1. Standard Specification, Bonding and Storage Conditions, Repairability, and Characteristics
Item
Unit
MF-331
Remark
Min. connection area
um2
60,000
Fine pitch
capability
Min. space
um
50
Line
um
pcs
50
Spacing
Resolution
um
/mm
50
Thickness
um
25
Length
m
50
Width
mm
1.5, 2.0
Material
Au-coated plastic
Size
um
Conductive particle
Density
pcs. / mm2
800
Thickness
um
50
Color
White
Separator
Type
Antistatic easy peel-off
Color
Transparent (gray)
Standard specification
Core
mm
18.5
Temperature
deg. C
80 +/- 10
Connection Film’s ultimate temperature
Pressure
MPa
1
Temporary
Time
S
1-3
Temperature
deg. C
150 +/- 10
Pressure
MPa
3±1
Bonding conditions
Final
bonding
Time
s
Packed
6 months after date of manufacture when stored at -10 to 5deg. C.
Unpacked
1 week at 25deg. C or below and 70%RH or below.
Storage conditions
Shelf life
Pre-bonded
1 week at -10 to 5deg. C. 1 week at 25℃ or below and 70%RH or below.
Repairability
Repairable
By acetone or toluene
Connection resistance
ohm
0.1
Ag paste PET / FPC; bonding width, 1.5mm
Insulation resistance
ohm
1012
Space 50μm; bonding width, 2.5mm
Peel strength(20℃)
N/m
600
Ag paste PET / FPC hot-bonded
Tack strength(20℃)
kN/m
0.1
Ag paste PET / FPC cold-bonded
Characteristi
Separator peeling strength
gf/2.5mm
1.5
ITO glass
Notes: 1)Take Connection Film out of the refrigerator or other storage without taking it out of its hermetic containers. Leave the Connection Film in the containers at room temperature for
2)Connection resistance: The table indicates a half of the resistance between neighboring circuits.
Current measured: 1mA. Includes the circuit resistances of the FPC and ITO glass.
3)Tack strength: Pre-bond an Connection Film sample to an ITO glass, peel its separator off, then tack s FPC to
it at room temperature. Then measure the tack strength of this sample.
4)Operating range: As per reliability tests using Hitachi’s test pieces.(This range varies according to the material used and external stress app
