Quanzhou Jinshengyuan Electronic Trading Co., Ltd
业务负责人: 黄文欣
咨询--座机:0595-82081003 邮编 3610000
咨询--热线:15805022076 邮箱2130392898@qq.com
手机:15805022076
咨询---Q Q: 2130392898
REXROTH HMV02.1R-W0015-A-07.NNNN 380-480V 23A 750V-DC 15KW SERVO
ALLEN BRADLEY 1336S-C007-AN-FR ADJUSTABLE FREQUENCY 7.5HP MOTOR
BAILEY IMCOM03 INFI 90 ENHANCED ConTROLLER 24V-DC 6VA PCB CIRCUIT
WORTHINGTON D1022 DLS D-LINE 3X2-5IN 230/460VAC 5HP CENTRIFUGAL
FOXBORO B0132WV-B MCU MODULE PCB CIRCUIT BOARD D473796
BUSCH RC0063-A005-1106 220/480V-AC SINGLE STAGE ROTARY VANE
BUSCH RC0063-A005-1001 SINGLE STAGE ROTARY VANE 41CFM VACUUM PUMP
NEW LEWA EK1 0.33HP 1725RPM 15MM STROKE 208-230/460V-AC METERING
NEW ABB 3HAB8101-8/12E DSQC346G ROBOT SERVO DRIVE D374903
NEW GOODYEAR 5800-20M-290 HI-PERFORMANCE PD 5800MM 290MM TIMING
NEW ABB NDCU-11K DRIVE ConTROL UNIT ASSEMBLY ConTROLLER D425218
NEW WITTENSTEIN ALPHA TP 110X-MF2-91-0G1-2S-KF 91:1 GEAR REDUCER
INGERSOLL RAND 92RA008 MULTI-VANE NPT 150PSI 1 IN 1-3/4 IN MOTOR
OKUMA OSP7000M E4809-770-104 OPERATOR INTERFACE PANEL D387744
CATERPILLAR CAT 6E-5927 TORQUE CONVERTER-REAR BRAKE COOLING OIL
CROUSE HINDS EBBRA604 RECEPTACLE EXPLOSION PROOF DISCONNECT
ATLAS COPCO 1614-6927-80 FLOAT VALVE 1/2IN NPT AIR COMPRESSOR
NEW PATERSON 16-1/2 IN BRonZE PUMP IMPELLER D497406
NEW FLOWSERVE 7001492 BEARING COLUMN TEE ASSEMBLY BRASS D476710
ALLEN BRADLEY 1336S-C030-AN-FR 30HP ADJUSTABLE FREQUENCY MOTOR
NEW ALLEN BRADLEY 1336F-B050-AN-EN 50HP ConSTANT TORQUE AC MOTOR
PSI AUTOMATION DV20-191-05 590CFM 1-1/4 IN 2 IN 1-5/8 IN
ALLEN BRADLEY 1336-MOD-KC050 SER D 3750W DYNAMIC BREAK FOR AC
NEW ELAU SM-100/30/080/P0/45/M1/B1 PACDRIVE SERVO MOTOR 400V
D/A SWEDEN RL-02 STEPPING MOTOR 110/220V-AC ConTROLLER B391032
D/A SWEDEN GD-01 110/220V-AC POWER SUPPLY B391784
DAMETRIC FG-01 110/220V-AC PCB CIRCUIT BOARD B392002
VOITH IMPACT PC-104 MULTI BUS ADAPTER CPU PROCESSOR PCB CIRCUIT
