RA1120-1DD24-0BB4 \LOAD FEEDER FUSELESS
3TH2031-0AC2 \CONTACTOR RELAY 31E EN 5
GWE:A5E00342557 \cable Tyristor rectifie
A5E00172030 \cable FS-H fan
5SY6213-7 \CIRCUIT BREAKER 6KA 2POL
6FX6002-1AA02-1AH0 \SIGC,ECU-OP020,7M
A5E00375399 \A5E00375399
3NP4010-0CH01 \FUSE SWITCH DISC. 160A
6ES7222-1HD22-0XA0 \EM222, 4DO RELAY,10A
3NE1331-2 \SITOR S.-COND. FUSE 350A
6SY7010-0AA18 \THYRISTOR MODULE
6FC9344-3SY00-1FA0 \SINUMERIK 800 (ACCES
EWN:1292023301000 \NDE shield for 1PH716
6SE6400-5AW00-0AP0 \MICROMASTER 440
6FX5002-1AA02-1AH0 \N SIGNAL CABLE
6FC9301-0DC20 \SWITCH
GWE:A5E00207694 \cable PWB DC
3NE8024-1 \SITOR S.-COND. FUSE 160A
6SL3211-0AB21-1UA1 \G110 CPM110 1AC230 1
6FX8002-5CN01-1AF0 \POWER CABLE PREASSEM
GWE:A5E00381957 \ISOLATION DC-
3TK2821-1CB30 \SIRIUS SAFETY RELAY
6ES7132-4BB01-0AA0 \ET200S, EL-MOD., 2DO
EWN:3333061001000 \EWN:3333061001000
EWN:0704112001000 \NDE-SHIELD
A5E00102801 \current transformer 500A
C79451-Z1329-U131 \SIMATIC S5, SPARE PAR
D-000201 \fuse connector
GWE:A5E00156831-V2 \STR.SCH.SATZ/E/f.Thy
GWE:A5E00156735-Q1 \ZK-Verschienung
6FX2002-4EA01-0CB0 \MPI INTERFACE CABLE
6FX1142-1BA01 \N DMP TERMINAL BLOCK,
5SX5104-7 \CIRC.BR. CURRENT SENS. T
GWE:A5E00156821-V2 \STR.SCHN.SATZ/E/
EWN:0563079001000 \fan unit
HL_175391_1 \BUSHING
6FC9344-4NY01-1AC0 \N SINUMERIK (ACCESSO
SWC:SDI02662 \N 2.3.GEN. MD2 Rectifie
6SL3262-1AB00-0DA0 \SCREENING KIT FOR PM
GWE:A5E00197446 \TDB bridges FS-F
3UG3051-1AC40 \MONITORING RELAY, 45 MM
A5E00197448 \TDB bridges FS-G 105mm
6ES7390-1AJ30-0AA0 \SIMATIC S7-300, RAIL
MAP_RE100-10 \HSKA-80 protect ring?
3TK2842-1BB42 \SIRIUS ELEC./STD.
EWN:5194005005000 \Hand Level
6FC9348-5BC \SIMODRIVE 610 1FT5 (ACCE
EWN:2923003081000 \Cable
6FX2003-1CB10 \N POWER CONNECTOR
EWN:0853003701000 \N/NDE Cover
6FC9340-8XB \N SINUMERIK (ACCESSORIES
GWE:A5E00200040 \bar set
A5E00162087 \TRANS_NPN_IGBT_1MBI200S-
6ES5988-3NB11 \FAN EXCHANGE PACKAGE
6SE6400-7AA00-0AH0 \N MM43 SED2 IO Modu
C79298-A3238-D3 \Cable set
SEN_175338_3 \sensor
6ES7132-4BB00-0AA0 \ET200S, EL-MOD., 2DO
6FX2002-4EB40-1AF0 \SIGNAL CABLE, PREASS
6SY9080 \N TRANSISTOR MODUL. 1DI2
A5E00156847 \bar set E FSH
6FC9301-0CC20 \RAPID TRAVERSE OVERRIDE
A5E00112391 \PWB bridge 490A
6FX8002-5CN01-1AJ0 \POWER CABLE PREASSEM
W97415-R1122-A953 \N THYRISTOR MODUL.
6SE7098-0XX84-0AH1 \MEMORY MODULE 6SE70
6FX2003-1CB20 \N POWER CONNECTOR
6FC5800-0AP01-0YB0 \NETZLAUFWERKE VERW.
C98130-A1235-C622 \Busbar
EWN:1513000208000 \N/END SHIELD BS 1FK60
GWE:A5E00335627 \output bar set
3RA1120-1JD26-0BB4 \LOAD FEEDER FUSELESS
C98130-A1235-C623 \Busbar
N-462008757010 \RC-BGRG3 611 REPAIR
GWE:A5E00180524 \FK MeMa FSJ 690V/ 665A
SWC:STR01870 \N MM42 Skip Module
6FX5002-5ES00-1AA8 \LEISTUNGSLEITUNG KON
GWE:A5E00197083 \DC-bar
6FX2002-2CA71-1BA0 \N SIGNAL CABLE
6NH7701-5AN \SINAUT ST7, CC 701-5A
GWE:A5E00338278 \input bar set
GWE:620361900101 \N MM4344 F-BGR.RCC1 4
EWN:1513000206000 \N/END SHIELD BS 1FK60
6ES5376-1AA11 \MEMORY SUBMOD. 376 CMOS-
GWE:A5E00192000 \FK FS-H GR/WR
3VL9400-4TD30 \ACC. F. VL400, CIRCULAR
A5E02178409 \POY_PRECHARGING_UNIT_SPI
6FX8002-2CB44-1BA0 \N SIGNAL CABLE
3NP4070-0CH01 \FUSE SWITCH DISC. 160A
6FC5551-1AA00-3BB0 \802S SOFTWARE;
6GK1500-0DA00 \RS 485 BUS TERMINAL
6FC9301-0AE20 \SWITCH,
3UF7210-1AA00-0 \OPERATOR PANEL W. DISP
6ES5727-1BD20 \CONNECTING CABLE 727-1 3
6FC5247-0AA43-0AA0 \OPTION F.PP031.MC
GWE:A5E00447496 \dc
C79451-Z1133-U4 \Displayinverter
6FX2002-1DC00-1EA0 \SIGNAL CABLE, PREASS
A5E00190906 \current transformer ESM1
EWN:5193004302000 \Encoder
5ST2540 \BUSBAR 6X100A, L=390MM
EWN:8399501822000 \N/KIT RESOLVER SIZE 2
SCH_174653_3 \ring
6FC9301-0EC20 \SWITCH,
N-A5E00194119 \Gehuse Kpl ER 300mm ext.
6FX8002-2CB51-1DA0 \DOUBLEMASTERCONTRO
6FX6002-2CF02-1BJ0 \Signal Cable 18M
ZWR_175743_V_1 \Space ring complete
A5E00156848 \bar set Thyristor
4AM4042-5MT10-0FA0 \TRA SITAS PH1 UPRI(V
C79298-A3238-B270 \cover complete
C98130-A1235-C621 \Busbar
6SE6400-3TC00-4AD2 \OUTPUT REACTOR FSB 3
6ED1052-1MD00-0BA5 \LOGO! 12/24RC,LOGIC
GWE:A5E00263056 \dc
6SY7010-2AA21 \FUSE
C98130-A1235-C481-1 \Insulation Thyristo
EWN:1292019201000 \NDE shield for 1PH713
3TF2185-8BB4 \CONTACTOR SIZE 00 3-POLE
3KX3612-1B \AUXILIARY SWITCH FOR 3KL
GWE:462118701002 \GEHAEUSE UE 10KW
GWE:000000622167 \GWE:000000622167
6FC9344-1TB \SINUMERIK (ACCESSORIES)
SIE/6FX2001/16 \cable building unit
EWN:5193001003000 \FAN MOTOR, M2D068-DF
6EA9610-0AA00-0AX0 \SIMATIC S5, BATTERIE
3RV1041-4LA10 \CIRCUIT-BREAKER SIZE S3
N-A5E00307149 \Gehuse komplett 100mm 16
A5E00162540 \cable fan/transformer (K
A5E01250145 \PICK32 with X1 terminal
6FX2002-5AA01-0CB5 \N POWER CABLE
6FC9340-8WY00-1EA0 \N SINUMERIK 800 (ACC
5SX2101-7 \CIRCUIT BREAKER T55 6KA
6SC6110-0EH05 \N SW BOARD
6ES7468-3AH50-0AA0 \SIMATIC S7-400, IM C
EWN:0853003310000 \N/COVER 1FK608./1FK6
6FC9344-4NB01 \SINUMERIK (ACCESSORIES)
6FX2001-2GD60 \G INCR. POS. ENCODER, WI
A5E00197439 \TDB bridges FS-F 55mm
6FX2001-4NC50 \DREHGEB.OPT- 6FX2001-4
6ES7963-1AA00-0AA0 \SIMATIC S7-400, IF96
SCH_174686_7 \disc segment
3RS1040-2GD50 \TEMPERATURE MONITORING R
C98043-A1087-L1 \N MAIN SPINDLE DRIVE
A5E00262431 \bluetooth modul
EWN:3333000303000 \N/CONNECTOR COMPLETE
GWE:A5E00156724 \bar set rectifier/E
EWN:1293770305000 \N/END SHIEL DAS 1FT50
C79451-Z1489-U1 \SIMATIC S5, SPARE PART
6ES7952-0AF00-0AA0 \SIMATIC S7, RAM MEMO
A5E00262290 \A5E00262290
3RT1046-1AP00 \CONTACTOR, AC-3 45 KW/40
6FX8002-2CB42-1EA0 \SIGNAL CABLE, PREASS
A5E00164638 \cable FSF basic unit
EWN:8399501516000 \N/COVER 1FK608/610F.E
6SE6400-4BD11-0AA0 \BRAKING RESISTOR FSA
SEN_175442_V_2 \SEN_175442_V_2
6FC9340-8WY00-1FA0 \SINUMERIK 800 (ACCES
D-A5E00156725 \CU-BAR-G
95.101.826.4.2 \piston
N-462018000322 \GWE-462018000322 200F.E/
EWN:1292167901000 \N/END SHIELD AS 1FIT5
3RK1205-0BG00-0AA2 \AS INTERFACE
6ES7221-1BF00-0XA0 \EM 221, 8DI, 24V DC,
6FX8002-2EQ18-1BB0 \SIGNAL CABLE, PREASS
C98130-A1002-C76 \N TRANSFORMER NETWORK
6FX8002-2CE02-1BA0 \N SIGNAL CABLE
EWN:0313005171000 \Encodercover
6FC9340-8WB \(ACCESSORIES)FOR RS 232
1LA7063-4AB17 \LOW-VOLTG. SQUIRREL-CAGE
1LA7063-6AB17 \LOW-VOLTG.SQUIRREL-CAGE
3RK1400-1CG00-0AA2 \AS-INTERFACE SLIMLIN
6FX5002-5DS31-1BF0 \POWER CABLE, PREASSE
6ES5312-3AB11 \SIMATIC S5, IM312 , EXTE
EWN:1292168504000 \N/END SHIELD AS IFT61
6FC5313-4AG00-0AA2 \COMPACTFLASHCARD
6SL3360-8AA00-0AA0 \KOND_MKP_38U7_+-5%_7
EWN:3334053910000 \N/CONNECTOR COMPLETE
EWN:3333000305000 \N/SOCKET COMPLETE NIC
EWN:3334052502000 \N/CONNECTOR COMPLETE
EWN:3334053301000 \N/CONNECTOR COMPLETE
A5E02094239 \PICK32_HS with X1 termin
A5E00156712 \bar set E/480V/840A
6FC9340-8XE \N SINUMERIK (ACCESSORIES
3NE4337-6 \SITOR S.-COND. FUSE 710A
A5E00151307 \cable rectifier PWB FSJ
3RB2956-2TH2 \CURRENT TRANSFORMER 20..
GWE:475508790270 \Cable form between rec
GHK_175338_1 \Housing
GWE:A5E00156725 \bar set rectifier for S
C98130-A1235-C661 \cable channel
6FX2001-2GB00 \G INCR. POS. ENCODER, WI
6ES7211-0BA23-0XB0 \CPU 221, AC PS, 6DI
3RX9307-1AA00 \AS-INTERFACE NETZTEIL
C79451-Z727-K5 \missing SIMATIC PG, spar
A5E00202739 \cable FS-H Thyristor
EWN:1733001201000 \Ringsegment
MTL_176281A_1 \Platte
3VL9400-3HF04 \ACCESSORY FOR VL400,
BAL/BAW/10 \sensor
A5E00156714 \bar set E/480V/985A
6ED1052-1FB00-0BA3 \LOGO! 230RC,LOGIC MO
A5E00162541 \cable fan/transformer (K
6FX2001-2KB00 \INCR. ROTARY ENCODER W.
6SC6100-0BA00 \N/SIMODRIVE 610
6SL3211-0AB22-2UA1 \G110 CPM110 1AC230 2
EWN:3333028461000 \N/ANGLE-ENTRY PLUG 12
380/85V
6FX5005-5ES81 \LEITUNGSPAKET FA. DMG
6FC9344-2BE \ACCESSORIES F.SINUMERIK
EWN:8399501815000 \brake
DK_175339A_1 \cover
6FX2002-5BA01-1BA0 \N POWER CABLE
EWN:1293707302000 \N/END SHIELD AS 1FT50
EWN:1702011901000 \N/BUILT-ON-FLANGE1PA
GWE:000000653451 \BSM50GD120DN2
6ES7223-1BH21-0XA0 \SIMATIC S7-200, DIGI
W-RG_175456_3 \ring
EWN:5194033801000 \N/G51 FOR 1FT506
EWN:5194033804000 \N/G51 FOR 1FT503
EWN:5194033803000 \N/G51 FOR 2FT504
EWN:5194033802000 \N/G51 FOR 1FT507
DK_175743_1 \Cover
RG_174981_14 \adjusting ring
A5E01192144 \SPEED_SUPERVISION_BOARD
GWE:A5E00447495 \dc
EWN:1293739702000 \N/END SHIELD AS 1FT50
C98043-A1087-L13 \FOR SERVICE
6SN1118-0DG12-0AA0 \W40 CLOSED-LOOP PLUG
6FX6002-5DA01-1CF0 \Power Cable 25M,wit
C98130-A1235-C685 \Busbar
DK_71922_100 \cover
C79451-A3463-D106 \SIMATIC S7, SET OF SP
3RK1400-1BQ20-0AA3 \AS-INTERFACE COMPACT
6FX2001-2CB25 \ENCODER 6FX2001-2CB
6FX2001-2CB50 \G/SINOMERIK
3RT1045-1BB40 \CONTACTOR, AC-3 37 KW/40
3TK2943-0BB4 \DELAY MODULE
6FX2001-3CB00 \DREHGEBER 6FX2001-3
3LD2714-0TK51 \MAIN SWITCH 100A/690V 40
3VL9325-7DC35 \S4/OVERCURRENT RELEASE
Accessory
6FX2002-2CB41-0CB5 \N SIGNAL CABLE,
5SZ6466 \Breakers
RG_175442C_3 \Ring
EWN:3333202011000 \N/CONNECTOR COMPLETE
6ES7963-2AA00-0AA0 \SIMATIC S7-400, IF96
6AU1400-2KA00-0AA0 \SIMOTION-D 6AU1400-2
6SL3210-1SB11-0UA0 \S120PM340 POWER UNFL
N-462118700112 \GWE-462118700112 50KPL.E
6FC5650-1EB00-0AG0 \PCU-TOOLBOX 6FC5650-
A5E00275850 \A5E00275850
GWE:462018799401 \ANST-BGR.200A SI
6SN1151-1CX10-2AB0 \FOR SERVICE
6FC5250-5BX10-3AH0 \N NCU SYSTEM SW 6 AX
C98130-A1235-C618 \Busbar
6FC5800-0AP25-0YB0 \3D SIMULATION
N-188000000689 \A5E00098347
A5E00142505 \TDB fastener U
6SY7000-0AC03 \FUSE
6ES5895-3SR22 \SOFTWARE
N1008-K*-M1*-SP \CYL.Roller bearing N100
EWN:5194033809000 \N / ACCESSORIES FOR R
RG_174981_8 \ring
NMA:2511158300 \bearing NU2216-ECP
6FX2001-2MB02 \DREHGEBER 6FX2001-2
6ES7322-1BF00-0AA0 \SIMATIC S7-300, DIGI
ROHR_175003D_2 \Tube
N-462118700121 \GWE-462118700121 50KPL.E
3RG4041-6KD00 \SIMATIC PXI340 INDUCTIVE
EWN:1292031501000 \N/END SHIELD BS 1FT50
EWN:1293770301000 \N/END SHIELD AS 1FT50
6ES7134-4JB50-0AB0 \ET200S, EL-MOD., 2AI
6SC6108-0SE80 \RETROFIT ASSEMBLY
EWN:1293770303000 \N/END SHIELD AS 1FT50
EWN:0844069701000 \N/TERMINAL BOX UPPER
6FC5250-3BX10-7AH0 \N SYSTEM SW NCU 571.
WKC:A5E00156651 \VCP FBG_PBI_04.16_(AC)
EWN:1292110011000 \N/END SHIELD NO DRIVE
WKC:A5E00844045 \CBR 01 BOARD
6ES7963-3AA00-0AA0 \SIMATIC S7-400, IF96
EWN:0313006701000 \Endcover
GWE:A5E00335852 \input bar set
6FC5247-0AA31-0AA0 \N ADAPTER FOR MMC103
ROHR_174686_2
6ES5440-8MA22 \440-8 DIG. OUTPUT 4DO, D
6ES7421-1FH00-0AA0 \SIMATIC S7-400, SM 4
6FC9320-5DF00 \N ELECTRONIC HANDWHEEL
6ES5988-7NA11 \FAN EXCHANGE PACKAGE
6ES7132-4BB30-0AA0 \SIMATIC DP, 5 ELECTR
6FX2002-5BA01-1BF0 \N POWER CABLE
A5E00152190 \DC-bar/480V/840A
EWN:5194037102000 \N/TACH 1FU1050-6HC
C79451-Z1489-K1 \SIMATIC S5, SPARE PART
A5E00271736 \A5E00271736
A5E00307149 \Gehause komplett 100mm
GWE:A5E00337766 \dc
EWN:5194049304000 \N/TACH 1FU1050-6NG
GWE:A5E00252386 \cable PWB rectifier ter
6ES5441-8MA11 \441-8 DIG. OUTPUT 4DO, D
A5E00808655 \POWER_SPLY_ATX12V_240V_5
BAL/BAW/06 \SENSOR
EWN:1292830312000 \DE SHIELD 1FT703. FOR
EWN:1292930312000 \DE SHIELD 1FT703
3RA1120-1CA24-0AP0 \LOAD FEEDER FUSELESS
RG_174686_13 \ring (tool change position
EWN:3333058605000 \N/CONNECTOR L SIZE 2
SPR_176006_1 \Splash ring
6SL3361-3AF02-0AA0 \REPLACEMENT DOOR FOR
6FC9344-2EE \SINUMERIK (ACCESSORIES)
C79298-A3238-B535 \KV-Clip
6ES5727-1CB00 \CONNECTING CABLE 727-1 1
6AV3980-1AA21-0AX0 \STANDARD FB TO CONNE
6SL3210-1SB11-0AA0 \S120PM340 POWER FLT
6RY1240-0AA07 \Thyr-Mod 105A 1600V 1000
EWN:5194037111000 \N/TACH 1FU1050-6GK
A5E02143667 \UEGK-02
3RK2400-1DQ00-0AA3 \AS-I COMPACT MODULE
RG_174791B_2 \balancing ring
GWE:000000655621 \BSM75GD120DN2
6AV3515-1EB30-1AA0 \OP15/A1 OPERATOR PAN
6AV3515-1EB32-1AA0 \OP15/A2 OPERATOR PAN
A5E00204837 \customer terminal FSJ in
6ES7235-0KD22-0XA0 \SIMATIC S7-200, ANAL
A5E00061002 \SIMATIC PG, SPARE PART
EWN:5194043602000 \TEACH-GENERATOR/HU105
SIE/6FX5005/01 \ Power-cable module
5SY6350-6 \CIRCUIT BREAKER 6KA 3POL
A5E00142501 \TDB fastener V
C79451-Z727-K6 \missing SIMATIC PG,spare
6SE6400-2FS03-8CD0 \MICROMASTER 4
HSS71902E/01 \BEARINGS
HS7016E/01 \bearing
6FX2002-4EA02-1AF0 \N SIGNAL CABLE
C98130-A1235-C686 \Busbar
6ES7360-3AA00-0AA0 \G S7-300, ANSCHALTUN
A5E00383968 \A5E00383968
6FC9320-3CS \SIPOS SIGNAL ENCODER, OU
6SN2157-2CK10-0BA0 \GEARING IP54 I=20
W-DK_174416_2 \cover ring
6FC5147-0AA00-0AA1 \N BACKGROUND ILLUMIN
RG_175460B_1 \ring
6FC5250-2AY20-2AG0 \SINUCOM 6FC5250-2AY
GWE:A5E00207890 \bar set
6FX5002-5DS51-1BF0 \POWER CABLE, PREASSE
A5E00273594 \A5E00273594
EWN:1291830612000 \06DE SHIELD 1FT706
EWN:1291210612000 \shield
EWN:1292210412000 \shield
EWN:1292200412000 \shield
A5E00107173 \TRANS_NPN_IGBT_BSM400_1.
SEN_175513_1 \Sensor Complete
6ES7223-1BL22-0XA0 \SIMATIC S7-200, DIGI
A5E00718723 \TEST CABLE
6FC9320-5DB00 \ELECTRON. HANDWHEEL 5V 6
6ES7231-7PB22-0XA0 \SIMATIC S7-200, RTD
A5E01185360 \PICKpower_MIX_HS
6FC5548-0AB03-0AA0 \MOTOR, 3.5NM
EWN:3333031501000 \N/CONNECTOR SIZE 3 (O
EWN:5194003201000 \N / Toothed wheel 1PH
VEX 65 SQCE 1 UL \spindle bearing
A5E00245170 \current transformer ESM2
EWN:5193153590000 \EWN:5193153590000
DK_176006_2 \Cover
N-462118007581 \GWE-462118007581
3RK1301-0AB10-1AA3 \RS1E-X FOR ET200S
GWE:462018790712 \A0 board
N-A5E00189872 \C-Bgr.200-400A E/R SIMODR
6FX2002-5AA31-1BG0 \N POWER CABLE
EWN:1293103205000 \N/END SHIELD AS 1FT50
KAB_175982_V_1 \Cable unit complete
EWN:5193045201001 \N/PERMANENT MAGNET-BR
6FX1410-0CX44 \Battery plug-in unit
N1015K.M1.SP \back bearing
6SY8101-0AA26 \RESISTOR HIGHVOLTAGE 969
EWN:0573206104090 \EWN:0573206104090
A5E00201015 \Thyristor FS-J
6RX1700-0AD64 \OPERAT.INSTR. GERMAN,ENG
HC7006C/01 \bearing
9:34EE-225PP-WCM8 \MDA5-8BB-CCD
6ES7212-1BA00-0XB0 \SIMATIC S7-200, CPU
6SL3360-8AA00-0AA3 \RES_NET_SONST_0R15_+
A5E00152144 \intermediate
W-RG_175456B_1 \ring
EWN:1293656925000 \N/END SHIELD AS 1FT50
EWN:1292117994000 \N/END SHIELD 1FT 608
A5E00143357 \Netzteil Docking 1 A5
EWN:5193016501000 \N/FAN COWL 2CW614.1GL
3VF3211-1BW41-0AN1 \ISOL. CIRCUIT-BREAKE
6SY8101-0AA33 \DIFFERENTIAL PRESSURE MO
EWN:3333053601000 \N/NNECTOR L SIZE 3 1F
EWN:1293717301000 \N/END SHIELD BS
6SC6500-0BB01 \R0 FEEDRATE CONTROL
C79298-A3238-B460 \Centronics Cable
A5E00691268 \A5E00691268
EWN:0000251089000 \Bearing
6SL3361-3AG01-0AA1 \FRONT COVER SINAMICS
YAS:HV-75BP4 \G/STAR-DELTA RELAY
EWN:5194052812000 \RESOLVER
DK_174730A_1 \ DECKEL
6FX2002-5AA02-1BJ0 \N POWER CABLE
EWN:5194037103000 \N/TACH 1FU1050-6HF
EWN:5194037104000 \N/TACH 1FU1050-6HG
4AM6142-8DD40-0FA0 \TRANSFORMER SITAS; P
HS71916E/01 \NDE-bearing
A5E00152139 \intermediate
EWN:3843207501010 \laufer 1FK7043-7
4AM6142-5AT10-0FA0 \TRANSFORMER SITAS; P
3VF3211-1FW41-8CA0 \CIRCUIT-BREAKER, 3-P
6FX1144-2BA00 \R0 INTERFACE DMP
6ES7214-1BD22-0XB0 \CPU 224, AC PS, 14DI
6ES7138-4DF11-0AB0 \ET200S, EL-MOD.,1SI,
GWE:A5E00438007 \dc
IND/INS0381/C25 \plug
EWN:0573011902493 \stator complete1FT506
EWN:3843116502010 \rotor
EWN:0573206102130 \EWN:0573206102130
EWN:5193504850000 \BRAKE HT07P01
6FC5247-0AF11-0AA0 \DIRECT KEY MODULE PR
95.600.682.9.2 \stem
EWN:3843159202010 \EWN:3843159202010
EWN:5193016402000 \EWN:5193016402000
RG_174686_6 \slinger ring
A5E00239082 \A5E00239082
A5E00126678 \VAS 5052 service case c
YAS:UZBA-B32A \G/SERIES REACTOR
8WD4428-0BE \SIGNALING COLUMN
EWN:0573008004150 \EWN:0573008004150
EWN:5193016105000 \N/FAN COWL AH130 2CW6
EWN:3843115601010 \ROTOR
C79298-A3238-B520 \DSO Measuring Cable
6SL3055-0AA00-3HA0 \TERMINAL MODULE TM17
BZ_448_4100_3 \none return valve
6FX1120-7BE01 \N MEMORY PCB W O RAM
6SE6440-2AB15-5AA1 \MICROMASTER 440
GWE:A5E00480714 \resistor
EWN:5193503650000 \BRAKE HT04P01
95.601.314.3.2 \Packing Sleeve
C79451-Z1572-U23 \Touch Display 10,4"
GWE:A5E00347573 \output bar set
C79298-A3238-B221 \Middle lid complete
8UC6414-1BB44 \DOOR-COUP. ROT. OM SZ4 H
YAS:HV-75AP4 \WINDING CHANGE CONTACTOR
EWN:1291200812000 \shield
EWN:1291210812000 \SHIELD
EWN:0000251088000 \Bearing
EWN:8399501540000 \N/COVER 1FK608/610F.E
EWN:0573011512498 \StatorComplete1FT5064
MAP_KS80-09 \HSKA-80 gripper
6FC5650-1EA00-3AG0 \TOOLBOX ON CD-ROM VE
6ES5465-3AA13 \W50 INPUT MODULE
EWN:0573008001150 \Stator for 1FK7040-5A
N-462118700201 \GWE-462118700201 100 KPL
EWN:0573016601492 \N/STATOR COMPLETE 1FT
6ES7214-1BD23-0XB0 \CPU 224, AC PS, 14DI
A5E00098997 \ZZZ/DIAGNOSIS CABLE 3M
3RN1013-1BW10 \THERMISTOR MOTOR PROTECT
A5E00152112 \DC-bar/480V/985A
4AM5595-0UA20-0NN2 \NTRAFO PHA1 PN(KVA):
6AV6642-0AA11-0AX1 \TOUCH PANEL TP177A 6
95.600.756.9.2 \DRAWBAR ADAPTER GD15X8X1
6FX1121-2BA02 \N SINUMERIK 800 INTERFAC
A5E01207323 \PICKpower32_HS
EWN:0572202601090 \n/stator complete 1ft
EWN:0572024002496 \EWN:0572024002496
6FX1191-0AA00 \N PLC TO EU
6FX1122-1AA02 \N SINUMERIK 3 PLC TO NC
EWN:0572007001130 \EWN:0572007001130
EWN:0573014004495 \EWN:0573014004495
EWN:3843115301001 \EWN:3843115301001
EWN:3843207401000 \EWN:3843207401000
EWN:5194014101000 \gear measuring wheel
SWC:S1750L312 \N MMB DCB MODULE 600V 1
SNFA_VEB60/05 \Bearings
6FC5148-0AA20-0AA0 \N DAMPING ELEMENTS
6ES5894-0MA04-0UD3 \STEP 5 BASIS V7.2, C
EWN:3843026802555 \N/Rotor for 1FT6034-1
HSS7012E/01/N \bearing
A5E00156705 \ZZZ/HARD DISK/OGB
EWN:3843124601555 \rotor
6FC5800-0AP17-0YB0 \SHOPTURN/SHOPMILL 6
EWN:1294601401000 \END SHIELD AS 1FT510.
ZR_LB_129_80_1 \encoder wheel
RG_174730A_2 \Piston
6ES5777-0BC01 \BT 777-0 BUS TERMINAL W.
EWN:1290211012000 \shield
EWN:5193016503000 \FAN MOTOR 2CW8344 DE-
3VF3211-5ES71-0AB2 \CIRCUIT-BREAKER, 3-P
EWN:0572007003130 \EWN:0572007003130
KB_175442C_1 \Release unit piston
F_10784/85C \spring pack
GWE:620362901402 \GWE:620362901402
6FC5147-0AA00-0AA0 \N BACKGROUND ILLUMIN
3VF3211-2BW41-0AB2 \S4/CIRCUIT-BREAKER
GWE:000000597971 \SINAMICS/MICROMASTER P
A5E00172029 \main cable FS-H
B71916E/01 \Bearing
6ES7441-1AA00-0AE0 \COMMUNICATION MODUL
6SY8101-0AA28 \RESISTOR HIGHVOLTAGE 969
RG_174416_10 \Piston
KB_175003C_1 \Piston small hole
6SL3210-1SB14-0AA0 \S120PM340 POWER FLT
MTL_A63_01 \Drive ring
GWE:A5E00156743-Q1 \ZK-Verschn./PWB-WR/6
EWN:0573014005495 \N/Stator for 1FT6064-
GWE:A5E00348233 \input bar set
6SE7027-2ES87-0FB1 \FILTER,RI SUP. 6SE70
EWN:0573014003495 \EWN:0573014003495
EWN:5193002039000 \Encoder
HSS7015E/01 \back bearing
ROHR_174791D_2 \draw bar pipe
SIE/6FX2001/23 \Encoder
6SY7000-0AD36 \MAINS-THYRISTOR MODULE
6SL3054-0CB01-1AA0 \SINAMICS COMPACTFLAS
6FX8008-1BD21-2AA0 \SIGNALLEITUNG METERW
SNFA_VEX80/05 \spindle bearing
EWN:0573014006495 \N/Stator for 1FT6064-
EWN:5193007730000 \encoder ERN 1387.020
EWN:5193016302000 \N / Brake for 1FK604.
EWN:3843119901000 \EWN:3843119901000
RG_174686A_2 \Piston
EWN:0573014006493 \EWN:0573014006493
3RK1300-1CS01-0AA1 \EM 300 DS, FOR ET 20
C79298-A3238-B903 \Connector board 1
EWN:3843078701555 \N/Rotor for 1PH7103-2
6EP1334-1SH01 \SITOP POWER 24 V/10 A
6FC5203-0AC10-1AA0 \N KEYBOARD OP0 32S
ZR_LB_77.4_40_1 \Encoder wheel 244ZR0521
6GK1100-0AB00 \SIBUKO PACKAGE 2
EWN:1292168502000 \N/END SHIELD AS 1FIT5
EWN:5193506350000 \BRAKE HT09P01
EWN:3843119906010 \rotor
3RS1705-1FW00 \INTERFACE CONVERTER
HC71912E/01 \bearing
VB_176173_1 \sleeve
HCB71912E/01 \back bearing
3RB1253-0FM20 \SOLID-STATE OVERLOAD REL
VEX 80 SQCE 1 UL \spindle bearing
95.602.694.3.1 \swithing ring
W-RG_175456_1 \ring
WZA_176024_1 \tool insert unit
EWN:8399501520000 \N/1FK604.KIT 8.30 INS
6SC6100-0NA82 \RETROFIT ASSEMBLY
6SE6440-2UC23-0CA1 \MICROMASTER 440
C98130-A1235-C619 \Busbar
6ES7422-1BH10-0AA0 \SIMATIC S7-400, SM 4
6FX2001-8RA03-1D \ENCODER
LB_ZAN50200/02 \GEBERRAD
6SE7034-6EC85-0JA0 \TSE-SURGE SUPPRESSOR
A5E00196322 \ANST-BGR.300A/80kW Eupec
A5E02463817 \Capacitor Group
EWN:5193202101000 \N/RESOLVER V23401T200
GWE:A5E00282811 \ISOLATION Plus - Minus
95.601.218.9.2 \pressure position
6ES5464-8MC11 \464-8 ANALOG INPUT, 4AI,
C98043-A1206-L22 \R0 FIELD SUPPLY BOARD
SEI/6FX2001/23 \Encoder
EWN:3843119803010 \rotor
A5E02463821 \Capacitor Group
A5E02463823 \Capacitor Group
6RY1243-0FA01 \TSR-SURGE SUPPRESSOR CIR
GWE:A5E00338066 \dc
SIE/6FX2001/29 \ENCODER
GWE:620999900002 \STARTER SET
EWN:3843116401010 \laufer 1FK7103-5
GWE:A5E00381953 \dc
6FM1720-3AA10 \STAND ALONE SINGLE-AXIS
EWN:3843307601000 \EWN:3843307601000
EWN:3843307702001 \EWN:3843307702001
EWN:3843307602001 \EWN:3843307602001
A5E00262596 \A5E00262596
6FX1822-0BX03-4H \N/ 810T/820T-BASIC
EWN:3843164502010 \rotor
C98043-A1006-L3 \N MAIN SPINDLE DRIVE, E
6FX1120-7BB01 \W35 BASIC MEMORY MODUL.
6FX1864-0BX02-7C \N OPERATOR PANEL SW,
6FX1864-0BX01-7C \N OPERATOR PANEL SW, M
6FX1863-0BX01-6D \N SERVO SW, 16 BIT,
6FX1837-0BX01 \N/SOFTWARE
6FX1837-0BX02 \N/SINUMERIK
6FC5111-0BA60-0AA0 \N/MODULE
6ES5431-8FA11 \431-8 DIG. INPUT 4DI, DC
EWN:519.40042.06 \N/SIMODRIVE 6.1
6SN1113-1AA00-1FA0 \N VPM 85, VOLTAGE PR
6FX1822-0BX04-2D \N/SINUMERIK 810/820
EWN:5193013003000 \Encoder
6ES5410-7AA11 \U40 digital output modul
6SE7018-0ES87-2DA0 \SIMOVERT MASTERDRIVE
3RT1046-1BB44 \CONTACTOR, AC-3 45 KW/40
6SL3000-0BE31-2DA0 \FILTER_NETZ_3AC_120K
A5E00200535 \IGD3 module /R/400V/605A
ROHR_174791D_1 \draw bar front part
HS7020E/01 \bearing
A5E00276115-04 \A5E00276115-04
3RG7844-6SD08-0SS0 \R0/ CURTAIN
N-462118700402 \GWE-462118700402 200 KPL
GWE:A5E00156738-Q1 \ZK-Verschn./PWB-GR/W
6ES7132-0HH01-0XB0 \ET200B, EL-BLOCK, 16
HC71914E/01 \Bearings
1FK7022-5AK71-1AG0 \SYNCHRONOUS SERVOMOT
6FC5463-0FA00-0AB1 \SHOPMILL COPY LICENS
6FX2001-5SS24 \ABS ROTARY ENCODER 6FX20
HCB71918E/01 \Bearing
6SL3100-1AE31-0AA0 \SINAMICS BRAKING MO
EWN:0573206101130 \EWN:0573206101130
EWN:3843116501000 \EWN:3843116501000
EWN:3843116401000 \EWN:3843116401000
EWN:3843159201000 \EWN:3843159201000
EWN:3843152001000 \EWN:3843152001000
EWN:3843152002000 \EWN:3843152002000
6SC6508-0AA00 \R0 P.C.B TRANSISTOR CONT
95.600.505.3.2 \SEALING SLEEVE CPL.W.5 V
HC7014C \bearing
95.101.241.3.2 \clamping unit
6ES5470-8MA12 \470-8 ANALOG INPUT, 2AO,
6ES7214-2BD23-0XB0 \CPU224XP,AC PS,14DI
GWE:A5E00348076 \DC-bar
EWN:0573000013497 \N/ STATOR FOR 1FT5076
6SN1111-0AA01-1AA0 \SIMODRIVE 611
HCS7012C/01 \Bearing
6SE6411-6UD15-5BA1 \G MM411 480V 0,55k
6FC5253-0BX10-0XG1 \HMI LANGUAGE_CD
6SC6503-0AF01 \FOR SERVICE
C79298-A3238-B530 \Current Clip 500A
6SL3352-7AE32-6AA0 \N FAN TRANSFORMER
6SL3224-0BE23-0AA0 \SINAMICS PM240-IP20-
6FX1126-0BL01 \MEMORY,RAM- 6FX1126-0
6FC9320-5DE01 \N ELECTRONIC HANDWHEEL I
6FX1822-1BX01-2D \n/software
6SC6506-0AA00 \R0 TRANSISTOR CONTROL P.
VS/RGM2GAV3F/02 \Encoder
LB_244ZR/11
6FX1822-1BX02-2D \N COM SW 2.3, MODUL. 2
EWN:5193007703000 \N/ERN1387.003 1PH6
A5E00126161 \IGD2/R Module FSG 380A/4
MTL_A100_01 \Driving ring
6FC5235-0AA06-0AA0 \N/CARDDRIVE WITH CAB
WZA_175147_1 \Tool cone
EWN:5193016201000 \N/FAN COWL 2CW6187 1G
WZA_175460_1 \Tool Insert Unit
EWN:3843135002555 \N/Rotor for 1FT6062-1
6FX1120-6BA01 \U35 PLC-CPU 135W (UP TO
EWN:0572007002130 \EWN:0572007002130
EWN:0572007923090 \EWN:0572007923090
EWN:0572007921090 \EWN:0572007921090
EWN:0572007921130 \EWN:0572007921130
C79298-A3238-B350 \Connector board 1
EWN:3843124602555 \N/Rotor for 1FT6044-1
6SC6100-0GC01 \P.C.B. POWER SUPPLY
A5E02463825 \Capacitor Group
6FX1154-5BA00 \N EPROM MODUL.
NMA:A5E00711805 \ERN 1331.062
EWN:0572010106493 \N/Stator for 1FT6084-
6FX1144-7BA01 \MSTT STANDARD 6FX1144-7
A5E00366791 \BASIS STATION
6FC5250-6BY30-3AH0 \N NCU SYSTEM SW 12 A
6SN1111-0AA01-1CA0 \N MAINS FILTER
C98043-A1002-L3 \MAIN SPINDLE DRIVE CONT
3TF5422-0XN2-Z \AC 250A2NO+2NC220V50/60H
EWN:5194004206000 \N/ ROD 320.002-5000
EWN:5194004201000 \accessories for ROD32
HC7016C/01 \bearing
6SY7010-0AA27 \spare part
6SY7000-0AF73 \SNUBBER- RESISTOR
RG_174640_V_1 \unit for cleanig air oper
6FX8002-5CA51-1EF0 \POWER CABLE, PREASSE
RG_174416_5 \Sliding sleeve
EWN:0573014001150 \RO/STATOR COMPLETE
YAS:UZBA-B63A \G/SERIES REACTOR
ROE_497229
6SC6512-0AA00 \R0 TRANSISTOR CONTROL P.
6SE6420-2AD23-0BA1 \MICROMASTER 420
A5E02039258 \CIO
6FC5112-0CA02-0AA0 \N DMP INTERFACE, CON
6FC5212-0AA01-1AA0 \NCU-
ROE_582875
EWN:0572010108493 \N/Stator for 1FT6086-
FL_943803AA_1 \Adapter for encoder
NMA:2510182400 \bearing 6216.C4.insul.
HC7017E/01 \spindle bearing
EWN:0572007004130 \EWN:0572007004130
EWN:0572007924090 \EWN:0572007924090
3VF5211-2BH41-0AB2 \S4/CIRCUIT-BREAKER
EWN:3843135202555 \N/Rotor for 1FT6082-1
LE_175446A_V_1 \Unclamping unit
A5E02463827 \Capacitor Group
A5E02463818 \Capacitor Group
GWE:5193007701000 \N/BRAKE EBD 1.2B;0.25
6SL3352-7AE35-0AA0 \N FAN TRANSFORMER
A5E00156222 \A5E00156222
6QX5226 \DIODE RECTIFIER D1809N40
A5E00152288 \intermediate
6ES7441-1AA03-0AE0 \SIMATIC S7-400, CP 4
6ES5721-0CB00 \CONNECT.CABLE 721-0, 10M
35421210A \CMHD IO board
6ES7214-1AC01-0XB0 \SIMATIC S7-200, CPU
GWE:A5E00846169 \dc
EWN:8399501550000 \N/1FK606 KIT 8.30 INS
R_9510219792 \Drawbar
A5E00495962 \Display Toshiba new
DK_176291_1 \bearing housing
6SE6440-2AD23-0BA1 \MICROMASTER 440
6GT2002-0EB00 \ASM450
A5E00151304 \cable basic unit FSJ
EWN:5194004204000 \accessories for ROD32
GWE:A5E00209095 \dc
EWN:5192234220000 \ENCODER
EWN:5192234401000 \ENCODER
6ES5430-4UA14 \430-4 DIG. INPUT 32DI, D
ROE_599059 \Clamping Crip
A5E02463828 \Capacitor Group
B71920E/02 \bearing
EWN:3843124803555 \N/Rotor for 1FT6064-1
EWN:0572010107495 \N/Stator for 1FT6086-
6FC5253-6BX10-4AG0 \HMI-ADV PCUSW6.0/6.1
EWN:3843135003555 \N/Rotor for 1FT6064-1
GWE:A5E00200564 \IGD3/R-Bgr.690/930VDC/4
GWE:A5E00209098 \dc
6GT2002-0HA00 \ASM_473
6GK1701-1CW50-3AA0 \SIMATIC NET IE S7-14
6FX1124-6AC02 \SINUMERIK SYSTEM 3, 800
C79298-A3238-B525 \Current Clip 50A
WZA_174686_1 \tool insert unit
WZA_174791B_1 \tool insert unit
YAS:JUSP-NS500 \PROFIBUS DP INTERFACE BO
ZR_SIE_127_85_1 \encoder ring
HC71922E/01 \Bearing
175339A \LOESEEINHEIT
GWE:A5E00156742-Q1 \ZK-Verschn./PWB-GR/6
35421357A \BBB board
EWN:0572012501492 \N / STATOR COMPLETE 1
A5E00195544 \IGD3 module /400V/745A
WZA_174791H_1 \tool insert unit
6SE9996-0XA11 \N MM-INTCM WDSTBREMSEIN
EWN:5192234145000 \ENCODER
6SL3120-1TE21-0AB0 \MOMO.INT400V9A 6SL31
6FX8008-1BD21-3AA0 \SIGNALLEITUNG METERW
SR_176006_1 \SWITCHING RING
A5E00152290 \intermediate
EWN:3843006703555 \Rotor
C79298-A3238-B442 \DBI with CAN
EWN:3843006702555 \N/Rotor for 1PH7133-2
3RG7844-6SD08-0SS1 \R0/ CURTAIN
A5E02463826 \Capacitor Group
A5E02463829 \Capacitor Group
WU33C3029 \Drawbar for Schutte spindle
A5E02463820 \Capacitor Group
EWN:3843009401555 \N/Rotor for 1PH7163-2
6ES7331-7PF10-0AB0 \SIMATIC S7-300, ANAL
100BNR10HTSULP3 \BEARING
YAS:SGMPH-04A4E4B \SERVO MOTOR
1FK7042-5AF71-1AH0 \SYNCHRONOUS SERVOMOT
EWN:0572007201130 \EWN:0572007201130
EWN:0572007202130 \EWN:0572007202130
EWN:0572000601090 \EWN:0572000601090
GWE:A5E00276508 \dc
6FX1121-4BJ02 \N SERVO-INTERFACE, 40 MM
GWE:A5E00205140 \dc
6SN1112-1AB00-1BA0 \MOD,SONST- 4.1MF 6SN
EWN:3843124802555 \N/Rotor for 1FT6062-1
U_RO_175003C_11 \Drawbar, Front part, Po
6AU1400-2PA00-0AA0-Z \SIMOTION D, CF CAR
6ES7630-0DA00-0AB0 \I/O MODULE F. SIMATI
95.600.999/400 \Drawbar Rod Spindle Leng
6FM1707-3AA10 \W35 CAM CONTROLLER WF 70
EWN:3843119903010 \laufer 1FK7103-5
6SY8101-0AA00 \LINE RECTIFIER DIODE D18
GWE:A5E00279706 \dc
6ES7331-7PF01-0AB0 \SIMATIC S7-300, ANAL
A5E02463822 \Capacitor Group
A5E02634807 \Capacitor Group
A5E02463824 \Capacitor Group
6FX1125-7AA02 \N/KEYBOARD
EWN:0572000602090 \EWN:0572000602090
YAS:SGDH-04AE \DRIVE UNIT 1 AXIS 7.5KW
6SE6420-2AD24-0BA1 \MICROMASTER 420
6FC9320-3KT00 \INCREMENTAL ROTARY POS.E
6AV6545-0AA15-2AX0 \TOUCH PANEL TP070 5,
6FX1122-2AM02 \W35 NC TO PLC
6FX1124-1CC10 \R0 MEMORY EPROM 32 BIT
SIE/6FX2001/02 \Encoder
EWN:3843135403555 \N/Rotor for 1FT6084-1
6SC6500-0BC01 \R0 SPINDLE POSITIONING W
ROE_1011061 \clamping set HSK-A50/B63
RG_175442C_2 \ring
GWE:000000599142 \IGBT FS300R17KE3 1700V
EWN:0572010106495 \N/Stator for 1FT6084-
EWN:0572010105496 \N/Stator for 1FT6084-
EWN:0572010106496 \N/Stator for 1FT6084-
EWN:5293004304152 \N/Gear box
6ES5700-3LA12 \CR 700-3 MOUNTING RACK,
6FX1145-4BA00 \N/SINUMERIK
XCB7014E/01 \BEARING
6ES5700-2LA12 \CR 700-2 MOUNTING RACK,
YAS:SGMAH-08A1A4S \G/FEED MOTOR 0.75 KW
6FC5357-0BH00-0XE0 \U45 NCU 570, 4 MEASU
XCB7014E/04 \bearing
GWE:A5E00846173 \dc
A5E00768512 \A5E00768512
6ES5318-8MB13 \IM318-B INTERFACE MOD.,
95.600.999/490 \drawbar
6GK1415-2BA20 \DP/AS-INTERFACE
6FC4600-1AS01 \W35 OPERATOR KEYBOARD
A5E02634808 \Capacitor Group
EWN:8399501535000 \N/1FK604. KIT 8.30 IN
6SE9621-3DD50-Z \MICROMASTER INTEGRATED
1FT6061-1AF71-3EG1 \N AC-VSA-MOTOR, ZK 8
YAS:SGDK-05AEA \G/FEED MODULE
LB_244ZR/12 \Encoder Wheel
6SY8101-0AA01 \LINE RECTIFIER DIODE
6SE7033-2ES87-0FA1 \FILTER 6SE7033-2ES87
GWE:A5E00145361 \IGD2/R-Bgr.690/930VDC/2
6SE6430-2UD31-8DB0 \MICROMASTER 430
6SC6103-0SE31 \W35 POWER CIRCUIT P.C.B
1FK7043-7AH71-1AB0 \RO/SYNCHRONOUS SERVO
1FT5066-0AK71-1-Z \N/MOTOR
6RB2000-0GA00 \R0 P.C.B POWER SUPPLY
6SY8101-0AA32 \DIODE MODULE
YAS:SGMGH-03ACA-MN11 \G/SERVOMOTOR 0.3 K
GWE:A5E00200562 \IGD3/R-Bgr.690/930VDC/4
A5E00156706 \DISPLAY
R_951019931/01 \LOSREINEIT
6SE7021-0EA61 \SIMOVERT MASTERDRIVES
EWN:3843009406555 \N/Rotor for 1PH7167-2
6SL3120-2TE13-0AB0 \MOMO.IN400V2X3A6SL31
C79298-A3238-B400 \Power supply
DK_174687_7 \COVER
6SN2132-1BC11-1BA0 \RO,POSMO A PROGRAMMA
EWN:3843135601555 \N/Rotor for 1FT6102-1
6ES7216-2AD00-0XB0 \SIMATIC S7-200, CPU
EWN:5192017502000 \N/Magnetgeh鋟se
1FK6060-6AF71-1AB0 \SYNCHRONOUS SERVOMOT
EWN:3843085903555 \Rotor
6AV3637-1ML00-0CX0 \OP37 OPERATOR PANEL,
YAS:SGMPH-08AAA-SE11 \G/SERVOMOTOR 0.75
6ES7331-7PF00-0AB0 \SIMATIC S7-300, ANAL
XC71914E/02 \Bearings
6ES7441-2AA00-0AE0 \COMMUNICATION MODUL
6SC6100-0GC14 \R0 P.C.B POWER SUPPLY
1FT5066-1AC71-4FA0 \MOTOR,8NM,2000MIN
FD1012/01 \Bearing
6FM1707-3AA70 \6FM1707-3AA70 CAMCONTROL
6SL3130-6TE21-6AB0 \SLMO.IN400V16KW6SL31
EWN:3843135404555 \N/Rotor for 1FT6086-1
95.600.004.3.6 \Clamping unit
EWN:5193007810000 \N/BRAKE EBD 1.2B;0.25
EWN:0572010108495 \N/Stator for 1FT6086-
6SE6440-2UC27-5DA1 \MICROMASTER 440
6ES5926-3KA12 \W60 CPU CENTRAL CONTROLL
1FK6080-6AF71-1AH0 \SYNCHRONOUS SERVOMOT
1FT5046-0AF71-1-Z \AC FEED DRIVE MOTOR,
C98043-A1210-L41 \W35 DC MAIN SPINDLE DR
6ES5324-3UR11 \IM 324R INTERFACE MOD. F
A5E00121526 \ZZZ/IGD2/R MODULE FSG 49
6ES5103-8MA03 \CPU100 F. S5-100U, DC 24
6FX1120-3BB01 \W35 SINUMERIK 3 PLC CU T
6FX1145-5BA00 \N/SINUMERIK
6SE7015-0EP60-Z \SIMOVERT MASTERDRIVES
6SN1130-1AD11-0CA0 \FEED MODUL., 25 50 A
EWN:0571101701030 \N/BRAKE EBD 1.2B;0.25
HIR:737070-101 \ENT 10515-R 24V DC SPARE
GWE:A5E00145378 \IGD2/R-Bgr.690/930VDC/1
6SL3353-6TE32-6AA3 \SPARE PART CIB/FSF/4
EWN:3843009402555 \N/Rotor for 1PH7163-2
6FX1142-7BA01 \N DMP SUBMODUL.
YAS:SGDK-15AEA \FEED MODULE 1 AXIS 1.5 K
A5E02590187 \Capacitor Group
ROE_466010 \pile
EWN:5193038501000 \N/PULSE GENERATOR ROD
34242169A03 \RTCPU,486DX4-100,8 MB(wa
6SE7015-0EP50 \SIMOVERT MASTERDRIVES
6SE6430-2UD31-8DA0 \MM4, FSD/V/18,5KW 6
6ES5266-8MA11 \IP 266 POSITIONING MODUL
6FX1147-1BA01 \R0 OPI VGA MODUL.
6SE6430-2UD32-2DA0 \MM4, FSD/V/22KW 6SE
6ES5095-8MD01 \S5-95U COMPACT UNIT W. D
6SL3985-6TN00-0AA0 \THYRISTORELECTRONICS
XC7016E/01 \Bearing
NMA:A5E00226495 \END SHIELD NDE
6FC5012-0CA03-0AA0 \IM 328-N INTERFACE
EWN:8399501555000 \N/1FK606 KIT 8.30 INS
EWN:519.30450.01 \R0 INCR. HOLLOW SHAFT
EWN:0571101602030 \Stator
6FX1132-0BA01 \W40 INTERFACE EXT. UNIT
C79298-A3238-B901 \MTI
6SC6100-0GE01 \R0 AC MSD COMBI
NMA:U520261001 \BEARING SHIELD
6FC5203-0AF28-4AN0 \PUSH BUTTON PANEL PP
6FC5247-0AA16-0AA0 \N BACK-LIT 9.5" COLO
6GK7342-5DA01-0XE0 \COMMUNICATION PROCES
6SL3352-6TH38-1AA3 \SINAMICS S
6SL3351-6GH31-8AB3 \SINAMICS G
6SL3352-6TH34-7AA3 \SINAMICS S
6SL3353-6TE41-1CA3 \SINAMICS S
6SL3353-6TE41-5BA3 \SINAMICS S
6SL3353-6TH35-8AA3 \SINAMICS S
6SL3353-6TH36-8BA3 \SINAMICS S
6SL3353-6TH37-4AA3 \SINAMICS S
6SL3353-6TH41-0AA3 \SINAMICS S
6SL3353-6TH41-3AA3 \SINAMICS S
6SL3352-6TH37-4AA3 \SINAMICS S
6SL3352-6TH38-8AA3 \SINAMICS S
ROHR_175003D_1 \Drawbar, Rear part
6SL3353-6TE34-2BA3 \SPARE PART/CIB/BLM/F
EWN:YFT934136202002 \stator for 1FT6108-
6SL3353-6TE35-0AA3 \SPARE PART CIB/FSG/4
6SE7028-6EC85-1HA0 \CONTROL MODULE PER1
95.102.223.9.2 \Drawbar
C79458-L2225-B105 \SIMATIC S5, SPARE PAR
1FN3450-3WC00-0AA1 \PRIMARY SECTION, 776
ROHR_174791A_11 \draw bar front part
YAS:SGDK-20AEA \DRIVE UNIT 2 KW 1AXIS
GWE:A5E00136079 \IGD2/R-Bgr.690/930VDC/3
6FX8002-5DA23-1DG0 \POWER CABLE, PREASSE
6GK1161-3AA00 \COMMUNICATION PROCESSOR
6RA7013-6DV62-0 \SIMOREG DC MASTER CONVE
6ES5524-3UA15 \CP 524 COMMUNICATIONS PR
6SC6140-0FE80 \RETROFIT ASSEMBLY
GWE:A5E00200558 \IGD3/R-Bgr.690/930VDC/5
6FX1124-6AD02 \I/O-MODULE 6FX1124-6
6SL3130-7TE21-6AA0 \ALMO.IN400V16KW6SL31
1FT6062-1AF71-3AH1 \SYNCHRONOUS SERVOMOT
9_LB_ZFN0265.0 \encoder ring
1FT5066-1AC71-4FB0 \MOTOR,8NM,2000MIN
3SJ3002-2AY15-Z \A08+D02
1FT6_STD_B130 \N/Stator complete
1PH7105-2HF32-0BJ0 \COMPACT INDUCTION MO
95.600.073.9.6 \Clamping Set
6FC5370-1AT00-0AA0 \808D HW PPU 141.1 T
6ES5304-3UB11 \IM304 INTERFACE MOD., 60
6FX1144-8BA01 \R0 DMP SUBMODUL. 48IN 48
YAS:SGMGH-13A5A2S \SERVO MOTOR 1.3KW 17B
1FT6062-6AK71-3AG0 \N AC-VSA-MOTOR, ZK 8
6SL3353-6TE36-1AA3 \SINAMICS S
6FC5203-0AD25-0AA0 \PUSH-BUTTON PANEL
SIE/1FE1082/12S \Stator
EWN:51930385.01 \FOR SERVICE
6SL3351-6GH32-2AB3 \SINAMICS G
95.600.124.9.6 \gripper finger
6FX1122-2AA02 \W35 NC TO PLC
6FX2001-8AE05 \G SIZAG 2 TOOTHED-WHEEL
6SL3353-6TH34-3BA3 \SINAMICS S
1FT5064-0AF01-1-Z \N/DRIVE MOTOR
1PH7133-2ND02-0CJ0 \COMPACT ASYNCHRONOUS
SIE/1FE1082/11S \Stator
6SL3356-6TE36-1AA3 \SINAMICS S
95.600.095.9.6 \short clamping unit--0
6SE7021-8TB61 \SIMOVERT MASTERDRIVES
6SC6100-0NA01 \MOD CONTROL ANALOG
6ES7441-2AA03-0AE0 \SIMATIC S7-400, CP 4
YAS:SGMKS-09A5A31 \G/ SERVO MOTOR
4EU2522-1AA00-0AA0 \COM CHK 3AC400V 50HZ
EWN:3843135602555 \N/Rotor for 1FT6105-1
6SL3353-6TE35-5CA3 \SINAMICS S
6SE6440-2AD31-5DA1 \MICROMASTER 440
YAS:SGMGH-03A5A-SE11 \G/FEED MOTOR 0.3 K
ROHR_174791D_3
95.600.075.9.6 \N/clamping unit
6FC5222-0AA02-2AA0 \SINUMERIK MCI2-BOARD
3VL4740-1DC36-0AA0 \CIRCUIT-BREAKER VL 4
95.601.050/860 \DRAWBAR
6SL3351-6GH31-5AB3 \SINAMICS G
6FC5303-1AF12-8BC0 \MPP483IEH-S26, 6FC5
NMA:A5E00226506 \END SHIELD NDE
6FX1122-1AC02 \COUPL.,PLC/NC 6FX1122-1
6RY1241-0BA00 \FAN UNIT (6QX5376)
6SC9421-0CA00 \W40 FBG.ISTA2
6FX1126-7BA01 \W35 MEMORY BOARD, PAGING
6ES5470-4UC12 \470-4 ANALOG INPUT, 8AO,
WZA_176099_1 \Tool insert unit
EWN:0570100101020 \N/Stator for 1PH7163-
6SE6430-2UD33-7EB0 \MICROMASTER 430
6FX1143-3BA01 \W40 KEY REQUEST UNIT
6SL3352-6TH31-0AA3 \SINAMICS S
6SL3352-6TH31-2AA3 \SINAMICS S
6SL3352-6TH31-5AA3 \SINAMICS S
6SL3352-6TH31-8AA3 \SINAMICS S
6SL3352-6TH32-2AA3 \SINAMICS S
1FN3450-4WB00-0AA1 \N AC-VSA-MOTOR, ZK 6
6SL3351-6GH34-7AB3 \SINAMICS G
6RY1243-0EA01 \GATING
6SL3351-6GH34-1AB3 \SINAMICS G
6FX1115-0AA02 \W40 5 8 MHZ VIDEO INTERF
6SC6504-0AA02 \R0 P.C.B. TRANSISTOR CON
EWN:YFA521353911001 \1PH7ERSATZ-STANDER
6SL3352-6TH33-3AA3 \SINAMICS S
6FX1113-6AA00 \R0 MS321-A, MEAS.CIRC. 2
6SL3352-6TH28-5AA3 \SINAMICS S
6RY1702-0CA33 \THYRISTOR LINE FRONT
6RB2120-0FD01 \W40 P.C.B POWER-CIRCUIT
6EW1890-1AB \R0 POWER SUPPLY UNIT
C79298-A3238-B451 \Motherboard
1PH7107-2HF20-0BA0 \COMPACT INDUCTION MO
6SL3353-6TE41-7CA3 \SINAMICS S
6FC5247-0AA16-0AA1 \N 10.4" BACK-LIT COL
YAS:SGMGH-05K5A-SE12 \G/FEED MOTOR 0.5 K
EWN:3843135801555 \N/Rotor for 1FT6102-1
ROHR_174791A_12 \draw bar rear part
SIE/1FE1052/04S \1FE1052-6WN10-4BW0 Sta
34242198A \Assem-Pendant, TC, ISO,
6SE6430-2UD34-5EA0 \MM4, FSE/V/45KW 6
1FT5106-1AC71-1AG0 \N AC-VSA-MOTOR, ZK 8
EWN:3843005803555 \ROTOR
6FX1113-5AA00 \R0 MS311-A, MEAS.CIRC. 2
6FM1706-3AA20 \W35 WF 706 POSITIONING A
6SE6430-2UD33-7EA0 \MM4, FSE/V/37KW 6
STA_176089A_1 \stator
DK_175381_1 \piston cover
6SY8102-0LB00 \THYRISTOR-ELEKTRONICS TA
6SL3300-1AH32-5BA0 \BRAKING-UNIT 690V;20
1FT7084-5AC71-1FG0 \SYNCHRONOUS MOTOR 1F
6FX1192-3AC00 \R0 MS122-C
6SL3000-0DE31-2AA0 \SINAMICS / SIMODRIV
6FC5501-0AB11-0AA0 \W50/CNC ECU 802CE
6FX1121-4BB02 \R0 SERVO-INTERFACE 40 MM
6SY7010-0AB43 \THYRISTOR BLOCK OF LEVEL
ROHR_175003B_V1 \brawer
SIE/1FE1106-4A \rotor
6SN1124-1AA00-0EA2 \LT-MOD.EXT160A -G2 6
6ES5470-4UA13 \470-4 ANALOG INPUT, 8AO,
6SL3351-6GH28-5AB3 \SINAMICS G
EWN:519.40042.04 \N INC. ROTARY TRANSDUC
6EW1890-0AB \R0 POWER SUPPLY UNIT
EWN:9999999914000 \1PA6ERSTAZ-STANDER
6FX1121-4BB01 \N SERVO-INTERFACE, 40 MM
6FX1121-2BA03 \W35 880 INTERFACE PCB
6FC5303-1AF02-8AK0 \MPP 483 HTC-S10, 6F
ROE_582873 \drawbar
YAS:SGMKS-09A5A3B \G/SERVOMOTOR
6FC5203-0AF50-3AA1 \W45/CONTROL PANEL
6ES5308-3UC21 \IM308-C INTERFACE MOD. F
EWN:3842141902555 \N/ ROTOR 1FT6134
YAS:SGMGH-20A5A2B \SERVO MOTOR 1.8 KW /1
6SN1118-0DH13-0AA0 \W45 CLOSED-LOOP PLUG
RG_174791F_1 \hydraulik part housing
6SE6440-2UD38-8FA0 \MICROMASTER
6FM1706-3AB20 \POS.-/COUNT-MOD_WF_706_6
6FM1470-4AA25 \W40 DISPL.MODUL. WF 470A
3KL6130-1AB02 \SW.DISCON. W.F. 630A/3P/
6SL3351-6GF38-1AB3 \SINAMICS G
6FX1190-7AA00 \W55 MS230-A, MEAS.CIRC.
YAS:SGMGH-05K5A-SE11 \G/ FEED MOTOR 0.5
6ES5470-7LA13 \470-7 ANALOG INPUT, 8AO,
1PH7137-2HD03-0BA0 \1PH7137-2HD03-0BA0
6SE7021-8TP50 \SIMOVERT MASTERDRIVES
6ES5942-7UB11 \CPU942 CENTR.CONTR.MOD.
6SY7000-0AD84 \DC
WZA_176246_1 \Tool insert unit
6SC6170-0FC51 \W40 POWER UNIT MODUL.
6FC5510-0BA11-0AA1 \SINUMERIK 802C NC CO
6ES5460-7LA13 \460-7 ANALOG INPUT, 8AI,
1PH7163-2ND03-0CJ0 \COMPACT ASYNCHRONOUS
NMA:U131006001 \stator
34242138A02 \power supply
6FX8002-5CC16-2AC0 \POWER CABLE, PREASSE
95.250.023.3.0 \rotary unit
WU33A3001B \Shaft for Schutte grinding s
6SE6430-2UD35-5FB0 \MICROMASTER 430
6ES5242-1AA13 \SIMATIC S5 , IP 242 COUN
6ES5922-3UA11 \CPU922 CENTR.CONTR.MOD.
6AV3627-1QK00-2AX0 \TP27-6 TOUCH PANEL
6SL3224-0BE33-7UA0 \SINAMICS PM240-IP20-
WE_175976_V_1 \Shaft Complete
6FX1135-7BB01 \W40/SINUMERIK810
6SY8101-0AA31 \ISOLATION MONITORING ACC
6FC5103-0AB02-0AA0 \SLIMLINE OPERATOR PA
6SC6120-0FE01 \W40 POWER P.C.B
ROE_490967
6FX1125-5AA00 \VIDEO-ANSCHALTUNG FARBE
6FX1111-0AR02 \R0 SINUMERIK 3 BAS. VERS
6ES7412-1XF01-0AB0 \SIMATIC S7-400, CPU
6RY1702-0CA18 \THYRISTOR LINE BACK
6GK1105-2AA10 \OSM ITP62
YAS:UTSJB-B18BDDAB \G/EXTERNAL SPINDLE E
YAS:SGDK-050505AEA \G/FEED MODULE
ROE_466346 \Clamping Unit
95.600.640.9.2 \Drawbar
1PH4103-4NF26 \N AC MAIN SPINDLE MOTOR
1PH2115-6WF41 \AC-HSA-EINBAUMOTOR, ZK 6
1FT6102-8AB71-4EG2 \SYNCHRONOUS SERVOMOT
6FM1723-3CA70 \ZZZ/WF 723C POSITIONING
1FT6062-6AF71-3AG1 \SYNCHRONOUS SERVOMOT
6AV3637-7AB16-1AM0 \OEM-OP37 UPRIGHT HOU
6FC5203-0AB13-0AA2 \W45 OPERATOR PANEL O
95.601.048.9.2 \Drawer
6ES5466-3LA11 \466-3 ANALOG INPUT, 8/16
6SL3121-1TE26-0AA3 \MOMO.EX400V60A 6SL3
6SN1123-1AA02-0FA1 \PO.MOD.SHL200A 6SN11
6FC5210-0DA21-0AA1 \R0 MMC 102 WITH SYST
6SL3351-6GE32-1AB2 \SINAMICS G
6SC6503-0AF02 \R0 POWER-CIRCUIT P.C.B 3
6SL3120-1TE26-0AA1 \MOMO.IN400V60A 6SL31
95.101.993.1/06 \hydraulic part
6FC5548-0AC13-0AA0 \SIMODRIVE BL(V3)
6FC5510-0BA00-0AA0 \SINUMERIK 802S NC CO
6FC5270-6AX30-2AH0 \SOFTWARE FOR COMMISS
6FX1128-1BA00 \W35 MEMORY PCB W O RAM
6SE7026-0ED61 \SIMOVERT MASTERDRIVES
YAS:CIMR-MXN2015 \SPINDEL DRIVE 15 KW AC
6ES5308-3UB11 \IM308-B INTERFACE MOD. F
6SE6440-2UD34-5FA1 \MICROMASTER 440 WITH
SIE/1FE1106/05S \1FE1106-4WS51-4ZW3,Z=V0
6ES5512-5BC12 \missing interface module
6FX1138-6BB01 \CPU,PLC- 135W 6FX1138-6
34242130A01 \OSA CRT
1FT5108-0AA71-1-Z \AC FEED DR. MOTOR
6SC6500-0NA44 \R0 CLOSED-LOOP CONTROL M
6FX1111-0AM02 \W45/SINUMERIK
6FX1136-3BB01 \R0 SERVO CPU 32 BIT
EWN:SNFM311189903001 \N / STATOR FOR
6ES7416-1XJ00-0AB0 \CPU416-1, MPI, 512KB
1FE1114-6WT11-1BA0 \BUILT-IN SYNCHRONOUS
6AU1350-2AG21-1BC1 \P350 BOX+ISOPROFIBUS
6SY8102-0CB11 \spare part
GAT_15047601 \Rotary Unit
YAS:CIMR-MRXN2015 \CONVERTER UNIT 15 KW
SIE/4EU43510/01 \CHOKE
6ES7713-1BB13-0AA4 \SIMATIC FIELD PG M2
6SY8102-1EB30 \COMPLETE LINE SIDE DIODE
95.250.079.2.0 \Rotary Unit
WE_175392_V_1 \rotor
6ES5921-3UA12 \SIMATIC S5, CPU 921 , CE
6SE6440-2UD37-5FB1 \MICROMASTER 440 WITH
YAS:UAKB-08BKO11 \SPINDLE MOTOR 5,5KW 1
6SE6430-2UD38-8FB0 \MICROMASTER 430
802S \Accessory
6ES7650-0LF16-0YX0 \SIMATIC PCS7 ES/OS I
EWN:3842141902003 \n/Rotor complete
6ES7720-1AB20-0YA0 \PG 720, SW-DISPLAY
6AV6541-0AA05-0BB0 \OPERATOR PANEL OP37/
6SE6440-2UD38-8FB1 \MICROMASTER 440 WITH
YAS:USAJKM-30-MN31 \G/ SPINDLE MOTOR
6SY8102-0GB30 \COMPLETE LINE SIDE DIODE
6SY8102-0CB30 \COMPLETE MP DIODE MODULE
WE_174731B_V_1 \Shaft complete with roto
6FX1125-8AA04 \W45 810, BASIC VERSION 1
6FC5222-0AA00-1AA0 \W40 SINUMERIK MCI BO
6SL3224-0BE37-5UA0 \SINAMICS PM240-IP20-
6ES5244-3AB31 \IP 244B TEMPERATURE CONT
6AV7615-0AF32-0CF0 \S2 PANEL PC 670
6SY8102-0AD11 \COMPLETE IGBT-MODULE 180
6SY8102-0AC11 \COMPLETE IGBT-MODULE 180
6SL3320-1TE32-6AA0 \EB+/FSF/650VDC/260A/
6SL3120-1TE32-0AA0 \MOMO.IN400V200A6SL31
6SY8102-0CB20 \COMPLETE MP DIODE MODULE
6SY8102-0GD30 \COMPLETE LINE SIDE DIODE
6SY8102-0GD20 \COMPLETE LINE SIDE DIODE
6FX1120-4BF02 \W45 SINUMERIK 850 880
6SY8102-0CB10 \spare part
YAS:USAJKM-30-MN52 \SPINDLE MOTOR
6DD1607-0AA1 \FM458-1 DP APPLICATION
6SY8102-0HB30 \W20 WK-Netzdiodenbauste
6AV7725-2BC10-0AD0 \SIMATIC PANEL PC 670
6SY7010-0AB32 \THYRISTOR BLOCK OF LEVEL
6SY8102-0HC30 \W20 WK-Netzdiodenbauste
1GG6162-0JC40-6VV5-Z \DC MOTOR, IP 23
6SY8102-1FD30 \W20 WK-Netzdiodenbauste
6SL3224-0BE38-8UA0 \SINAMICS PM240-IP20-
6SY8102-0HD30 \W20 WK-Netzdiodenbauste
6FC5357-0BY32-1AE0 \R0 NCU 573.2
6ES5927-3KA13 \W50 CPU 927
6FC5357-0BY32-0AE1 \R0 NCU 573 .2
6RA7081-6DV62-0-Z \G64+G75+K01+K11+S00
NMA:STATOR GEHAUSE/M \stator
6ES5926-3SA12 \926 CENTR.CONTR.MOD. 926
6DD2920-0AM0 \DIGITAL CONTROL SYSTEM S
6FX1147-5BA02 \W50 EXPANSION BOARD
6FX1120-4BD03 \W45 850 880 COM CPU
6SL3300-7TE35-0AA0 \UNIT AIM 3 (G2) EG 4
6SY8102-0BB20 \W20 WK-IGBT-Baustein, 4
6ES5944-7UB21 \CPU944 CENTR.CONTR.MOD.
6SY8102-0AB30 \COMPLETE IGBT-MODULE 600
6SY8102-0AD10 \COMPLETE IGBT-MODULE 180
6SY8102-0AC10 \COMPLETE IGBT-MODULE 180
6SY8102-0BB30 \W20 WK-IGBT-Baustein, 6
6SL3352-1AG35-8CA1 \SINAMICS PWB FSH 1PH
6SL3353-1AG41-1DA1 \SINAMICS PWB BLM FSG
6SL3352-1AG35-8EA1 \SINAMICS PWB FSH 2PH
6AV8011-1LE62-0KA0 \COLOR MONITOR MP54/C
6SL3352-1AG38-1FA1 \SINAMICS PWB FSJ 1PH
6ES5948-3UA21 \CPU948 CENTR.CONTR.MOD.F
6ES5948-3UA22 \CPU948 CENTR.CONTR.MOD.F
3WL1210-4CB34-4AN2-Z \FIXED-MOUNTED CIRC
6SY8102-0AD20 \TWO COMPLETE IGBT-MODULE
6SY8102-0AC20 \TWO COMPLETE IGBT-MODULE
6SL3352-1AG38-8FA1 \SINAMICS PWB FSJ 1PH
6SY8102-0BD20 \W20 Zwei IGBT-Bausteine
6SY8102-0BC20 \W20 Zwei IGBT-Bausteine
6SY8102-0AD30 \TWO COMPLETE IGBT-MODULE
6SY8102-0AC30 \TWO COMPLETE IGBT-MODULE
6DD1606-3AA0 \SIMADYN D , PROCESS MODU
6SE7041-0EH85-0AA0 \SIMOVERT MASTERDRIVE
6SY8102-0BD30 \W20 Zwei IGBT-Bausteine
6SY8102-0BC30 \W20 Zwei IGBT-Bausteine
3WL1216-4CB34-4AN2-Z \FIXED-MOUNTED CIRC
6SE7041-8EK85-1AA0 \SIMOVERT MASTERDRIVE
6SL3982-5CX60-0AA0 \IGCT PHASE MODULE 1.
