ALLIED MOTION电机
ALLIED MOTION代理 ALLIED MOTION美国 ALLIED MOTION价格 ALLIED MOTION经销
宁波金晟杰机电有限公司供应美国LIED MOTION电机、ALLIED MOTION马达、ALLIED MOTION驱动器、ALLIED MOTION步进电机、ALLIED MOTION齿轮箱、ALLIED MOTION伺服驱动器、ALLIED MOTION伺服电机
美国ALLIED MOTION是世界著名的运动控制专业厂商。
主要产品有:COPI编码器、伺服驱动器、伺服电机、Megaflux大扭矩无刷电机、无刷直流电机、永磁直流电机等。ALLIED MOTION电机、直流无刷电机、无芯直流电机、铁芯直流电机、同步马达、扭力电机、伺服马达、驱动器、步进电机、齿轮箱、编码器.
Motor Maintenance Kit, 230V, for ZU4
ZU4-series, portable electric Z-Class pumps ZU4-series, portable electric Z-Class pumps ... reservoirs: 4, 8, 10, 20, 40 litres usable oil ZU4 applications: for intermittent duty cycle and high speed applications ... transport is required and/or on remote locations ZU4 standard electric: manual valve ZU4 electric with LCD: manual ...
* High-efficiency two speed pump: higher oil flow and bypass pressure: 11,5 l/min at 7 bar; 8,8 l/min at 50 bar; 1,0 l/min at 700 bar
* 1,25 kW universal motor: high power-to-weight ratio, excellent low-voltage operating characteristics
* Moulded composite shroud: ergonomic, non-conductive handle for easy transport
* Steel reservoirs: 4, 8, 10, 20, 40 litres usable oil
* ZU4 applications: for intermittent duty cycle and high speed applications with medium to large size cylinders and tools, and when frequent pump transport is required and/or on remote locations
* ZU4 standard electric: manual valve
* ZU4 electric with LCD: manual or solenoid valves. Back-lit LCD provides self test, diagnostic and read-out capabilities
* For special requirements many pump options available
该产品种类齐全 品质优良 如您有意购买 欢迎来电咨询!
