●技术参数: |
● Technical parameters: |
机器型号:CH–202–2 |
Machine model: CH– 202 –2 |
机器尺寸:1000×W440×H850mm |
Machine size: L1000 x W440 x H850mm |
UV 灯参数:2KW×300mm×1 支 |
UV lamp: 2KW * 300mm * 1 |
UV 灯种类:紫外线高压汞灯 |
UV lamp types: ultraviolet high pressure mercury lamp |
UV 波长:365~390nm |
UV wavelength: 365~390nm |
UV 室温度:45℃ |
UV room temperature: 45℃ |
灯管强度:100% |
Lamp intensity: 100% |
UV 灯功率密度:95W/cm |
The UV lamp power density:95W/cm |
深圳市盛世晨晖科技有限公司
UV 室长:450mm |
UV cells: 450mm |
滚筒:表面滚花,确保输送平稳 |
Roller: surface knurling, ensure the smooth |
整机材料:冷轧板表机喷塑 |
The material: cold rolled plate surface |
输送速度:0.1-10m/min |
Transmission speed: 0.1-10m/min |
输送带宽度:200mm |
Belt width:200mm |
冷却方式:强制风冷 |
Cooling: forced air. |
自动延时关机:有 |
Automatic delay shutdown:Yes |
外接电源:220V |
External power supply: 220V |
输送带材质:特氟龙或不锈钢 |
Conveyor belt material: Teflon or stainless steel |
●适应范围:紫外线 UV 胶固化,UV 光油或者 UV 涂料固化
●Applicable scope: ultraviolet UV curing,UV ink or UV paint curin
