| 工业串口智能彩屏 - 列表 | |||||||
| 英寸 | 型号 | 外形尺寸(W*H) | 显示尺寸 | 显示像素 | 产品描述 | 资料下载 | 说明 |
| 1.77" | T-EF018K01280160ALIA | 待定 | 35.04*28.03 | 128RGB*160 | TTL/RS232,竖横方向可显 | 3:04 | |
| 2.0" | T-EF020K01760220ALIA | 待定 | 31.7*39.6 | 176RGB*220 | TTL/RS232,竖横方向可显 | 3:04 | |
| 2.2" | T-EF022K01760220ALIA | 待定 | 34.9*43.6 | 176RGB*220 | TTL/RS232,竖横方向可显 | 3:04 | |
| 2.4" | T-EF024K02400320ALIA | 待定 | 48.96*36.72 | 240RGB*320 | TTL/RS232,竖横方向可显 | 3:04 | |
| 2.6" | T-EF026K02400320ALIA | 46.0*83.0 | 39.6*52.8 | 240RGB*320 | TTL/RS232,竖横方向可显 | 3:04 | |
| 2.8" | T-EF028K02400320BLIA | 51.8*78.2 | 43.2*57.6 | 240RGB*320 | TTL/RS232,竖横方向可显 | 3:04 | |
| 2.8" | T-EF028K02400320DLIA | 51.8*78.2 | 43.2*57.6 | 240RGB*320 | IPS全视角,TTL/RS232,竖横方向可显 | 3:04 | |
| 3.0" | T-EF030K02400400ALIA | 48.0*87.0 | 38.9*64.8 | 240RGB*400 | IPS全视角,TTL/RS232,竖横方向可显 | 9:16 | |
| 3.2" | T-EF032K02400320ALIA | 待定 | 48.6*64.8 | 240RGB*320 | TTL/RS232,竖横方向可显 | 3:04 | |
| 3.5" | T-EF035K03200480ALIA | 55.5*94.0 | 48.96*73.44 | 320RGB*480 | IPS全视角,TTL/RS232,竖横方向可显 | 3:04 | |
| 3.5" | T-EF035K03200480BLIA | 70.0*93.0 | 48.96*73.44 | 320RGB*480 | 普通屏,TTL/RS232,竖横方向可显 | 3:04 | |
| 3.5" | T-EF035K03200240ALIA | 93.0*70.0 | 70.08*52.56 | 320RGB*240 | TTL/RS232/USB,横竖方向可显 | 4:03 | |
| 3.5" | T-EF035K03200240BLIA | 83.0*82.6 | 70.08*52.56 | 320RGB*240 | TTL/RS232/USB,横竖方向可显 | 4:03 | |
| 4.3" | T-EF043K04800272ALIA | 122.0*72.0 | 95.04*53.86 | 480RGB*272 | TTL/RS232/USB,横竖方向可显 | 16:09 | |
| 5.0" | T-EF050K04800272ALIA | 144.0*104.0 | 110.88*62.83 | 480RGB*272 | TTL/RS232/USB,横竖方向可显 | 16:09 | |
| 5.0" | T-EF050K04800272BLIA | 137.5*81.0 | 110.88*62.83 | 480RGB*272 | TTL/RS232/USB,横竖方向可显 | 16:09 | |
| 5.0" | T-EF050K08000480ALIA | 137.5*81.0 | 108.88*62.8 | 800RGB*480 | TTL/RS232/USB,横竖方向可显 | 16:09 | |
| 5.0" | T-EF050K08000480BLIA | 144.0*104.0 | 108.88*62.8 | 800RGB*480 | TTL/RS232/USB,横竖方向可显 | 16:09 | |
| 5.6" | T-EF056K06400480ALIA | 146.0*107.0 | 112.9*84.7 | 640RGB*480 | TTL/RS232/USB,横竖方向可显 | 4:03 | |
| 5.6" | T-EF056K06400480BLIA | 128.3*119.3 | 112.9*84.67 | 640RGB*480 | TTL/RS232/USB,正屏,横竖可显 | 4:03 | |
| 6.2" | T-EF062K08000480ALIA | 175.0*94.0 | 139.5*79.3 | 800RGB*480 | TTL/RS232/USB,横竖可显 | 16:09 | |
| 7.0" | T-EF070K08000480ALI | 185.0*105.0 | 154.08*85.92 | 800RGB*480 | TTL/RS232/USB/CAN/网口,横竖可显 | 16:09 | |
| 7.0" | T-EF070K10240600ALIA | 185.0*105.0 | 154.08*85.92 | 1024RGB*600 | TTL/RS232/USB/CAN/网口,横竖可显 | 16:09 | |
| 8.0" | T-EF080K08000480ALIA | 215.0*124.0 | 180.1*103.4 | 800RGB*480 | TTL/RS232/USB,横竖方向可显 | 16:09 | |
| 8.0" | T-EF080K08000600ALIA | 200.0*150.0 | 162.0*121.5 | 800RGB*600 | TTL/RS232/USB,横竖方向可显 | 4:03 | |
| 8.0" | T-EF080K10240768ALIA | 200.0*150.0 | 162.0*121.5 | 1024RGB*768 | TTL/RS232/USB,横竖方向可显 | 4:03 | |
| 9.0" | T-EF090K08000480ALIA | 232.0*134.0 | 200.5*114.2 | 800RGB*480 | TTL/RS232/USB,横竖方向可显 | 16:09 | |
| 10.1" | T-EF101K10240600ALIA | 254.0*160.0 | 222.7*125.3 | 1024RGB*600 | TTL/RS232/USB/CAN/网口,横竖可显 | 16:09 | |
| 10.1" | T-EF101K13650768ALIA | 254.0*160.0 | 222.7*125.3 | 1365RGB*768 | TTL/RS232/USB/CAN/网口,横竖可显 | 16:09 | |
| 10.4" | T-EF104K08000600ALIA | 248.0*183.0 | 211.2*158.4 | 800RGB*600 | TTL/RS232/USB,横竖方向可显 | 4:03 | |
| 12.1" | T-EF121K12800800ALIA | 275.8*178.1 | 261.1*163.2 | 1280RGB*800 | TTL/RS232/USB,横竖方向可显 | 8:05 | |
| 12.1" | T-EF121K13650768ALIA | 279.0*167.2 | 268.0*150.7 | 1365RGB*768 | TTL/RS232/USB,横竖方向可显 | 16:09 | |
| 15.0" | T-EF150K10240768ALIA | 326.5*253.5 | 303.8*228.1 | 1024RGB*768 | TTL/RS232/USB,横竖方向可显 | 4:03 | |
| 15.6" | T-EF156K13650768ALIA | 363.8*215.9 | 344.2*193.6 | 1365RGB*768 | TTL/RS232/USB,横竖方向可显 | 16:09 | |
| 18.5" | T-EF185K13650768ALIA | 430.3*254.6 | 409.8*230.4 | 1365RGB*768 | TTL/RS232/USB,横竖方向可显 | 16:09 | |
