u Clad plate+Sensor(ito Glass)
u Glass + Sensor(ito Glass)
u Glass + ito Film + ito Film
u PET + Sensor(ito Glass)
Additional products
u Polarizer and AR CTP
u AG and low reflective CTP
u AG and AF CTP
Specifications:
Operation viltage :2.8/3.3/5V(for need)
Operation current: 25mA-10mA(Depend on IC)
Surface hardness :3H-7H
Interface:I2C,USB,RS232
Transmittance≥90%,Reflectivity≦6%
Operation temperature:-40°C-+90°C, ≦90%RH
Storage temperature: -40°C-+90°C, ≦90%RH
Surface treatment: AF,AG,AR
Contact method of TP and IC:COF or COB, Operation force:<20g
Operation expectance:>100million
Glass(Cover lens) thickness:0.7mm,1.1mm,2.0mm,3.0mm,6.0mm,8.0mm etc.
Water resistance:spray, No mistake touch by water dripping,operation in small water,
Glove operation:Nylon Glove,Rubber Glove,cotton and linen Glove,woolen glove.
Touch point:10 point
EMC:
EMI(CISPR 22,30mhz~1GHZ) under limit line:-4db
ESD(iec61000-4-2,level4, high:±25kv)
Air: ±15kv, conract±8kv,RS(IEC61000-4-3,Level4:30v/m)
EFT(IEC61000-4-4,Level4) AC power line:4kv:I/O port:2kv
CS(iec61000-4-6, Level3:10v/m)
Capacity Touch Panel certification
AEC-Q100,IEC,PCI4.0
通过中国触摸屏网金牌会员认证
