外壳/边框颜色 Dark gray
显示类别 活动矩阵TFTLCD
液晶屏尺寸 Size: 19.0" diagonal
Type: Active matrix TFT LCD
Aspect ratio: 5 x 4
显示区域 Horizontal: 14.82" (376.32 mm)
Vertical: 11.85" (301.06 mm)
显示器尺寸 Width: 16.9" (429 mm)
Height: 14.92" (379 mm)
Depth: 8.15" (207 mm)
尺寸图编号 MS600183 Rev A
最佳(真实)分辨率 1280 x 1024
其它支持分辨率 1280 x 1024 at 60 or 75 Hz
1152 x 864 at 75 Hz
1024 x 768 at 60, 65, 70 or 75 Hz
832 x 624 at 75 Hz (Mac)
800 x 600 at 56, 60, 72 or 75 Hz
720 x 400 at 70 Hz
720 x 350 at 70 Hz
640 x 480 at 60, 66, 72 or 75 Hz
颜色 16.7 million with dithering
亮度-LCD面板 LCD panel: 300 cd/m2 (typical)
亮度-带触摸屏的LCD面板 with AccuTouch: 240 cd/m2 (typical)
with IntelliTouch: 270 cd/m2 (typical)
响应时间 5 msec (typical)
视角(从中间) Horizontal (left/right): ±80° or 160° total
Vertical (up/down): ±80° or 160° total
对比度(标准值) 800:1 (typical)
输入视频模式 Analog (no proprietary video card needed)
输入同步模式 Separate horizontal and vertical sync, composite sync and sync-on-green
输入视频信号连接器 Mini D-Sub 15-Pin VGA type
输入频率 Horizontal: 31.5-80 kHz
Vertical: 56.3-75 Hz
电源 Type: Internal, with jack to accept power from optional external brick
AC input (line) voltage: 85-265 VAC, 47–63 Hz
DC input (line) voltage: 12.0 VDC ±0.75V
附加功能 无
功耗 50 W max.
温度 工作温度0℃-40℃;储藏温度-20℃-60℃
保修:3年保修。
