机器型号:CH–435–5 Machine model: CH– 435 –5
机器尺寸:L1700×W740×H1500mm Machine size: L1700×W740×H1500mm
UV灯参数:2KW×550mm×2支 UV lamp: 2KW *550mm * 2
UV灯种类:紫外线高压汞灯(UVA) UV lamp types: ultraviolet high pressure mercury lamp (UVA)
UV波长:365nm UV wavelength: 365nm
UV室温度:70℃ UV room temperature: 70℃
灯管强度:100% Lamp intensity: 100%
UV灯功率密度:90W/cm The UV lamp power density:90W/cm
UV灯可调高度:100—250mm(角度可调) UV lamp with adjustable height: 100 - 250mm ( adjustable)
输送带材质:特氟龙 Conveyor belt material: Teflon
反射罩: 铝制反射罩内置进口反光铝,反射效率高,使用寿命长
Reflector: aluminum reflector built-in imported aluminum reflector, the reflection of high efficiency, long service life
进料端长:100mm The feed end length: 100mm
UV 室长:1000mm UV cells: 1000mm
出料端长:100mm The discharge end length: 100mm
滚筒:表面滚花,确保输送平稳 Roller: surface knurling, ensure the smooth delivery of
整机材料:冷轧板表机喷塑 The material: cold rolled plate surface machine spray
输送速度:0.1-8m/min Transmission speed: 0.1-8m/min
输送带宽度:500mm Belt width:500mm
冷却方式:强制风冷 Cooling: forced air.
自动延时关机:有 Automatic delay shutdown:Yes
外接电源:380V External power supply:380V
●适应范围:紫外线UV胶固化,UV光油或者UV涂料固化
●Applicable scope: ultraviolet UV curing,UV ink or UV paint curin
