适合ECR和CAT应用的高性能打印机
快速打印
双向和逻辑搜索控制能实现30列打印时每秒5.6行(58毫米),或是42列打印时4.4行/秒(76毫米)的高速打印输出。
可靠性
卓越的高可靠性:爱普生标准的MCBF为900万行。
安装了黑标检测器
M-U110II标配了可变电阻的黑标检测器,实现最佳的黑标检测能力。
可使用多种纸卷
M-U110系列支持多种尺寸的纸卷。
M-U110II能够处理两种纸卷宽度:58毫米和76毫米。
M-U111S非常适合使用流行的穿孔纸卷进行打印。
打印多份拷贝
M-U110II能够打印一份原件和一份清晰的复件。
M-U110 Series |
1S tation Printer |
Model |
M-U110II |
M-U122 |
M-U110A |
M-U111S |
Printing Method |
S erial impact dot matrix |
Printing Format |
Font |
7x9 |
7x9 |
Column capacity |
42 columns (76 mm) / 30 columns (58 mm) |
30 columns |
40 columns (89 mm) / 28 columns (76 mm) |
Character size |
1.20 (W) x 3.1 (H) mm |
1.24 (W) x 3.1 (H) mm |
1.24 (W) x 3.1 (H) mm (89 mm ) / 1.5 (W) x 3.1 (H) mm (76 mm) |
Line spacing |
Approx. 4.2 mm |
Column spacing |
Approx. 1.5 mm |
Approx. 1.6 mm |
Approx. 1.6 mm |
Approx. 1.6 mm (89 mm) / Approx. 2.0 mm (76 mm) |
Number of total dots |
210 dots(420 positions)/line (76 mm) / 150 dots (300 positions)/line(58 mm) |
150 dots (300 pos itions ) / line |
210 dots(420 positions)/line (76mm)/150 dots (300positions)/line (58mm) |
200 dots (400 positions) / line / 140 dots (280 positions) / line |
Printing Speed |
4.4lines/sec.(76 mm)/5.6 lines/sec. (58mm) |
4.2lines/sec. |
3.3 lines/sec.(76 mm)/4.2 lines / sec.(58 mm) |
3.4 lines / sec. (89 mm) / 4.4 lines / sec. (76 mm) |
Print head |
Voltage |
24 ± 2.4 VDC |
Peak current |
Approx. 11.7 A (at 24 VDC) |
Approx. 8.6 A (at 24 VDC) |
Approx. 9 A (at 24 VDC) |
Motor |
Voltage |
24 ± 2.4 VDC |
Mean current |
0.35A / phase (CR motor) / 0.3A / phase (P .F .motor) |
Paper |
Roll paper |
Roll paper |
Roll paper |
Sprocket paper |
Dimensions |
Roll paper:76.2±0.7 mm (W)/57.5±0.5 mm(W)xdia.83mm max. Validation:130 mm or more(W)x60mm or more(H) |
Roll paper:57.50.5mm(W)xdia.83 mm max. |
Roll paper :76.2±0.7mm(W)/57.5±0.5 mm(W) dia. 83 mm max |
89.0±0.5mm (W)x127 to 254mm(H) (between perforations) 76.2±0.7mm(W)x127 to 254 mm(H)(between perforations) |
Total Thickness |
Roll paper : 0.06 to 0.14mm |
Roll paper : 0.06 to 0.2mm |
Roll paper : 0.06 to 0.14 mm |
0.25 to 0.35 mm |
Copy Capability |
Original and one copy |
Original and two copies |
Original and three copies |
Ribbon Cassette |
ERC-39(P) |
ERC-42(P) |
ERC-39(P) |
ERC-39(P) |
Operating Temperature |
0 to 50℃ |
Reliability |
Print head Life |
150,000,000 characters |
MCBF |
9,000,000 lines |
5,000,000 lines |
5,000,000 lines |
5,000,000 lines |
Printer Life |
9,000,000 lines |
8,000,000 lines |
8,000,000 lines |
8,000,000 lines |
Overall Dimens ions |
127.0 (W) x 96.0 (D) x 53.0 (H) mm |
108.0 (W) x 96.0 (D) x 53.0 (H) mm |
128.6 (W) x 98.8 (D) x 77.3 (H) mm (76 mm) 127.6 (W) x 98.8 (D) x 77.3 (H) mm (58 mm) |
127.0 (W) x 96.0 (D) x 61.0 (H) mm |
Mass (without options) |
Approx. 470 g |
Approx. 400 g |
Approx. 700 g |
Approx. 460 g |
Reliability |
Print head Life |
