4.3寸智能彩屏模块工业串口带TP触摸功能
最后更新: 2024-04-23 11:21
工业串口智能彩屏 - 列表
英寸 型号 外形尺寸(W*H) 显示尺寸 显示像素 产品描述 资料下载 说明
1.77" T-EF018K01280160ALIA 待定 35.04*28.03 128RGB*160 TTL/RS232,竖横方向可显 PDF 3:04
2.0" T-EF020K01760220ALIA 待定 31.7*39.6 176RGB*220 TTL/RS232,竖横方向可显 PDF 3:04
2.2" T-EF022K01760220ALIA 待定 34.9*43.6 176RGB*220 TTL/RS232,竖横方向可显 PDF 3:04
2.4" T-EF024K02400320ALIA 待定 48.96*36.72 240RGB*320 TTL/RS232,竖横方向可显 PDF 3:04
2.6" T-EF026K02400320ALIA 46.0*83.0 39.6*52.8 240RGB*320 TTL/RS232,竖横方向可显 PDF 3:04
2.8" T-EF028K02400320BLIA 51.8*78.2 43.2*57.6 240RGB*320 TTL/RS232,竖横方向可显 PDF 3:04
2.8" T-EF028K02400320DLIA 51.8*78.2 43.2*57.6 240RGB*320 IPS全视角,TTL/RS232,竖横方向可显 PDF 3:04
3.0" T-EF030K02400400ALIA 48.0*87.0 38.9*64.8 240RGB*400 IPS全视角,TTL/RS232,竖横方向可显 PDF 9:16
3.2" T-EF032K02400320ALIA 待定 48.6*64.8 240RGB*320 TTL/RS232,竖横方向可显 PDF 3:04
3.5" T-EF035K03200480ALIA 55.5*94.0 48.96*73.44 320RGB*480 IPS全视角,TTL/RS232,竖横方向可显 PDF 3:04
3.5" T-EF035K03200480BLIA 70.0*93.0 48.96*73.44 320RGB*480 普通屏,TTL/RS232,竖横方向可显 PDF 3:04
3.5" T-EF035K03200240ALIA 93.0*70.0 70.08*52.56 320RGB*240 TTL/RS232/USB,横竖方向可显 PDF 4:03
3.5" T-EF035K03200240BLIA 83.0*82.6 70.08*52.56 320RGB*240 TTL/RS232/USB,横竖方向可显 PDF 4:03
4.3" T-EF043K04800272ALIA 122.0*72.0 95.04*53.86 480RGB*272 TTL/RS232/USB,横竖方向可显 PDF 16:09
5.0" T-EF050K04800272ALIA 144.0*104.0 110.88*62.83 480RGB*272 TTL/RS232/USB,横竖方向可显 PDF 16:09
5.0" T-EF050K04800272BLIA 137.5*81.0 110.88*62.83 480RGB*272 TTL/RS232/USB,横竖方向可显 PDF 16:09
5.0" T-EF050K08000480ALIA 137.5*81.0 108.88*62.8 800RGB*480 TTL/RS232/USB,横竖方向可显 PDF 16:09
5.0" T-EF050K08000480BLIA 144.0*104.0 108.88*62.8 800RGB*480 TTL/RS232/USB,横竖方向可显 PDF 16:09
5.6" T-EF056K06400480ALIA 146.0*107.0 112.9*84.7 640RGB*480 TTL/RS232/USB,横竖方向可显 PDF 4:03
5.6" T-EF056K06400480BLIA 128.3*119.3 112.9*84.67 640RGB*480 TTL/RS232/USB,正屏,横竖可显 PDF 4:03
6.2" T-EF062K08000480ALIA 175.0*94.0 139.5*79.3 800RGB*480 TTL/RS232/USB,横竖可显 PDF 16:09
7.0" T-EF070K08000480ALI 185.0*105.0 154.08*85.92 800RGB*480 TTL/RS232/USB/CAN/网口,横竖可显 PDF 16:09
7.0" T-EF070K10240600ALIA 185.0*105.0 154.08*85.92 1024RGB*600 TTL/RS232/USB/CAN/网口,横竖可显 PDF 16:09
8.0" T-EF080K08000480ALIA 215.0*124.0 180.1*103.4 800RGB*480 TTL/RS232/USB,横竖方向可显 PDF 16:09
8.0" T-EF080K08000600ALIA 200.0*150.0 162.0*121.5 800RGB*600 TTL/RS232/USB,横竖方向可显 PDF 4:03
8.0" T-EF080K10240768ALIA 200.0*150.0 162.0*121.5 1024RGB*768 TTL/RS232/USB,横竖方向可显 PDF 4:03
9.0" T-EF090K08000480ALIA 232.0*134.0 200.5*114.2 800RGB*480 TTL/RS232/USB,横竖方向可显 PDF 16:09
10.1" T-EF101K10240600ALIA 254.0*160.0 222.7*125.3 1024RGB*600 TTL/RS232/USB/CAN/网口,横竖可显 PDF 16:09
10.1" T-EF101K13650768ALIA 254.0*160.0 222.7*125.3 1365RGB*768 TTL/RS232/USB/CAN/网口,横竖可显 PDF 16:09
10.4" T-EF104K08000600ALIA 248.0*183.0 211.2*158.4 800RGB*600 TTL/RS232/USB,横竖方向可显 PDF 4:03
12.1" T-EF121K12800800ALIA 275.8*178.1 261.1*163.2 1280RGB*800 TTL/RS232/USB,横竖方向可显 PDF 8:05
12.1" T-EF121K13650768ALIA 279.0*167.2 268.0*150.7 1365RGB*768 TTL/RS232/USB,横竖方向可显 PDF 16:09
15.0" T-EF150K10240768ALIA 326.5*253.5 303.8*228.1 1024RGB*768 TTL/RS232/USB,横竖方向可显 PDF 4:03
15.6" T-EF156K13650768ALIA 363.8*215.9 344.2*193.6 1365RGB*768 TTL/RS232/USB,横竖方向可显 PDF 16:09
18.5" T-EF185K13650768ALIA 430.3*254.6 409.8*230.4 1365RGB*768 TTL/RS232/USB,横竖方向可显 PDF 16:09
3.8寸单色LCD液晶显示屏240160图形点阵 1.0寸12864小尺寸LCD液晶显示屏 2.0寸单色LCD液晶显示屏12864图形点阵 1.8寸单色LCD液晶显示屏128*64图形点阵COG结构, 2.8寸高品质单色显示屏防静电抗干扰性能强 LCD液晶屏 12864液晶屏 3.3V串口 长期供应户外电源液晶显示屏 定制各种规格的LCD段码显示屏
