西门子数控和伺服产品型号
数控系统及驱动装置订货号码对照表
MLFB Product de
1FK6063-6AF71-1EH0 11NM,3000rpm,6-pole motor, absolute valuel encoder 2048p/rev;plain shaft, with hold brake, IP64
1FK6101-8AF71-1EG0 27NM,3000rpm,8-pole motor, absolute valuel encoder 2048p/rev;plain shaft, IP64
1FK7042-5AF71-1AG0 3.2Nm,3000rpm,incremental encoder,plain shaft
1FK7042-5AF71-1AH0 3.2Nm,3000rpm,incremental encoder,plain shaft,with brake
1FK7042-5AF71-1DG5 3000RPM,Inc Encoder,IP65,D.E: IP67,paint, 3NM,without brake
1FK7042-5AF71-1DH5 3000RPM,Inc Encoder,IP65,D.E: IP67,paint, 3NM,with brake
1FK7042-5AF71-1SG0 3Nm,3000rpm,8-pole resolver [RESOLVER P=4], plain shaft
1FK7042-5AF71-1SH0 3Nm,3000rpm,8-pole resolver [RESOLVER P=4], plain shaft, BRAKE
1FK7060-5AF71-1AB0 6Nm,3000rpm,incremental encoder,with fitted key and keyway,with brake
1FK7060-5AF71-1AG0 6Nm,3000rpm,incremental encoder,plain shaft
1FK7060-5AF71-1AH0 6Nm,3000rpm,incremental encoder,plain shaft,with brake
1FK7060-5AF71-1DG5 3000RPM,Inc Encoder,IP65,D.E: IP67,paint, 6NM,without brake
1FK7060-5AF71-1DH5 3000RPM,Inc Encoder,IP65,D.E: IP67,paint, 6NM,with brake
1FK7060-5AF71-1SG0 6Nm,3000rpm,8-pole resolver [RESOLVER P=4], plain shaft
1FK7060-5AF71-1SH0 6Nm,3000rpm,8-pole resolver [RESOLVER P=4], plain shaft, BRAKE
1FK7063-5AF71-1AA0 11Nm,3000rpm,incremental encoder,with fitted key and keyway
1FK7063-5AF71-1AG0 11Nm,3000rpm,incremental encoder,plain shaft
1FK7063-5AF71-1AH0 11Nm,3000rpm,incremental encoder,plain shaft,with brake
1FK7063-5AF71-1DG5 3000RPM,Inc Encoder,IP65,D.E: IP67,paint, 11NM,without brake
1FK7063-5AF71-1DH5 3000RPM,Inc Encoder,IP65,D.E: IP67,paint, 11NM,with brake
1FK7063-5AF71-1SG0 11Nm,3000rpm, 8-pole resolver [RESOLVER P=4], plain shaft
1FK7063-5AF71-1SH0 11Nm,3000rpm, 8-pole resolver [RESOLVER P=4], plain shaft, brake
1FK7080-5AF71-1AG0 8Nm,3000rpm,incremental encoder,plain shaft
1FK7080-5AF71-1AH0 8Nm,3000rpm,incremental encoder,plain shaft,with brake
1FK7080-5AF71-1DG5 3000RPM,Inc Encoder,IP65,D.E: IP67,paint, 8NM,without brake
1FK7080-5AF71-1DH5 3000RPM,Inc Encoder,IP65,D.E: IP67,paint, 8NM,with brake
1FK7080-5AF71-1SG0 8Nm,3000rpm,8-pole resolver [RESOLVER P=4], plain shaft
1FK7080-5AF71-1SH0 8Nm,3000rpm,8-pole resolver [RESOLVER P=4], plain shaft, BRAKE
1FK7080-5AF71-1TG0 8Nm,3000rpm,2-pole resolver [RESOLVER P=1], plain shaft
1FK7083-5AF71-1AA0 16Nm,3000rpm,incremental encoder, with fitted key and keyway
1FK7083-5AF71-1AG0 16Nm,3000rpm,incremental encoder, plain shaft
1FK7083-5AF71-1AH0 16Nm,3000rpm,incremental encoder, plain shaft,with brake
1FK7083-5AF71-1DG5 3000RPM,Inc Encoder,IP65,D.E: IP67,paint, 16NM,without brake
1FK7083-5AF71-1DH5 3000RPM,Inc Encoder,IP65,D.E: IP67,paint, 16NM,with brake
1FK7083-5AF71-1SG0 16Nm,3000rpm, 8-POLE resolver [RESOLVER P=4],plain shaft
1FK7083-5AF71-1SH0 16Nm,3000rpm, 8-POLE resolver [RESOLVER P=4],plain shaft, BRAKE
1FK7100-5AF71-1AG0 18Nm,3000rpm,incremental encoder,plain shaft
1FK7100-5AF71-1AH0 18Nm,3000rpm,incremental encoder,plain shaft,with brake
1FK7100-5AF71-1DG5 3000RPM,Inc Encoder,IP65,D.E: IP67,paint, 18NM,without brake
1FK7100-5AF71-1DH5 3000RPM,Inc Encoder,IP65,D.E: IP67,paint, 18NM,with brake
1FK7100-5AF71-1SG0 18Nm,3000RPM,8-POLE resolver [RESOLVER P=4], plain shaft
1FK7100-5AF71-1SH0 18Nm,3000RPM,8-POLE resolver [RESOLVER P=4], plain shaft, BRAKE
1FK7100-5AF71-1TG0 18NM,3000rpm, 2-POLE resolver [RESOLVER P=1], plain shaft
1FK7101-5AF71-1AA0 27Nm,3000rpm,incremental encoder,with fitted key and keyway
1FK7101-5AF71-1AG0 27Nm,3000rpm,incremental encoder,plain shaft
1FK7101-5AF71-1AH0 27Nm,3000rpm,incremental encoder,plain shaft,with brake
1FK7101-5AF71-1DG5 3000RPM,Inc Encoder,IP65,D.E: IP67,paint, 27NM,without brake
1FK7101-5AF71-1DH5 3000RPM,Inc Encoder,IP65,D.E: IP67,paint, 27NM,with brake
1FK7101-5AF71-1SG0 27Nm,300rpm, 8-pole resolver [RESOLVER P=4], plain shaft
1FK7101-5AF71-1SH0 27Nm,300rpm, 8-pole resolver [RESOLVER P=4], plain shaft, BRAKE
1FK7103-5AF71-1AA0 36Nm,3000rpm,incremental encoder,with fitted key and keyway
1FK7103-5AF71-1AG0 36Nm,3000rpm,incremental encoder,plain shaft
1FK7103-5AF71-1AH0 36Nm,3000rpm,incremental encoder,plain shaft,with brake
1FK7103-5AF71-1DG5 3000RPM,Inc Encoder,IP65,D.E: IP67,paint, 36NM,without brake
1FK7103-5AF71-1DH5 3000RPM,Inc Encoder,IP65,D.E: IP67,paint, 36NM,with brake
1FK7103-5AF71-1SG0 36Nm,plain shaft
1FK7103-5AF71-1SH0 36Nm,plain shaft,with brake
1FK7105-5AF71-1DG5 3000RPM,Inc Encoder,IP65,D.E: IP67,paint, 45NM,without brake
1FK7105-5AF71-1DH5 3000RPM,Inc Encoder,IP65,D.E: IP67,paint, 45NM,with brake
1FT5102-1AA71-4FA0 33NM/1200RPM/ROD320
1FT5102-1AC71-1FA0 33NM/2000RPM/ ADDTIONALLY INSTALLED ROD320 2500 P/REV
1FT6084-8AK71-3AG2 20Nm,600rpm, IM B5, I-2048, plain shaft
1PH7101-2NF02-0BJ0 3.7kW,1500rpm,IM B5,plain shaft
1PH7101-2QF02-0BC0 3.7KW,IM B5,IP55,vibration grade R,with full key
1PH7103-2NF00-0BJ3 5.5kW,1500rpm,IM B3,plain shaft,standard paint finish
1PH7103-2NF02-0BJ0 5.5kW,1500rpm,IM B5,plain shaft
1PH7103-2NF03-0BJ0 5.5kW,1500rpm,IM B35,plain shaft
1PH7103-2QF02-0BA0 5.5KW,IM B5,IP55,vibration grade R,with halfkey
1PH7103-2QF02-0BC0 5.5KW,IM B5,IP55,vibration grade R,with full key
1PH7103-2QF02-0BJ0 5.5KW,IM B5,IP55,vibration grade R,smooth shaft
1PH7105-2NF02-0BC0 7kW,1500rpm,IM B5,with fitted key
1PH7105-2NF02-0BJ0 7kW,1500rpm,IM B5,plain shaft
1PH7105-2NF03-0BA0 7kW,1500rpm,IM B35,with fitted key
1PH7105-2NF03-0BJ0 7kW,1500rpm,IM B35,plain shaft
1PH7105-2QF02-0BA0 7KW,IM B5,IP55,vibration grade R,with halfkey
1PH7105-2QF02-0BC0 7KW,IM B5,IP55,vibration grade R,with full key
1PH7105-2QF02-0BJ0 7KW,IM B5,IP55,vibration grade R,smooth shaft
1PH7107-2NF02-0BJ0 9kW,1500rpm,IM B5,plain shaft, R
1PH7107-2NF02-0CA0 9kW,1500rpm,1Vpp 2048, IM B5,plain shaft, R
1PH7107-2NF03-0CJ0 9kW,1500rpm,IM B5,plain shaft,S
1PH7107-2QF02-0BJ0 9KW,IM B5,IP55,vibration grade R,smooth shaft
1PH7107-2QF02-0CC0 9KW,IM B5,IP55,vibration grade C,with full key
1PH7107-2QF02-0LC0 9KW,IM B5,IP56,vibration grade C,with full key, performance
1PH7131-2NF00-0BA0 11kW,1500rpm,IM B5,with fitted key, half-key
1PH7131-2NF02-0BC0 11kW,1500rpm,IM B5,with fitted key, full-key
1PH7131-2NF02-0BJ0 11kW,1500rpm,IM B5,plain shaft
1PH7131-2NF03-0BC0 11kW,1500rpm,IM B35,with fitted key, full-key
1PH7131-2QF02-0BC0 11KW,IM B5,IP55,vibration grade R,with full key
1PH7133-2ND02-0CA0 12kW,1500rpm,IM B5,with fitted key, half-key
1PH7133-2QD02-0CA0 12KW,IM B5,IP55,vibration grade C,with half key
1PH7137-2QD02-0CA0 17KW,IM B5,IP55,vibration grade C,with half key
6ED1052-1FB00-0BA3 LOGO!230RC 8 DI/4 DO
6EP1333-2AA00 Power supplies 220V/24V, 5A
6EP1333-3BA00 Power supplies 220V/24V, 5A
6EP1334-3BA00 Power supplies 220V/24V, 10A
6EP1436-2BA00 SITOP POWER 20 3X400-500VAC/24VDC 20A
6EP1436-3BA00 SITOP power,3-PH, 400-500VAC; 24VDC, 20A
6EP5306-5BG00 CABLE SET consisting of 6M (19 FT 8IN.) flat ribbon cable and 8 IDC-connectors, 50pin with strain relief device for self mounting
6EP5406-5AA00 TERMINAL STRIP CONVERTERFROM 50-PIN IDC-CONNECTORTO SCREW-TYPE TERMINALSFOR 1 TO 1 CONNECTION, W/O LED
6ES5734-2BD20 Cable PG7XX and S5-90U to 155U
6ES7216-2BD00-0XB0 SIMATIC S7-200, CPU 216, 24I/16O, 2 PPI
6ES7231-0HC00-0XA0 SIMATIC S7-200, ANALOG INPUT EM231, NON-ISOLATED, 3AI 12 BIT UNIPLOLAR, DC-0-5V/ DC 0-10V, 0-20MA FOR S7-21X CPU ONLY
6ES7307-1EA00-0AA0 SIMATIC S7-300, PS307, 120/230VAC; 24VDC, 5A
6ES7307-1KA00-0AA0 SIMATIC S7-300, PS307, 120/230VAC; 24VDC, 10A
6ES7321-1BH02-0AA0 SM321 digital input modules,16 inputs,24V dc
6ES7321-1BL00-0AA0 SM321 digital input modules,32 inputs,24V dc
6ES7322-1BH01-0AA0 SM322 digital output modules,16 outputs, 24V dc, 0.5A
6ES7322-1BL00-0AA0 SM322 digital output modules,32 outputs, 24V dc, 0.5A
6ES7322-1HH00-0AA0 SM322 digital output modules,16 outputs, 24V dc, 2A relays
6ES7323-1BH80-0AA0 *** SM323 digital input/output, 8 DI/8 DO,24Vdc,0.5A
6ES7332-5HB01-0AB0 *** SM332 anolog output module, 2 anolog putput
6ES7361-3CA01-0AA0 Interface IM361
6ES7368-3BB01-0AA0 "Pre-assembled connecting cable
between IM 360 and IM 361 or IM 361 and IM 361, 1m"
6ES7368-3BC51-0AA0 "Pre-assembled connecting cable
between IM 360 and IM 361 or IM 361 and IM 361, 2.5m"
6ES7390-1AE80-0AA0 SIMATIC S7-300, RAIL, L=480MM
6ES7390-1AF30-0AA0 SIMATIC S7-300, RAIL, L=530MM
6ES7392-1AJ00-0AA0 Front connector 20-way with screw contacts
6ES7392-1AM00-0AA0 Front connector 40-way with screw contacts
6ES7901-3BF21-0XA0 PC/PPI Cable connectiong S7-200 to serial port of PC repacement:6ES7901-3CB30-0XA0
6ES7901-3CB30-0XA0 PC/PPI Cable connectiong S7-200 to serial port of PC
6ES7951-0KE00-0AA0 SIMATIC S7, MEMORY CARD FOR S7-300, SHORT VERSION, 5V FLASH EPROM, 32KBYTES
6ES7953-8LF11-0AA0 SIMATIC S7 MICRO MEMORY CARD, 64K
6ES7971-1AA00-0AA0 SIMATIC S7 BACKUP BATTERY [LI] 3.6V/0.95Ah FOR S7-300 CPUS and S5-90U
6ES7972-0BA41-0XA0 PROFIBUS connector
6ES7972-0CA23-0XA0 SIMATIC S7 PC ADAPTER RS232 TO RS485
6ES7972-0CB20-0XA0 SIMATIC S7 PC ADAPTER USB F. CONNECTOR OF S7-200/300/400 C7; RS232 TO RS485 WITH USB-CABLE A(5M) CAN BE USED UNDER WIN 2000/XP
6EV3055-0DC SINUMERIK 810 POWER SUPPY 24VDC/5VDC, 15A
6FC3178-3EF20 J85, MCP for SINUMERIK 810T
6FC3251-1AC-Z Z=J81+K20 SINUMERIK 810T GA3
6FC3551-1AC-Z Z=J81+K20 SINUMERIK 810M GA3
6FC3821-2AC-Z Z=J82+K20 SINUMERIK 810N GA3 SW23
6FC3984-3RA M01 Input/output submodule, as a basic submodule with mounting plate = 6FX1124-6AD02
6FC3984-3RL M10 SINUMERIK OPTION SUPPLIED SEPARATELY INTERFACE SUBMODULE FOR ELECTRONIC HANDWHEELS =6FX1126-5AA01
6FC3984-7AG20 SINUMERIK OPERATOR PANEL FRONT FLATE
6FC3988-7AF01 SINUMERIK 810/SYSTEM 3 22CM[9"] MONO MONITOR
6FC5110-0CA01-0AA0 SINUMERIK 840C/840CE PLC CPU 135WB2 WITHOUT SYSTEM SW
6FC5203-0AB10-0AA1 SINUMERIK FM-NC/810D/DE/840D/DE SLIMLINE OPERATOR PANEL OP031 19" OP W.24CM/9.5" MONOCHROME FLATSCREEN, STANDARD LAYOUT
6FC5203-0AD10-0AA0 19" machine control pannel with mechanical keys, standard/US layout
6FC5203-0AF00-0AA1 Operator panel front OP 010
6FC5203-0AF01-0AA0 Operator panel front OP 010C
6FC5203-0AF02-0AA0 Operator panel front OP 012 12.1"TFT 800X600 SVGA
6FC5203-0AF02-0AA1 Operator panel front OP 012 12.1"TFT 800X600 SVGA
6FC5203-0AF03-0AA0 Operator panel front OP 015
6FC5203-0AF04-0AA0 Operator panel front OP 010S
6FC5203-0AF22-0AA0 Machine Control Panel MCP 483C MPI,19" with mechanical keys
6FC5203-0AF22-0AA2 Machine Control Panel MCP 483C MPI,19" with mechanical keys
6FC5210-0DA00-1AA1 SINUMERIK MMC100.2 WITH SYSTEM SOFTWARE WITH INTEL 486, 12MB DRAM
6FC5210-0DF00-0AA1 SINUMERIK 810D/840D PCU20: SPC 166 MHZ; 32 MB DRAM16 MB FLASH; 24 V DCWITH CURRENT HMI SOFTWARE
6FC5210-0DF04-0AA0 PCU 70
6FC5210-0DF22-0AA1 SINUMERIK PCU 501.2 GHZ, 256 MB RAM; 24 V DC;WINDOWS XP PROFESSIONALFOR EMBEDDED SYSTEMS(WINXP PRO E
6FC5210-0DF22-2AA0 SINUMERIK PCU50 1.2G/256MB RAM/ XP
6FC5211-0BA01-0AA2 ADI4
6FC5247-0AA00-0AA2 SINUMERIK 840D/DE NCU BOX
6FC5247-0AA00-0AA3 SINUMERIK 840D/DE NCU BOX
6FC5247-0AA11-0AA2 PC card acc. To PCMCIA standard 8M (empty)
6FC5247-0AA11-0AA3 Memory card,8Mbyte
6FC5248-0AF20-2AA0 Mounting brackets
6FC5250-0BX30-0AH0 12 axes on PC card, Standard 840D powerline
6FC5250-0BY30-0AH0 "12 axes on PC card, Export 840DE powerline ? Single license for current software version"
6FC5250-0CX30-0AH0 "NCU system software, 6 axes on PC card, standard 840D powerline"
6FC5250-0CY30-0AH0 "6 axes on PC card, Export 840DE powerline? Single license for current software version"
6FC5251-0AA07-0AA0 Additional channel
6FC5252-0AX21-0AB0 Toolbox for SINUMERIK 810D/840D on CD-ROM
6FC5253-0BX10-0AF0 HMI-advanced on PCU hard disk
6FC5298-7AA20-3RP0 840D/840Di/810D 诊断说明
6FC5298-7AB00-3RP0 840D/840Di/810D 编程说明(基础部分)
6FC5303-0AF30-1AA0 MCP 802DSL, for use with option modul,for side mounting od PCU, inclusing ribbon cable
6FC5303-0DM13-1AA0 Keyboard, horizontal design, for mounting under the PCU(including connecting cables, length 1.5 meters
6FC5303-0DT12-1AA0 Keyboard, vertical design,for mounting on the side of PCU(including connecting cable, length 1.5 meters)
6FC5312-0DA01-0AA0 MCPA module for MCP 802Dsl connection and analog spindle with +/-10V interface
6FC5356-0BB12-0AE0 NCU 561.4
6FC5357-0BB12-0AE0 NCU 571.4
6FC5357-0BB15-0AE0 NCU 571.5
6FC5357-0BB22-0AE0 NCU 572,3
6FC5357-0BB23-0AE0 NCU 572.4
6FC5357-0BB24-0AE0 NCU 572.4
6FC5357-0BB34-0AE0 NCU 573.4
6FC5357-0BB35-0AE0 NCU 573.5
6FC5370-0AA00-2AA0 SINUMERIK 802D SL T/M plus(PCU 210.3 including firmware)
6FC5370-0AA00-3AA0 SINUMERIK 802D SL T/M pro(PCU 210.3 including firmware)
6FC5397-0CP10-0RA0 SINUMERIK 802D sl/SINAMICS Startup(instruction manual)
6FC5397-1CP10-0RA0 SINUMERIK 802D sl De
6FC5398-0CP10-0RA0 SINUMERIK 802D sl OP-Milling
6FC5398-1CP10-0RA0 SINUMERIK 802D sl OP-Turning
6FC5398-2CP10-0RA0 SINUMERIK 802D SL Diagnose instruction
6FC5410-0AY03-1AA0 SINUMERIK 810DE MODULE CCU3.4WITH SYSTEM SW (EXPORT)256 KBYTE NC MEMORY(MAX.EXTENSION 2.5 MBYTE)PLC
6FC5411-0AA00-0AA0 "Single I/O module EFP
64I/32O, isolated, Up to 3 single I/O modules"
6FC5411-0AA80-0AA0 Connecting cable L=150mm for single-tier configuration
6FC5412-0FA10-0AA0 Axis expansion plug-in unit for SINUMERIK 810D incl. ribbon cable
6FC5412-0FA12-0AA0 Axis expansion plug-in unit left, single-axis for SINUMERIK 810D incl. ribbon cable
6FC5447-0AA00-0AA1 CCU-box with 3 integrated power sections
6FC5447-0AA01-0AA0 CCU-box with 2 integrated power sections
6FC5500-0AA00-2AA0 802S Base Line package: Controller+Toolbox+Logbook+Quick Start + RS232 isolator + Transformer AC 380/AC 220 400W
6FC5500-0AA11-2AA0 802C Base Line package:Controller+Toolbox+Logbook+Quick Start + RS232 isolator+Transformer AC 380/AC 220 400W + Cable 802C BL - 611U L=7M 6FX2002-3AD01-1AH0
6FC5503-0AC00-0AA0 SINUMERIK 802S/C OP020
6FC5503-0AD00-0AA0 SINUMERIK 802S/C MCP
6FC5503-0AY03-0AA0 Override Switch,Feedrate
6FC5503-0AY04-0AA0 Override Switch, SPINDLE
6FC5503-0AY05-0AA0 SINUMERIK 802S COMPLETE EMERGENCY-OFF UNIT 1 NC + 1NO CONTACT
6FC5510-0BA00-0AA1 SINUMERIK 802S ECU
6FC5510-0CA01-0AA0
6FC5511-0CA00-0AA0 SINUMERIK 802S/C 802S/C-BL DI/O 16I/16O
6FC5511-0CB00-0AA0 802C BL EXT.I/O
6FC5548-0AA00-0AA0 STEPDRIVE C
6FC5548-0AA02-0AA0 STEPDRIVE C++ (for 18/25 Nm)
6FC5548-0AB03-0AA0 stepmotor - 3.5 Nm
6FC5548-0AB06-0AA0 stepmotor - 6 Nm
6FC5548-0AB08-0AA0 stepmotor - 9 Nm
6FC5548-0AB12-0AA0 stepmotor - 12 Nm
6FC5548-0AB18-0AA0 stepmotor - 18 Nm
6FC5548-0AB25-0AA0 stepmotor - 25 Nm
6FC5548-0AC21-0AA0 SIMODRIVE Baseline A 1-axis
6FC5548-0AC22-0AA0 SIMODRIVE Baseline A 2-axis
6FC5597-2AA00-0BP0 802S Installation guide ENGLSIH =6FC5597-2AA00-0BP1
6FC5597-2AA00-0BP1 802S Installation guide ENGLSIH
6FC5597-2AA10-0BP0 802S/C De
6FC5597-3AA00-0RP1 SINUMERIK 802S 安装调试 [中文]
6FC5597-3AA10-0BP1 SINUMERIK 802S/C De
6FC5597-3AA10-0RP2 SINUMERIK 802S/C 功能说明 [中文]
6FC5597-3AA20-0BP1 SINUMERIK 802C Insatllation guide ENGLISH
6FC5597-4AA01-3RP0 SINUMERIK 802S BL Start up and Installation中文
6FC5597-4AA11-3RP0 SINUMERIK 802S/C BL Function De
6FC5597-4AA21-3RP0 SINUMERIK 802C BL安装调试Start up and Installation中文
6FC5598-3AA00-0RP1 SINUMERIK 802S/C 操作编程[车床]中文
6FC5598-3AA10-0RP1 SINUMERIK 802S/C 操作编程[铣床]中文
6FC5598-3AA20-0RP0 SINUMERIK 802S/C 诊断说明中文
6FC5598-3AA30-0RP1 SINUMERIK 802S简明操作编程[中文]
6FC5598-4AA01-3RP0 SINUMERIK 802S/C BL Operating and Programming (T)中文
6FC5598-4AA11-3RP0 SINUMERIK 802S/C BL Operating and Programming (M)中文
6FC5598-4AA21-3RP0 SINUMERIK 802S/C BL诊断说明中文
6FC5600-0AB01-0AA0 SIN802D Baseline Basic Package incl. PCU, 1*Simodrive 611UE, 1*72 inputs / 48 outputs,1*Profibus unit for motion control,3*Profibus connector and toolbox
6FC5600-0AF01-0AA0 SIN802D Basic Package 1 incl. PCU, horizontal keyboard, 611 universal E, 72 inputs / 48 outputs,3 Profibus connector and toolbox
6FC5600-0AF02-0AA0 SIN802D Basic Package 3 incl. PCU, horizontal keyboard, 2′611 universal E, 72 inputs / 48 outputs,4 Profibus connector and toolbox
6FC5600-0AG01-0AA0 SIN802D Basic Package 1 incl. PCU, vertical keyboard, 611 universal E, 72 inputs / 48 outputs,3 Profibus connector and toolbox
6FC5600-0AG02-0AA0 SIN802D Basic Package 2 incl. PCU, vertical keyboard, 2′611 universal E, 72 inputs / 48 outputs,4 Profibus connector and toolbox
6FC5603-0AC12-1AA0 CNC Keyboard,vertical
6FC5603-0AC13-1AA0 CNC Keyboard,horizontal
6FC5603-0AD00-0AA1 SINUMERIK 802D Machine Control Panel (MCP), vertical format
6FC5603-0AD00-0AA2 SINUMERIK 802D Machine Control Panel (MCP), vertical format
6FC5610-0BA10-0AA1 SINUMERIK 802D CNC operator panel (PCU210.2)
6FC5611-0CA01-0AA0 Digital I/O module,72 inputs / 48 outputs
6FC5651-0AA01-0AA0 Tool Life monitoring software *) only used for SIN802D Package.
6FC5651-0AA02-0AA0 C-axis *) only used for SIN802D Package.
6FC5653-0AA01-0AA0 PLC Teleservice software
6FC5655-0AA01-0AA0 Fixed stop *) only used for SIN802D Package.
6FC5673-0AA01-0AF0 Color Display
6FC5697-2AA00-0BP3 SINUMERIK 802D Startup EDITION 11/03 (English)
6FC5697-2AA00-0RP2 SINUMERIK 802D Startup(中文)
6FC5697-2AA10-0BP2 SINUMERIK 802D/802D BL Fuction De
6FC5697-2AA10-0RP1 SINUMERIK 802D/802D BL De
6FC5698-2AA00-0BP0 SINUMERIK 802D OPERATING/PROGRAMMING EDITION 11/00 ENGLISH
6FC5698-2AA00-0BP1 SINUMERIK 802D OPERATING/PROGRAMMING TURNING EDITION 07/01 ENGLISH
6FC5698-2AA00-0RP1 SINUMERIK 802D 操作编程[车床]
6FC5698-2AA00-0RP2 SINUMERIK 802D OP-Turning(Chinese)
6FC5698-2AA00-0RP3 SINUMERIK 802D/802D BL OP-Turning[中文]
6FC5698-2AA10-0BP3 SINUMERIK 802D/802D BL OP-Milling(English)
6FC5698-2AA10-0RP2 SINUMERIK 802D OP-Milling(中文)
6FC5698-2AA10-0RP3 SINUMERIK 802D/802D BL OP-Milling中文]
6FC5698-2AA20-0BP1 SINUMERIK 802D Diagnose(English)
6FC5698-2AA20-0RP1 SINUMERIK 802D Diagnose(中文)
6FC8506-1RX01-0AA0 Repair service contract 0-4 measurement circuits with 1 year
6FC8506-2RX01-0AA0 Repair service contract 0-4 measurement circuits within 2 years
6FC9301-0AE20 SINUMERIK 800 OPERATING MODE SELETING, 16 SWITCHING LEVELS, ANTHRACITE, 296244 or 39867 16/15°
6FC9301-0BC20 SINUMERIK 800 FEED OVERRIDE ROTARY SWITCH 1X23G, T=32, COVER, BUTTON,ARROW DISK, SCALE DISK FEEDRATE, 23/11.25°
6FC9301-0CC20 SINUMERIK 800 RAPID TRAVERSE OVERRIDE SWITCH, 8 SWITCHING LEVELS, CHARCOAL,8/30°
6FC9301-0DC20 SINUMERIK 810M AXES SELECTOR SWITCH, 8 SWITCHING LEVELS, ANTHRACITE, 355545 8/30°
6FC9301-0DD20 SINUMERIK 850M AXES SELECTOR SWITCH, 16 SWITCHING LEVELS, ANTHRACITE, 16/15°
6FC9301-0EC20 SINUMERIK 800 SPINDLE OVERRIDE ROTARY SWITCH 1X16 G, T=24,COVER,BUTOON,ARROW DISK,SCALE DISK FEEDRATE, 16/15°
6FC9302-2AA Terminal strip converter, 34-pole, 0.5 A output ? Without LED status display
6FC9302-2AB Terminal strip converter, 34-pole, 0.5 A output ? Red LED status display
6FC9320-5DC00 Electronic handwheel, front plate 76.2 x 76.2 mm
6FC9320-5DC01 Electronic handwheel, front plate 76.2 x 76.2 mm+/A,/B
6FC9340-8LL F.I/O submodule to Termianl strip converter, RIBBON CABLE 34WAYS L=1M
6FC9340-8RB00 SINUMERIK 800 SIGNAL CABLE ANOLOG L=5M
6FC9340-8RC00 SINUMERIK 800 SIGNAL CABLE ANOLOG L=10M
6FC9340-8XY00-1AB0 Ribbon cable EFP-terminal strip conv. 1m
6FC9348-7HP00 SIMODRIVE (ACCESSORIES)SUB D CONNECTOR SBM HOUSING25-WAY FEMALE CONTACTSWITH SCREW TYPE LOCKING UNC4
6FC9348-7HX SUB D connector, SMB housing, 15-way female
6FX1121-2BA03 SINUMERIK 810/880 INTERFACE PCB, FROM GA3 JUMPER S1 UPWARD
6FX1121-2BB02 sinumerik 810 GA1 接口板
6FX1121-4BA02 SIROTEC/SINUMERIK SERVO INTERFACE, 20MM, 3AXES
6FX1121-4BA03 SIROTEC/SINUMERIK SERVO INTERFACE, 20MM, 3AXES
6FX1122-1AC02 SINUMERIK 3 PLC-NC
6FX1122-2AD02 SINUMERIK 3 NC TO PLC
6FX1124-6AD02 SINUMERIK SYSTEM 3, 880, IN-/OUTPUT MODULE 64 I/32 O
6FX1126-1AA03 SINUMERIK 800 VIDEO GRAPHIC, MONOCHROME
6FX1126-1AA04 SINUMERIK 800 VIDEO GRAPHIC, MONOCHROME
6FX1126-5AA01 SINUMERIK 800 Interface module for 3 handwheels
6FX1128-1BA00 SINUMERIK 800 BASIC MEMORY MODULE W/O RAM
6FX1130-0BA02 SINUMERIK 810, BASIC VERSION 2/3, COMPLETE KEYBOARD
6FX1132-8BB01 SINUMERIK 810/820, BASIC VERSION 2 CPU WITH COPROCESSOR(COP)
6FX1133-0BB01 SINUMERIK 810 CENTRAL BUS
6FX1138-5BB04 SINUMERIK 810/820, BASIC VERSION 3, 805SM, CPU, 16MHz, ACOP, FROM SW. VERSION 2.X
6FX1151-1BA01 SINUMERIK 800 VIDEO MODULE, WITH COLOR MEM
6FX1151-1BB01 SINUMERIK 800 VIDEO-GRAPHICS,MONOCHROME
6FX1154-8BB01 SINUMERIK 800 VIDEO INTERFACE TTL/VGA, W. COLOR MEMORY
6FX1402-2BB10 M50 HCMOS-BUS Round cable, 1m long
6FX1402-2BB50 M49 HCMOS-BUS Round cable, 5m long
6FX1410-0CX46 SINUMERIK 805/810/820 BATTERY PLUG-IN UNIT FOR 3 MIGNON
6FX2001-2AB02 TTL (RS 422) incremental encoder, Synchronous flange and 5 V DC supply voltage, Connection: Radial flange outlet, 1024 S/R
6FX2001-2AB50 TTL (RS 422) incremental encoder, Synchronous flange and 5 V DC supply voltage, Connection: Radial flange outlet, 1500 S/R
6FX2001-2CB02 TTL (RS 422) incremental encoder, Synchronous flange and 5 V DC supply voltage, Connection: Cable 1 m (3.28 ft) with connector, 1024 S/R
6FX2001-2CC50 TTL (RS 422) incremental encoder, Synchronous flange and 5 V DC supply voltage, Connection:Cable 1 m (3.28 ft) with connector, 2500 S/R
6FX2001-2CF00 TTL (RS 422) incremental encoder, Synchronous flange and 5 V DC supply voltage, Connection: Cable 1 m (3.28 ft) with connector, 5000 S/R
6FX2001-2EB02 TTL (RS 422) incremental encoder, Synchronous flange and 5 V DC supply voltage, Connection: Radial flange outlet, 1024 S/R
6FX2001-2GB02 TTL (RS 422) incremental encoder, Synchronous flange and 5 V DC supply voltage, Connection: Axial flange outlet, 1024 S/R
6FX2001-3CB02 sin/cos 1 Vpp incremental encoder, Synchronous flange and 5 V DC supply voltage, Connection: Cable 1 m (3.28 ft) with connector, 1024 S/R
6FX2001-3CC50 sin/cos 1 Vpp incremental encoder, Synchronous flange and 5 V DC supply voltage, Connection: Cable 1 m (3.28 ft) with connector, 2500 S/R
6FX2001-3EB02 sin/cos 1 Vpp incremental encoder, Synchronous flange and 5 V DC supply voltage, Connection: Radial flange outlet, 1024 S/R
6FX2001-3EC50
6FX2001-5FE13 EnDat absolute encoder, Synchronous flange and 5 V DC supply voltage Connection: ? Radial flange outlet, Resolution: Single-turn 8192 steps/revolution(13-bit)
6FX2001-7KF10 spring disk coupling
6FX2001-7KP01 clamp
6FX2001-7KS06 spring disk coupling
6FX2002-1AA01-1AD0 V24-RS232 CABLE 9Pins[SOCKET]-9Pins[SOCKET]
6FX2002-1DC00-1AF0 Drive CLiQ cable from 802D sl PCU to SINAMICS line module(5M)
6FX2002-1DC00-1BA0 Drive CLiQ cable from 802D sl PCU to SINAMICS line module(10M)
6FX2002-1DC00-1BF0 Drive CLiQ cable from 802D sl PCU to SINAMICS line module(15M)
6FX2002-2CE02-1BA0 Signal cable built-in ROD320 L=10M
6FX2002-3AB01-1AF0
6FX2002-3AD01-1AH0 Cable 802C BL - 611U(7M)
6FX2002-3AD01-1BA0 Cable 802C BL - SIMODIRVE L=10M
6FX2002-4EA01-1AF0 MPI bus cable with three connectors CNC-MMC-MSTT(l2=5m;l1=1m)
6FX2002-4EA04-1AF0 MPI bus cable with three connectors CNC-MMC-MSTT(l2=1m;l1=5m)
6FX2002-4EA80-1BA0 Pre-assembled MPI bus cable
6FX2002-5AA12-1BF0 POWER CABLE 1FT5, CONNECTOR SIZE 2, 4X4 SQMM, L=15M
6FX2003-0AA02 Profibus connector
6FX2003-0CA10 power cable connector
6FX2003-0CB10 power cable connector
6FX2003-0CB20 power cable connector
6FX2003-0CE12 connector type 12-way
6FX2003-0DA00 Terminator for drive bus
6FX2003-0DS00 RS232 ISOLATOR
6FX2003-0LU00 POWER CONNECTOR SIZE 16-WAY SOCKET, union NUT1 6-POLE INSULATOR 8 SOCKET CONTACTS (1-2.5 MM2)2 CABLE
6FX2003-0LU10 POWER CONNECTOR 6-POL SIZE 1.5SOCKET, union NUT1 6-POLE INSULATOR 5 SOCKET CONTACTS (1.5-4MM2)5 SOCK
6FX2003-0SU01 SIGNAL CONNECTOR, 9-PINunion NUT1 INSULATOR WITH SOCKET CONT.1 INSULATOR WITH PIN CONT.SOLDER VERSIO
6FX2003-0SU12
6FX2003-7DX00 Mounting flange for signal conn.(can be used for conn. With union cap and for conn. With external thread also)
6FX2003-7FX00 HF clamp for signal connector and power connector and power connector size1
6FX2006-1BA02 Cable distributor
6FX2006-1BC01 DISTRIBUTOR for hand-held unit with iicl. Shorting plug 3-wire connection
6FX2006-1BG00 Connecting kit
6FX2006-1HA0 Holder made of polystyrence
6FX2007-1AC03 "B-MPI handheld unit 3-step enabling button
including connecting cable with connector
3-wire enabling
- coiled connecting cable length: 3.5 m (11 ft 6 in)"
6FX2007-1AC04 "B-MPI handheld unit 3-step enabling button including connecting cable with connector 3-wire enabling - coiled connecting cable length: 3.5 m (11 ft 6 in)"
6FX2007-1AC13 "B-MPI handheld unit 3-step enabling button including connecting cable with connector 3-wire enabling - straight connecting cable length: 10 m (32 ft 10 in)"
6FX2007-1AC14 "B-MPI handheld unit 3-step enabling button including connecting cable with connector 3-wire enabling - straight connecting cable length: 10 m (32 ft 10 in)"
6FX2007-1AD01 "Mini handheld unit 3-step enabling button incl. 2 magnets for attachment and connecting cable with connector ? Coiled connecting cable Length: 1.5 m (4 ft 11 in), stretches to 3.5 m (11 ft 6 in)"
6FX2007-1AD11 "Mini handheld unit 3-step enabling button incl. 2 magnets for attachment and connecting cable with connector ? Straight connecting cable Length: 5 m (16 ft 5 in)"
6FX2007-1AE04 "B-MPI handheld unit 3-step enabling button
4-wire enabling
6FX2007-1AE14 "B-MPI handheld unit 3-step enabling button
4-wire enabling
6FX4002-2CA51-1BF0 SIGNAL CABLE 611A---1PH6 ENCODER/SIMAG H, 3X2X0.14+4X0.14+2X0.5C L=15M
6FX4002-2CB31-1BA0 SIGNAL CABLE, 611A TO 1FT5 TG/SHAFT POSITION ENCODER, 12X0.23C, L=10M
6FX4002-2CB42-1BA0 SIGNAL CABLE, 810/820 TO BUILT-IN ENCODER ROD320, 4X2X0.38+4X0.5C, L=10M
6FX4002-2CB42-1BF0 SIGNAL CABLE, 810/820 TO BUILT-IN ENCODER ROD320, 4X2X0.38+4X0.5C, L=15M
6FX4002-5CA12-1BJ0 POWER CABLE, PREASSEMBLED, EXT., 4X4 C, CONNECTOR SIZE 2 [1FT/1FK TO 611/810D/SIMODRIVE] L=18M
6FX4002-5DA01-1BA0 POWER CABLE, 4X1.5C,CONN. SIZE 1, L=10M
6FX4002-5DA02-1BF0 POWER CABLE L=15M
6FX5002-2AD00-1BA0 SIGNAL CABLE, (611D/MCU TO ENDAT ENCODER) 3X2X0.14+4X2X0.5C L=10M
6FX5002-2CA11-1AF0 encoder cable,5M
6FX5002-2CA11-1AG0 encoder cable,6M
6FX5002-2CA11-1BA0 encoder cable,10M
6FX5002-2CA11-1BF0 encoder cable,15M
6FX5002-2CA11-1CA0 encoder cable,20M
6FX5002-2CA11-1CF0 encoder cable,25M
6FX5002-2CA31-1AF0 Signal cable,5M
6FX5002-2CB51-1BF0 SIGNAL CABLE (BUILT-ON ENCODER 5V 6FX2001-2) 4X2X0.34+4X0.5C L=15M
6FX5002-2CD01-1AF0 Signal cable, SMC30 --- external encoder(TTL), 5M
6FX5002-2CD01-1BA0 Signal cable, SMC30 --- external encoder(TTL), 10M
6FX5002-2CD01-1BF0 Signal cable, SMC30 --- external encoder(TTL), 15M
6FX5002-2CD01-1CA0 Signal cable, SMC30 --- external encoder(TTL), 20M
6FX5002-2CD01-1CF0 Signal cable, SMC30 --- external encoder(TTL), 25M
6FX5002-2CG00-1AF0 Incremental(sin/cos 1Vpp) encoder cable,5M, IP20/IP67
6FX5002-2CG00-1BA0 Incremental(sin/cos 1Vpp) encoder cable,10M, IP20/IP67
6FX5002-2CG00-1BF0 Incremental(sin/cos 1Vpp) encoder cable,15M, IP20/IP67
6FX5002-2CG00-1CA0 Incremental (sin/cos 1Vpp)encoder cable,20M, IP20/IP67
6FX5002-2CG00-1CF0 Incremental(sin/cos 1Vpp) encoder cable,25M, IP20/IP67
6FX5002-2CJ00-1AH0 Signal cable,SIMODRIVE Baseline-802C BL(7M)
6FX5002-2DC10-1AF0 DRIVE CLiQ Signal cable for Motor encoder --- Motor module,5M, IP20/IP67, with 24VDC
6FX5002-2DC10-1BA0 DRIVE CLiQSignal cable for Motor encoder --- Motor module,10M,IP20/IP67, with 24VDC
6FX5002-2DC10-1BF0 DRIVE CLiQSignal cable for Motor encoder --- Motor module,15M,IP20/IP67, with 24VDC
6FX5002-2EQ10-1BA0 SIGNAL CABLE, (ABSOLUTE ENCODER IN MOTOR) 3X2X0.14+4X0.14+2X0.5+4X0.22C L=10M
6FX5002-2EQ10-1BJ0 signal cable, (ABSOLUTE ENCODER IN MOTOR) 3X2X0.14+4X0.14+2X0.5+4X0.22 C, L=18M
6FX5002-5CA01-1AF0 power cable for 3,2-16 Nm motor,5M
6FX5002-5CA01-1BJ0 power cable for 3,2-16 Nm motor,18M
6FX5002-5CA11-1AF0 power cable for 18 Nm motor,5M
6FX5002-5CA11-1BA0 power cable for 18 Nm motor,10M
6FX5002-5CA11-1BF0 power cable for 18 Nm motor,15M
6FX5002-5CA11-1CA0 power cable for 18 Nm motor,20M
6FX5002-5CA21-1BA0 POWER CABLE 4X1.5C, CONN. SIZE 1.5 L=10M
6FX5002-5CA31-1AF0 power cable for 27 Nm motor,5M
6FX5002-5CA31-1BA0 power cable for 27 Nm motor,10M
6FX5002-5CA31-1BF0 power cable for 27 Nm motor,15M
6FX5002-5CA41-1AF0 power cable for 27 Nm motor,5M
6FX5002-5CA41-1BA0 power cable for 27 Nm motor,10M
6FX5002-5CA41-1BC0 power cable for 27 Nm motor,12M
6FX5002-5CA41-1BF0 power cable for 27 Nm motor,15M
6FX5002-5CA41-1CA0 power cable for 27 Nm motor,20M
6FX5002-5CA51-1AF0 power cable for 36 Nm motor,5M
6FX5002-5CA51-1BA0 power cable for 36 Nm motor,10M
6FX5002-5CA51-1BF0 power cable for 36 Nm motor,15M
6FX5002-5CS01-1AF0 Power cable below 18NM,5M
6FX5002-5CS01-1BA0 Power cable below 18NM,10M
6FX5002-5CS01-1BF0 Power cable below 18NM,15M
6FX5002-5CS02-1AF0 Power cable for 1FT/1FK/1PH spindle motor,5M, open connection in motor side, 4x1.5 sqr.mm, used for 1PH7101
6FX5002-5CS02-1BA0 Power cable for 1FT/1FK/1PH spindle motor,10M, open connection in motor side, 4x1.5 sqr.mm,used for 1PH7101
6FX5002-5CS02-1BF0 Power cable for 1FT/1FK/1PH spindle motor,15M, open connection in motor side, 4x1.5 sqr.mm,used for 1PH7101
6FX5002-5CS12-1AF0 Power cable for 1FT/1FK/1PH spindle motor,5M, open connection in motor side, 4x2.5 sqr.mm, used for 1PH7103
6FX5002-5CS12-1BA0 Power cable for 1FT/1FK/1PH spindle motor,10M, open connection in motor side, 4x2.5 sqr.mm,used for 1PH7103
6FX5002-5CS12-1BF0 Power cable for 1FT/1FK/1PH spindle motor,15M, open connection in motor side, 4x2.5 sqr.mm,used for 1PH7103
6FX5002-5CS31-1AF0 Power cable for 27NM,5M
6FX5002-5CS31-1BA0 Power cable for 27NM,10M
6FX5002-5CS31-1BF0 Power cable for 27NM,15M
6FX5002-5CS41-1AF0 Power cable for 36NM,5M
6FX5002-5CS41-1BA0 Power cable for 36NM,10M
6FX5002-5CS41-1BF0 Power cable for 36NM,15M
6FX5002-5CS42-1AF0 Power cable for 1FT/1FK/1PH spindle motor,5M, open connection in motor side, 4x4 sqr.mm, used for 1PH7107
6FX5002-5CS42-1BA0 Power cable for 1FT/1FK/1PH spindle motor,10M, open connection in motor side, 4x4 sqr.mm,used for 1PH7107
6FX5002-5CS42-1BF0 Power cable for 1FT/1FK/1PH spindle motor,15M, open connection in motor side, 4x4 sqr.mm,used for 1PH7107
6FX5002-5CS51-1AF0 Power cable for 45NM,5M
6FX5002-5CS51-1BA0 Power cable for 45NM,10M
6FX5002-5CS51-1BF0 Power cable for 45NM,15M
6FX5002-5CS52-1AF0 Power cable for 1FT/1FK/1PH spindle motor,5M, open connection in motor side, 4x6 sqr.mm, used for 1PH7133-xxD02
6FX5002-5CS52-1BA0 Power cable for 1FT/1FK/1PH spindle motor,10M, open connection in motor side, 4x6 sqr.mm, used for 1PH7133-xxD02
6FX5002-5CS52-1BF0 Power cable for 1FT/1FK/1PH spindle motor,15M, open connection in motor side, 4x6 sqr.mm, used for 1PH7133-xxD02
6FX5002-5DA01-1AF0 power cable for 3.2-16NM,5M
6FX5002-5DA11-1AF0 power cable for 18 Nm motor,5M,brake
6FX5002-5DA11-1BA0 power cable for 18 Nm motor,10M,brake
6FX5002-5DA11-1BF0 power cable for 18 Nm motor,15M,brake
6FX5002-5DA11-1CA0 power cable for 18 Nm motor,20M,brake
6FX5002-5DA31-1AF0 power cable for 27 Nm motor,5M,brake
6FX5002-5DA31-1BA0 power cable for 27 Nm motor,10M,brake
6FX5002-5DA31-1BF0 power cable for 27 Nm motor,15M,brake
6FX5002-5DA41-1AF0 power cable for 27 Nm motor,5M,brake
6FX5002-5DA41-1BA0 power cable for 27 Nm motor,10M,brake
6FX5002-5DA41-1BC0 power cable for 27 Nm motor,12M,brake
6FX5002-5DA41-1BF0 power cable for 27 Nm motor,15M,brake
6FX5002-5DA41-1CA0 power cable for 27 Nm motor,20M,brake
6FX5002-5DA51-1AF0 power cable for 36 Nm motor,5M,brake
6FX5002-5DA51-1BA0 power cable for 36 Nm motor,10M,brake
6FX5002-5DA51-1BF0 power cable for 36 Nm motor,15M,brake
6FX5002-5DS01-1AF0 Power cable below 18NM,5M,With brake
6FX5002-5DS01-1BA0 Power cable below 18NM,10M,With brake
6FX5002-5DS01-1BF0 Power cable below 18NM,15M,With brake
6FX5002-5DS31-1AF0 Power cable for 27NM,5M,with brake
6FX5002-5DS31-1BA0 Power cable for 27NM,10M,with brake
6FX5002-5DS31-1BF0 Power cable for 27NM,15M,with brake
6FX5002-5DS41-1AF0 Power cable for 36NM,5M,with brake
6FX5002-5DS41-1BA0 Power cable for 36NM,10M,with brake
6FX5002-5DS41-1BF0 Power cable for 36NM,15M,with brake
6FX5002-5DS51-1AF0 Power cable for 45NM,5M,with brake
6FX5002-5DS51-1BA0 Power cable for 45NM,10M,with brake
6FX5002-5DS51-1BF0 Power cable for 45NM,15M,with brake
6FX5008-1BA11-1FA0 POWER CABLE, 4X1.5 +2X1.5C L=50M
6FX5008-1BB51-1AF0 Power cable for 1FT/1FK/1PH spindle motor,5M, open connection in motor side, 4x10 sqr.mm, used for 1PH7133-xxG02/1PH7137xxD02
6FX5008-1BB51-1BA0 Power cable for 1FT/1FK/1PH spindle motor,10M, open connection in motor side, 4x10 sqr.mm, used for 1PH7133-xxG02/1PH7137xxD02
6FX5008-1BB51-1BF0 Power cable for 1FT/1FK/1PH spindle motor,15M, open connection in motor side, 4x10 sqr.mm, used for 1PH7133-xxG02/1PH7137xxD02
6FX5008-1BB61-1AF0 Power cable for 1FT/1FK/1PH spindle motor,5M, open connection in motor side, 4x16 sqr.mm, used for 1PH7137-xxG02/1PH7163xxD03
6FX5008-1BB61-1BA0 Power cable for 1FT/1FK/1PH spindle motor,10M, open connection in motor side, 4x16 sqr.mm, used for 1PH7137-xxG02/1PH7163xxD03
6FX5008-1BB61-1BF0 Power cable for 1FT/1FK/1PH spindle motor,15M, open connection in motor side, 4x16 sqr.mm, used for 1PH7137-xxG02/1PH7163xxD04
6FX5008-1BD21-2AA0 SIGNAL CABLE, 4X2X0.34+4X0.5C L=100M
6FX5008-1BD51-2AA0 SIGNAL CABLE, 3X2X0.14+4X0.14+2X0.5+4X0.22C C L=100M
6FX6002-2CA31-1AB0 signal cable,1M
6FX6002-2CA31-1AD0 signal cable,3M
6FX6002-2CA31-1AE0 signal cable,4M
6FX6002-2CA31-1AF0 signal cable,5M
6FX6002-2CA31-1AG0 signal cable,6M
6FX6002-2CA31-1AH0 signal cable,7M
6FX6002-2CA31-1AJ0 signal cable,9M
6FX6002-2CA31-1BA0 signal cable,10M
6FX6002-2CA31-1BC0 signal cable,12M
6FX6002-2CA31-1BF0 signal cable,15M
6FX6002-2CA31-1CA0 signal cable,20M
6FX6002-2CF02-1AF0 signal cable,5M 611U-Motor
6FX6002-2CF02-1BA0 signal cable,10M 611U-Motor
6FX6002-2CF02-1BF0 signal cable,15M 611U-Motor
6FX6002-2CJ10-1AH0 Signal cable,611U-802C BL(7M)
6FX6002-3AD02-1AH0 Cable 802S Base Line -STEPDRIVE C (7m)]
6FX6002-3BA31-1AD0 Cable 802S, BETW. ENC and CONVERTER L=3M
6FX6002-5AA51-1AB0 SINUMERIK 802S CABLE BETW. STEPDRIVE AND STEPPER MOTOR L= 1 m
6FX6002-5AA51-1AD0 SINUMERIK 802S CABLE BETW. STEPDRIVE AND STEPPER MOTOR L= 3 m
6FX6002-5AA51-1AF0 SINUMERIK 802S CABLE BETW. STEPDRIVE AND STEPPER MOTOR L= 5 m
6FX6002-5AA51-1AH0 SINUMERIK 802S CABLE BETW. STEPDRIVE AND STEPPER MOTOR L= 7 m
6FX6002-5AA51-1BA0 SINUMERIK 802S CABLE BETW. STEPDRIVE AND STEPPER MOTOR L= 10 m
6FX6002-5AA51-1BF0 SINUMERIK 802S CABLE BETW. STEPDRIVE AND STEPPER MOTOR L= 15 m
6FX6002-5CA01-1AF0 power cable for 3,2-18 Nm motor,5M
6FX6002-5CA01-1AG0 power cable for 3,2-16 Nm motor,6M
6FX6002-5CA01-1AH0 power cable for 3,2-16 Nm motor,7M
6FX6002-5CA01-1AJ0 power cable for 3,2-16 Nm motor,8M
6FX6002-5CA01-1BA0 power cable for 3,2-18 Nm motor,10M
6FX6002-5CA01-1BC0 power cable for 3,2-16 Nm motor,12M
6FX6002-5CA01-1BF0 power cable for 3,2-18 Nm motor,15M
6FX6002-5CA01-1CA0 power cable for 3,2-16 Nm motor,20M
6FX6002-5DA01-1AD0 power cable for 3,2-16 Nm motor,3M
6FX6002-5DA01-1AE0 power cable for 3,2-16 Nm motor,4M
6FX6002-5DA01-1AF0 power cable for 3,2-16 Nm motor,5M,brake
6FX6002-5DA01-1AH0 power cable for 3,2-16 Nm motor,7M,brake
6FX6002-5DA01-1BA0 power cable for 3,2-16 Nm motor,10M,brake
6FX6002-5DA01-1BF0 power cable for 3,2-18 Nm motor,15M,brake
6FX8002-2BA00-1BA0 SIGNAL CABLE, 4X2X0.34+4X0.5C 611 TO CONTROL VALVE L=10M
6FX8002-2BA02-1AF0 command cable for HLA/ANA L=5m
6FX8002-2CA11-1AF0 SIGNAL CABLE,(SIMODRIVE TO SINUS ENC. 1Vpp) 4X2X0.34+4X0.5 C, L=5M
6FX8002-2CD01-1AF0 SIGNAL CABLE, (INCR. ENCODER TTL 6FX2001-2) 4X2X0.34+4X0.5 C, L=5M
6FX8002-4AA21-1AF0 Pre-assembled cable for Handwheel L=5M
6FX8002-4AA21-1BA0 Pre-assembled cable for Handwheel L=10M
6FX8008-1BD61-1FA0 handwheel cable (50M)
6GK1551-2AA00 SIMATIC NET CP5512 PG-Profibus or MPI
6MM-6MM SPRING DISK COUPLING
6SC6100-0AB00 SIMODRIVE 610 G20 DC-
6SC6100-0GC14 SIMODRIVE 650 POWER SUPPLY FOR 6SC6502/03-4AA01/02
6SC6100-0NA11 SIMODRIVE 610 AC FEED DRIVE, CLOSED-LOOP CONTROL 2-AXES, N12
6SE3214-0DA40 MICROMASTER VECTOR MMV150/3, 3AC 380-500+/-10%, 1.5KW
6SE6400-0BP00-0AA0 MICROMASTER 4 BASIC OPERATOR PANEL [BOP]
6SL3000-0CE15-0AA0 SINAMICS SMART Line reactor for 5KW
6SL3000-0CE21-0AA0 SINAMICS SMART Line reactor for 10KW
6SL3055-0AA00-5BA1 SMC20 Sensor Module for external incremental encoder:SIN/COS 1Vpp absolute encoder: ENDAT without DRIVE-CLIQ cable
6SL3055-0AA00-5CA0 SMC30 Sensor Module for external encoder(without DRIVE-CLiQ cable)
6SL3060-4AD00-0AA0 Drive CLiQ cable(0.16m), IP20/20
6SL3060-4AF00-0AA0 Drive CLiQ cable(0.21m), IP20/20
6SL3060-4AH00-0AA0 Drive CLiQ cable(0.26m), IP20/20
6SL3060-4AU00-0AA0 Drive CLiQ cable(0.6m), IP20/20
6SL3100-1AE31-0AA0 SINAMIC Braking Module,1.5KW
6SL3100-1BE22-5AA0 "SINAMICS pulsed resistor plus,600V,15.6OHM
control power module for voltage monitoring "
6SL3100-1BE31-0AA0 SINAMIC Braking resistor,1.5KW/100KW
6SL3100-1CE14-0AA0 SINAMIC SCAPACITOR MODULEINPUT: 600 V DC4000 UF
6SL3120-1TE13-0AA0 SINAMIC Single Motor Moudule, 3A/1.6Kw,internal cooling
6SL3120-1TE15-0AA0 SINAMIC Single Motor Moudule, 5A/2.7Kw,internal cooling
6SL3120-1TE21-0AA1 SINAMIC Single Motor Moudule, 9A/4.8Kw,internal cooling
6SL3120-1TE21-8AA1 SINAMIC Single Motor Moudule, 18A/9.7Kw,internal cooling
6SL3120-1TE23-0AA1 SINAMIC Single Motor Moudule, 30A/16Kw, internal cooling
6SL3120-2TE13-0AA0 SINAMIC Double Motor Moudle,2*3A/1.6Kw,internal cooling
6SL3120-2TE15-0AA0 SINAMIC Double Motor Moudle,2*5A/2.7Kw,internal cooling
6SL3120-2TE21-0AA0 SINAMIC Double Motor Moudle,2*9A/4.8Kw,internal cooling
6SL3120-2TE21-8AA0 SINAMIC Double Motor Moudle,2*18A/9.7Kw, internal cooling
6SL3121-1TE13-0AA0 SINAMIC Single Motor Moudule, 3A/1.6Kw,external cooling
6SL3121-1TE15-0AA0 SINAMIC Single Motor Moudule, 5A/2.7Kw,external cooling
6SL3121-1TE21-0AA0 SINAMIC Single Motor Moudule, 9A/4.8Kw,external cooling
6SL3121-1TE21-8AA0 SINAMIC Single Motor Moudule, 18A/9.7Kw,external cooling
6SL3121-1TE23-0AA0 SINAMIC Single Motor Moudule, 30A/16Kw,external cooling
6SL3121-2TE13-0AA0 SINAMIC Double Motor Moudle,2*3A/1.6Kw,external cooling
6SL3121-2TE15-0AA0 SINAMIC Double Motor Moudle,2*5A/2.7Kw,external cooling
6SL3121-2TE21-0AA0 SINAMIC Double Motor Moudle,2*9A/4.8Kw,external cooling
6SL3121-2TE21-8AA0 SINAMIC Double Motor Moudle,2*18A/ 7Kw,external cooling
6SL3130-6AE15-0AA0 SINAMICS SMART Line module, 5KW,internal cooling
6SL3130-6AE21-0AA0 SINAMICS SMART Line module, 10KW,internal cooling
6SL3130-7TE21-6AA1 SINAMICS ACTIVE Line module, 16KW,internal cooling
6SL3130-7TE23-6AA1 SINAMICS ACTIVE Line module, 36KW,internal cooling
6SL3131-6AE15-0AA0 SINAMICS SMART Line module, 5KW,external cooling
6SL3131-6AE21-0AA0 SINAMICS SMART Line module, 10KW,external cooling
6SL3131-7TE21-6AA0 SINAMICS ACTIVE Line module, 16KW,external cooling
6SL3131-7TE23-6AA0 SINAMICS ACTIVE Line module, 36KW,external cooling
6SL3162-1AF00-0AA0 SINAMICSSHIELD CONNECTION PLATEFOR 150 MMLINE/MOTOR MODULES
6SL3162-1AH00-0AA0 SINAMICSSHIELD CONNECTION PLATEFOR 300 MMLINE/MOTOR MODULES
6SL3162-1AH01-0AA0 SINAMICSSHIELD CONNECTION PLATEFOR 200 MMLINE/MOTOR MODULES
6SL3162-2AA00-0AA0 SINAMICS24 V TERMINAL ADAPTERFOR MODULES IN BOOKSIZE DESIGN
6SL3162-2BD00-0AA0 SINAMICSDC
6SL3162-2BM00-0AA0 SINAMICSDC
6SL3162-2BM01-0AA0 SINAMICSDC
6SL3166-3AB00-0AA0 SINAMICSWARNING LABELSFOR SINAMICS MODULEIN BOOKSIZE DESIGN1 SHEET, 12 LANGUAGES
6SN1060-0AA01-0BP0 611A 规划指南
6SN1111-0AA00-0BA1 HF commutation reactor,for 16kW infeed / regenerative unit
6SN1111-0AA00-0CA1 HF commutation reactor,for 36kW infeed / regenerative unit
6SN1111-0AA01-1AA0 Main filter for 10KW
6SN1111-0AB00-0AA0 Overvoltage limiter module for line infeed modules of 10 kW and over for SIMODRIVE 611
6SN1111-1AA00-0CA0 HF commutation reactor,for 28kW infeed unit
6SN1112-1AC01-0AA1 Monitoring module for SIMODRIVE 611 complete with all connection and coupling elements for internal and external heat dissipation
6SN1113-1AA00-0DA0 pulsd resistor for 28kW infeed unit
6SN1113-1AB01-0BA1 Pulsed resistor module
6SN1114-0AA01-0AA0 SIMODRIVE 611A SETTING MODULE FOR FEED MODULE ENHANCED INTERFACE
6SN1114-0NB01-0AA0 Motion control with PROFIBUS DP V2
6SN1114-0NB01-0AA1 Motion control with PROFIBUS DP V2
6SN1115-0AA12-0AA0 Signal amplifier electronics SAE
6SN1115-0BA11-0AA1 "Control unit with digital setpoint interface
for hydraulic linear drives HLA/ANA"
6SN1118-0AA11-0AA1 SIMODRIVE 611-A, closed-loop plug-in unit, 1-AXIS, for feed drives with 1FT5, enhanced interface
6SN1118-0AD11-0AA1 SIMODRIVE 611-A, closed-loop plug-in unit, 1-AXIS, for feed drives with 1FT5, standard interface
6SN1118-0AE11-0AA0
6SN1118-0AE11-0AA1 SIMODRIVE 611-A, closed-loop plug-in unit, 2-AXES, for feed drives with 1FT5, standard interface
6SN1118-0DG22-0AA1 SIMODRIVE 611D
6SN1118-0DG23-0AA0 "High performance Closed-loop control in Single-axis version
with direct measuring system"
6SN1118-0DH23-0AA0 "High performance Closed-loop control in two-axis version
6SN1118-0DJ21-0AA1 "High Performance closed-loop control
in single-axis version
without direct measuring system"
6SN1118-0DJ23-0AA0 "High Performance closed-loop control
6SN1118-0DJ23-0AA1 "High Performance closed-loop control
6SN1118-0DK21-0AA1 "High performance Closed-loop control
in two-axis version"
6SN1118-0DK23-0AA0 "High performance Closed-loop control
in two-axis version
Direct measuring system Incremental encoder sin/cos 1 Vpp or absolute encoder with EnDat 1)"
6SN1118-0DK23-0AA1 "High performance Closed-loop control
in two-axis version
6SN1118-0DM31-0AA0 High Standard Closed-loop control in two-axis version
6SN1118-0DM33-0AA0 "High Standard Closed-loop control in two-axis version
6SN1118-0DM33-0AA1 "High Standard Closed-loop control in two-axis version
6SN1118-0HK01-0AA0 611 universal HRS Two-axis version / RESOLVER / speed/torque setpoint
6SN1118-0NH01-0AA0 "611 universal HRS
Two-axis version / Incremental encoder / sin/cos 1 Vpp /
absolute encoder, velocity / speed/torque setpoint"
6SN1118-0NH01-0AA1 "611 universal HRS Two-axis version / Incremental encoder / sin/cos 1 Vpp /
6SN1118-0NH10-0AA2 611 universal E (without Profibus DP) upto mid 2002
6SN1118-0NH11-0AA0 611 universal E (without Profibus DP) from mid 2002
6SN1118-0NH11-0AA1 611 universal E (without Profibus DP)
6SN1118-0NJ01-0AA1 "611 universal, single axes,
Resolver, speed/torque setpoint"
6SN1118-0NK01-0AA0
6SN1118-0NK01-0AA1 611 universal,double axes
6SN1118-1NH01-0AA1 611 universal HRS, two-axis version, Incremental encoder sin/cos 1 Vpp / absolute encoder, velocity/speed/torque setpoint, positioning
6SN1118-1NJ01-0AA1 "611 universal, single axes,
Resolver, speed/torque setpoint, positining"
6SN1118-1NK01-0AA1 611 universal HRS, two-axis version resolver, speed/torque setpoint, positioning
6SN1121-0BA11-0AA1 Close-loop plug-in unit, for main spindle drives with 1PH7, universal version
6SN1122-0BA11-0AA1 Close-loop plug-in unit, for inductive motor
6SN1123-1AA00-0AA1 power module,5/10A
6SN1123-1AA00-0BA1 power module,9/18A
6SN1123-1AA00-0CA1 power module,18/36A
6SN1123-1AA00-0DA1 power module,28/56A
6SN1123-1AA00-0EA1 power module,56/112A
6SN1123-1AA00-0HA1 power module,3/6A
6SN1123-1AA00-0JA1 power module,100/100A
6SN1123-1AA00-0KA1 power module,140/210A
6SN1123-1AA00-0LA1 power module,42/64A
6SN1123-1AA00-0LA2 power module,42/64A
6SN1123-1AA01-0FA1 power module,70/140A
6SN1123-1AB00-0AA1 power module,double axes ,5/10A
6SN1123-1AB00-0BA1 power module,double axes ,9/18A
6SN1123-1AB00-0CA1 power module,double axes ,18/36A
6SN1123-1AB00-0CA2 power module,double axes ,18/36A
6SN1123-1AB00-0HA1 power module,double axes ,3/6A
6SN1145-1AA00-0CA0 infeed unit 28KW
6SN1145-1AA01-0AA1 infeed unit 10KW
6SN1145-1BA01-0BA1 infeed / regenerative unit 16KW
6SN1145-1BA01-0DA1 infeed / regenerative unit 55KW
6SN1145-1BA02-0CA1 infeed / regenerative unit 36KW
6SN1145-1BB00-0EA1 infeed / regenerative unit 80KW
6SN1145-1BB00-0FA1 infeed / regenerative unit 120KW
6SN1146-1AB00-0BA1 infeed unit 5KW
6SN1161-1CA00-0AA0 Drive bus cable Ribbon cable width=50MM
6SN1161-1CA00-0BA0 Drive bus cable Ribbon cable width=100MM
6SN1161-1CA00-0CA0 Drive bus cable Ribbon cable width=150MM
6SN1161-1CA00-0DA0 Drive bus cable Ribbon cable width=300MM
6SN1161-1CA00-0FA0 Drive bus cable Ribbon cable width=200MM
6SN1162-0BA01-0AA0 Thermally conductive plate Width: 100 mm (3.94 in)
6SN1162-0BA02-0AA2 Built-on fan Radial fan with IP44 degree of protection for internal and external heat dissipation Supply voltage: 3-phase AC 360 ... 510 V/45 ... 65 Hz Supply current: 0.2 ... 0.3 A
6SN1162-0BA03-0AA1 Hose cooling packages Package 1 for single module comprising
6SN1162-0BA03-0CA1 "Hose cooling packages Package 2 for 2-tier configuration of I/RF 55 kW and 85 A power section comprising:
4 x module connection flange 2000 mm (6.56 ft) hose
1 x cabinet connection flange
1 x radial fan as for Package 1"
6SN1162-0BA04-0JA0 Blanking cover for fixing the module and for closing the prepared cut-out in drive versions with external heat dissipation Width: 50 mm (1.97 in)
6SN1162-0EA00-0AA0 Shielded terminal plates 50mm
6SN1162-0EA00-0BA0 Shielded terminal plates 100mm
6SN1162-0EA00-0CA0 Shielded terminal plates 150mm
6SN1162-0EA00-0DA0 Shielded terminal plates 300mm
6SN1162-0EA00-0JA0 Shielded terminal plates 200mm
6SN1162-0EB00-0BA0 SHIELD CONNEC. PLATE FOR EXTERNAL COOLING, MODULE WIDTH 100 MM
6SN1162-0FA00-0AA1 Shielded contacting clip
6SN1162-1AA00-0AA0 Univeral empty casing width: 50mm
6SN1197-0AB21-0RP1 SIMODRIVE base line A, Start-Up manual: Chinese version
6XV1830-0EH10 Profibus cable, 1M
6XV1830-3EH10 Profibus cable, 1M, Trailing possible
6ZB5410-0BB01 810T GA3操作编程
6ZB5410-0BB01-0BA1[M] 810M GA3操作编程
6ZB5410-0DC02-0AA4 810/820 GA3 安装表
6ZB5410-0DH02-0AA2 810/820 GA3 接口说明-part 1
6ZB5410-0DL02-0AA2 810/820 GA3 安装说明
6ZB5410-0DV02 810/820 GA3 接口说明-part 2
6ZB5410-0DW02 810/820 GA3 PLC编程说明
6ZB5410-0EP02 810/820 operating and programming[English]
6ZB5410-0EP02-0BA0 sin810T,operation and programming,[中文]
6ZB5410-0EQ02-0BA0 sin810M,operation and programming,[中文]
6ZB5410-0EQ02-0BA2 sin810M,operation and programming,ENGLISH
6ZB5410-0HM02 810/820N BV2/3 OP PART 1: operating and PART 2: programming
6ZB5410-0HP02 810/820N BV2/3 interface de
6ZB5410-0HU02 810/820G BV3 Installation
BES 516-325-AO-C-PU Inductive Sensors M12x1 x 72 normally-open Sn=2mm shielded
E20001-H3880-C500-V1-5D00 840D/810D/FM-NC 操作指南
E20001-H5550-C500-V1-5D00 810D/840D 简明调试指南
E20001-H5560-C500-X-5D00 840D/840Di/810D/611D 调整表
E20001-H5580-C400-V2-5D00 S7-300硬件和安装手册
E20001-H6110-C500-X-5D00 840D/840Di/810D 操作部件
E20001-HX810-C500-U-5D00 编程指南
E2001-H3870-C500-V1-5D00 诊断指南
E2001-H3940-C500-V1-5D00 简明操作手册
E7810-4CA04-03-5D00 S7 STEP 7 V5.3编程参考手册
更多工控及相关产品请访问天津鼎辉科技发展有限公司网站 网址:www.tj-30.cn
