ELO1928L ELO19寸医疗触摸显示器
品牌: ELO
型号: ELO1928L ELO19寸医疗触摸显示器
供货总量: 1000 台
所在地: 广东 惠州市
有效期至: 2012-12-31 [已过期]
最后更新: 2012-01-01 14:58
 声学脉冲波辨识(APR)技术是Elo2007年6月于美国西岸所发表的新技术。它的优点在于极佳的光学质量(高透光性),耐用,稳定性,拖曳特性。特别适合用于各种环境的应用
    ELO广范的触控产品系列包括触摸屏、触摸显示器以及触控一体机,能够满足各类应用的严格需求,如工业、医疗、POS、公共设备查询机、接待、交通运输、办公设备及游戏机等。
    Model 1928L
    Form factor Desktop
    Enclosure color Dark gray, beige
    Diagonal size 19.0"
    Aspect ratio 5:4
    Useful screen area Horizontal: 14.8" (376 mm)
    Vertical: 11.9" (301 mm)
    Monitor dimensions (with stand) Width: 16.9" (429 mm)
    Height: 15.2" (386 mm)
    Depth: 8.2" (207 mm)
    Native (optimal) resolution 1280 x 1024 at 60 Hz
    Other supported resolutions 1280 x 1024 at 60 or 75 Hz
    1280 x 960 at 60 Hz
    1152 x 864 at 75 Hz
    1024 x 768 at 60, 65, 70 or 75 Hz
    832 x 624 at 75 Hz (Mac)
    800 x 600 at 56, 60, 72 or 75 Hz
    720 x 400 at 70 Hz
    720 x 350 at 70 Hz
    640 x 480 at 60, 66, 72 or 75 Hz
    Colors 16.7 million
    Brightness
    (typical) LCD panel: 300 nits
    AccuTouch: 246 nits
    Acoustic Pulse Recognition: 276 nits
    IntelliTouch: 276 nits
    Response time - total (typical) 20 msec
    Viewing angle
    (typical) Horizontal: ±89° or 178° total
    Vertical: ±89° or 178° total
    Contrast ratio (typical) 1300:1
    Input video format Analog VGA, DVI-D
    Input video signal connector Mini D-Sub 15-Pin VGA type, DVI-D connector
    Input frequency Horizontal: 31.5–80 kHz
    Vertical: 56.3–75 Hz
    Power supply External DC (power brick)
    Input voltage DC: 12.0 V ± 0.60 V
    Input connector DC: Coaxial power jack (2.5 mm pin diameter, 6.3 mm barrel diameter, 9.5 mm barrel length)
    Power consumption (typical) 48 W
    Temperature Operating: 0°C to 40°C (32°F to 104°F)
    Storage: -20°C to 60°C (-4°F to 140°F)
    Humidity
    (noncondensing) Operating: 20%-80%
    Storage: 10%-90%
    Weight Actual with stand: 17.7 lb (8.0 kg)
    Actual without stand: 13.5 lb (6.1 kg)
    Shipping with stand: 26.1 lb (11.8 kg)
    Shipping box dimensions
    (W x D x H) 21.27" (540 mm) x 20.09" (510 mm) x 11.23" (315 mm)
    Backlight lamp life Typical 40,000 hours to half brightness
    MTBF 50,000 hours demonstrated
    Warranty 3 years
    Optional product coverage Advance Unit Replacement program (North America only)
    Extended Warranty(North America and EMEA only)
    Agency approvals North America/Worldwide: UL, cUL , CB, MPR II, CE, FCC, VCCI, IC, C-Tick (Class B), Argentina S, IEC/EN61000-4-3
    Asia: UL, cUL , CB, MPR II, CE, FCC, VCCI, IC, C-Tick (Class B), Argentina S, MIC, eK, CCC, China RoHS, IEC/EN61000-4-3
    Speakers 2 watt/channel speakers located in display head
    On-screen display (OSD) Controls (side): menu, up, down, select, power
    Settings: contrast , brightness, H-position, V-position, recall default, RGB, volume, sharpness, phase, clock, OSD H-position, OSD V-position, OSD timeout, auto adjust, input select
    Languages: English, French, Dutch, Spanish, Swedish, Italian, Chinese, Polish, Japanese
    Lockouts: power, user controls
    Stand options Tilt, remove
    Mounting options 100 mm VESA mount
    Threaded-through mounting holes, under stand
    Sealing Touchscreen sealed to bezel
    Touchscreen sealed to LCD
    Other features 2 stage DPMS
    VESA DDC, Plug & Play
    Five-second power down delay function
    Security lock receptacle 信息属性: 品牌:ELO
型号:1928L
分辨率:1280×1024
单点触摸>:3500 万次
外形尺寸:19 mm
OEM:不可以
