CH-101-1C抽屉式 UV 固化箱
●技术参数: |
●Technical parameters: |
机器型号:CH–101-1C |
Machine model: CH - 101-1C |
机器尺寸:L500×W430×H620mm |
Machine size: L500 x W430 x H620mm |
UV 灯参数:1KW×300mm×1 支 |
UV lamp: 1KW * 300mm * 1 |
抽屉尺寸:L430×W360×H150mm |
Size: L430 x W360 x H150mm |
UV 灯种类:紫外线高压汞灯 |
UVlamp types: ultraviolet high pressure mercury |
灯管强度:100% |
lampLamp intensity: 100% |
UV 灯功率密度:85W/cm |
The UV lamp power density: 85W/cm |
UV 波长:365nm |
UV wavelength: 365nm |
冷却方式:强制风冷 |
Cooling: forced air. |
自动延时关机:无 |
Automatic delay shutdown: no |
外接电源:220V |
External power supply: 220V |
温度参考:动态温度 60℃ |
The temperature reference: dynamic |
temperature below60℃ |
●适应范围:紫外线 UV 胶固化,UV 油墨或者漆料固化
●Applicable scope: ultraviolet UVcuring,UVink
可添加:故障报警,其它未说明事项可按做
●add: fault alarm, other unspecified matters can be customized according to customer demand
