Quanzhou Jinshengyuan Electronic Trading Co., Ltd
业务负责人: 黄文欣
咨询--座机:0595-82081003 邮编 3610000
咨询--热线:15805022076 邮箱2130392898@qq.com
手机:15805022076(VX开头加个G)
咨询---Q Q: 2130392898
NORTEL NT0x91AA ConVERTER ALARM BOARD
ELECTROSWITCH 78PA10LH ConTROL SWITCH RELAY
UNIMESS/AMBIT UKT 2000 GAUGE/METER (BROKE FRONT HANDLE)
ABB FRXG065944440C FT-19R FLEXITEST SWITCH PANELNIB
ABB FRXG065833440CF FT-19R FLEXITEST SWITCH PANELNI
ALLEN BRADLEY 1321-3R25-B 5 PERCENT IMPEDANCE LINE REAC
SQUARE D 9050-BO 25D PNEUMATIC TIMING RELAY B0NT*
TB WOODS XFC4002-0B MICRO-INVERTER AC DRIVE 2HP (MISSIN
SPRECHER+SCHUH CAS7-12D-14C SAFETY ConTACTOR 24VDCN
TOSHIBA VFXC-1232/B15 ConTROL BOARD
GE/YOKOGAWA 103131LSNG7 AMP METER 0-20A
DELTROL 23258-70 DPST 20-30A 115V/600V CONTACTORNNB
BLACK BOX LE6202 COAX REPEATER INTERFACE CARD
APOLLO 70-104-01 3/4" BRonZE BALL VALVE (LOT OF 4)N
SQUARE D 9065-AGO-1R/AG0?-1R THERMAL OVERLOAD RELAYN
PARKER/SCHRADER BELLOWS H2665BGA53A/H26?VXBGA53ANNB*
BITRODE 3AC10140-201 PC BOARD
TOTAL ConTROL PC752PBM604A/PC?752CCS009A INTERFACEGO
OMRON E3HS-DS5E1 12-24VDC PHOTOELECTRIC SWITCH
ALLEN BRADLEY 1321-3R35-B LINE REACTOR OPEN 3MPX
SMC CDRA1BW50-190C ROTARY ACTUATOR 1.0MPa
SCHIELE 2.407.551.20/24?0755120 ADI-12 PLC MODULE
BARMAG EB42B RELAY BOARD
SANGAMO AC/50 TRANSDUCER
C.A. NORGREN CO. P84EA15 PNEUMATIC VALVE
LENZE 6812S-23 AC DRIVE 6800SB***
DAYTON 4Z280 1/12HP, 115V 60Hz PERMANENT SPLIT CAPACITO
GE CR1062R31B MANUAL MOTOR STARTER W/ ENCLOSURENIB*
INGERSOLL-RAND/?ARO EConOMAIR 2320-5209-300 CYLINDER
MOVOMATIC PC117B RELAY BOARD
BAY NETWORKS DL012099 BAYSTACK 152 10base-T HUB*NIB
ALPHA DRYER 493079 900117 POWER SUPPLY CARD
ALLEN BRADLEY RED BEACON/SIGNAL LIGHT
STI 42687-0400/MS43?40BX MINISAFE TRANSMITTER
TELEMECANIQUE GV2P14H7 CIRCUIT BREAKER MOTOR
MESSER S320-1-346 GAS PRESSURE REGULATOR 0-15 PSINN
VOGEL 316591-002 SPEED GEAR REDUCER 1:1
NAMCO EA700-70001 SNAP-LOCK LIMIT SWITCH
CHESTERTON 666595/255-20 SLV A2 CARTRIDGE DUAL SEAL
ADVANCE 71A8472-001 QUADRI-VOLT CORE & COIL BALLAST
MANUTEC INC. C91-SA-03 C91SA03 ROTAY COUPLER
SMC MXF12-20 SLIDE CYLINDERNNB*
SIEMENS C98040-A1401-P2?-01-85 CIRCUIT BOARD
PHOENIX ConTACT QUINT-PS-120AC/?2?4DC/1 POWER SUPPLY
SSD link L5207-2-00 L5207200 PROCESSOR MODULE
RIKEN KEIKI RKP-62069/GP-57?1A INDICATOR ALARM
FUJI 2MBI50N-120 BLOCK
CHYRON CORP 4A0 0065 REV 9 SYNC GENERATOR INFINITY BOAR
CHYRON CORP 4A0 0065 REV B MIX & EFFECTS BOARDNT*
CHYRON CORP 3A00522 REV03/4A02607 REVA/6A01117/6A?11117
OHIO GEAR B262 GEAR REDUCER 40:1 1.05HP
CHYRON CORP 6A01080 REVG/ 4A02523 REV/ 3A00491 REV01 VI
HOHNER IN960-1525-67A1?-0500 ROTARY ENCODER
SMC MXS20-10 DUAL ROD TABLE SLIDE CYLINDER
OMRON CQMIH-CPU21 PROGRAMMABLE ConTROLLER CPU UNITX
MAGNETEK 5P90-0267 CONTROLLER
EUPEC 110463-TT 170 N 10K7 POWER BLOCK
EUPEC 110463-TT170N 18L2 POWER BLOCK
SPIRAX SARCO 3/4 13WHS/69846 300PSIG AIR ELIMINATOR
CIC 5525-0-(-1)H20G?-7A-10 PRESSURE TRANSMITTERNT*
DURANT 39700-600 SHAFT ENCODER 600PPRXLNT**
