Specification(技术参数) Decay Tdst Results(测试结果)
Operating Votage(工作电压)
4.6KV
Cirremt consumption(消耗电流)
200uA
Operating Temperature(操作温度)
-10~50℃
Weight(重量)
0.55KG
H.V cable(高压电缆线)
3Meters
Air pressure(空气压力)
45~700psi
Air velocity(气流速度)
>10M/sce
Testing Conditions(测试条件)
Testing voltage(测试电压)1Kvto100V operating voltage(操作电压)110/220V Temperature(操作温度 22℃
Distance(距理)
300mm
600mm
900mm
Decay time
(中和时间)
Posivive(正)
0.1s
0.4s
0.7s
Negative(负)
0.1s
0.3s
0.8s
